Beau M Samba Member
Posted: Wed Nov 17, 2021 8:00 pm Post subject: FNG with my first Baja |
Hello all
I've been wrenching for 20+ years and recently bought my first air cooled VW, a 71 beetle. Its got the baja fiberglass fenders etc, it was in the process of being converted to a 13b rotary when I bought it.
It's definitely a project vehicle and many months away from being on the road. I bought the bug with no engine, but have since acquired two, both in pretty rough shape. I've torn down one and it had rust on the con rods, the other I drained the oil and there was so much sand it was chunky.
I'm vacillating daily on sticking with the air cooled or do a subie swap. I'm no stranger to engine swaps, I put an LS in my 98 Tahoe and have a 68 Mustang with a Toyota 2JZ. The only real two downsides I see with the subie motor are radiator placement and oil pan clearance, even with the shortened ones. If I stay VW it will probably end up being more $$$ and I'll have less HP.
I'm not even sure what I'm getting at here. A couple ???s
Is the subie pan clearance a huge issue off-road? The bug will mostly be seeing logging roads and trails in WA, occasional sand.
I just don't know what to do. With my current junk it most likely involves a machine shop and a bunch of new parts. With a subie engine I can get a low mileage one with a warranty and plop it in. Sure I need the adapter and wire harness and all that, but the needed parts for the VW add up real fast.
Anyway, here's the car.
Engine #1 I tore down, must have had a lot of moisture
Engine #2 with the gritty sludge oil. This is as far as I've gotten.
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Wed Nov 17, 2021 8:27 pm Post subject: Re: FNG with my first Baja |
In the last year I have done an ecotec and an air cooled from a similar starting point. Any efi watercooled swap is gonna cost ~3500 unless you cut a bunch of corners, and will be pushing a type 1 trans hard. An Air cooled engine is probably 2500-3500 just for the engine depending on how much you have to buy new, but you won’t have to spend the $ on adapters, electric fuel pump, radiator set up, fans, ecu/wiring, etc.
air cooled power has a very different, better vibe IMO and it more fun to drive in a Stockish car.
That is a cool Baja
EDIT: Looks like a three rib bus trans in there. Makes a water cooled engine a little more appealing. I would ride in a 2+ Liter air cooled car before you go away from air cooled _________________ it's more fun loud and dirty |
Beau M Samba Member
Posted: Wed Nov 17, 2021 9:05 pm Post subject: Re: FNG with my first Baja |
Thanks for the advice!
Yup it has a bus trans but I don’t know much about it. It has a new fuel tank up front and an EFI fuel pump with new feed / return lines (intended for the 13g).
I’m not in a huge hurry so have time to do more research but this is a much harder decision than expected. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12745 Location: Western Canada
Posted: Thu Nov 18, 2021 6:43 am Post subject: Re: FNG with my first Baja |
A water pumper swap will give you more HP at a far lower cost engine wise but there are trade offs. There will be a 100 pound or more weight penalty, wiring, rad placement and plumbing are going to be a challenge. I would also expect the resale value of the car to go down. Another thing to consider and you are not telling us yet is with a full bodied car if you will be needing a heating/defrost system. A swap is going to complicate that. In some parts of the country it is a requirement to make the car street legal.
If you are not a HP freak, quite frankly I would finish the engine teardowns, clean both up and measure the critical bits with the goal in mind to re-use as much stock parts as possible. Two reasons, first off is that in many cases the stock parts from VW are of better quality and they FIT! The second is that if you are not power hungry a stock 1600 DP (built carefully with attention to detail) with it's light weight and that Bus transaxle will surprise you both on and off the road. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Beau M Samba Member
Posted: Thu Nov 18, 2021 10:34 am Post subject: Re: FNG with my first Baja |
All good points. There's no need for heater / defrost here, but I think that would be fairly easy to set up with the subie motor.
As far as the 100lb weight penalty, my fat butt is already a there
I agree. I'll tear the other down and clean them up. I know if I go VW I'll need pistons / jugs / heads, which are around $600 for the set. Not terrible. But I can see how the other parts can nickel and dime you. |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
cbeck Samba Member
Beau M Samba Member
Posted: Thu Nov 18, 2021 8:03 pm Post subject: Re: FNG with my first Baja |
Wulfthang Samba Member
Posted: Thu Nov 18, 2021 9:05 pm Post subject: Re: FNG with my first Baja |
I used to own a Baja many years ago with a fairly hot VW engine. Now I have a Rail with a fairly hot Ford V6 water cooled engine in it. The difference is incredible. I'll never go back to air cooled!
My engine is a a 2.8 Cologne and it's old school heavy iron. I had the engine and I had the adapter kit so it was a no brainer to put it in my rail. Look around and maybe pick up an older engine for a lot less money. You could probably take your choice of several different engines, with or without computer systems. I don't know where you'd mount the radiator though. I put mine on my rail up on her back. If you do decide to go water cooled, get the biggest radiator that you can fit! |
cbeck Samba Member
Posted: Fri Nov 19, 2021 5:00 am Post subject: Re: FNG with my first Baja |
Shop talk forum has a conversion perversion thread. Lots of ideas there also.
_________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Beau M Samba Member
Posted: Fri Nov 19, 2021 8:53 am Post subject: Re: FNG with my first Baja |
Why is this decision so hard???
Last night I "decided" I'm going air cooled after watching a few rebuild videos. Then I took stock of what I have, and did some quick guestimating, an it will cost at least $1000 for me to get a mostly stock engine up and running.
I can buy an entire subaru legacy for that.
Sure I will still need the adapter and a billion other parts, but tossing a grand into an air cooled only to pull it out due to disappointment seems bad.
I am no stranger to swaps or "while I'm at it" project scope creep. Here's my 68 Mustang with a 2JZ. I'm also no stranger to EFI in an old car and all the "fun" that comes with it.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Fri Nov 19, 2021 1:10 pm Post subject: Re: FNG with my first Baja |
You could have an air cooled engine running in 1 week, but water cooled will be 1 year! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oprn Samba Member
Posted: Fri Nov 19, 2021 1:40 pm Post subject: Re: FNG with my first Baja |
Your mind was made up before you started this thread. You are a swap guy so - have at it and enjoy! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Aerindel Samba Member
Joined: May 30, 2015 Posts: 459 Location: Western Montana
Posted: Fri Nov 19, 2021 2:26 pm Post subject: Re: FNG with my first Baja |
I wish I knew how to swap engines....I have four subaru engines just sitting on shelves, but I have no idea how to make them run without putting them in a subaru. One of them, a subi 1.8 I think would be paricularly good in a buggy.
My VW engine though, I could get that running on an engine stand in about ten minutes. _________________ Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046 |
Blue Coyote Samba Member
Joined: September 05, 2009 Posts: 14 Location: Eugene OR
Posted: Fri Nov 19, 2021 6:26 pm Post subject: Re: FNG with my first Baja |
Welcome to the Baja world - also a first timer. What started as a $400 Gambler and has since gotten a ‘bit out of hand’. Been down the “what engine” road - started with a 1600 and when that gave up went to a 2.0. Also been down the used engine and what’s inside - it’s always water. Car is light enough it has plenty of power. And the nice part is that any air cooled motor will bolt up. Have plenty of other big HP and LT rides, but the bug is just stupid fun to drive - simple, requires some skill to keep alive.
And love that wing (seriously- mine needs a wing…
_________________ 1969 Gambugly- HooptieX/ GORRA / Gambler500 pile of parts. |
Posted: Fri Nov 19, 2021 8:15 pm Post subject: Re: FNG with my first Baja |
Beau M wrote: |
Because it fundamentally changes a Baja bug into something else entirely when you ditch the air cooled.
It is hard to pick, it really is! I’ll say it again, go spend a weekend riding/driving a well built air cooled car before you decide. I have a turbo efi camaro, and thought the ecotec was the right choice… well I’m back in an air cooled and I think I prefer it! It’s hard to beat a mech fuel pump, carbureted air cooled in good condition that is just a play car. But don’t get me wrong the ecotec absolutely RIPS - haha I guess I’m not helping much! _________________ it's more fun loud and dirty |
Beau M Samba Member
Posted: Sat Nov 20, 2021 9:57 am Post subject: Re: FNG with my first Baja |
Blue Coyote wrote: |
Nice! I’m also an avid Gambler and that will be this cars main use. I’m sure I saw your car at the Gilchrist store once or twice. My goal is to have this thing up and running by June |
pickuptrucker Samba Member
Posted: Sun Nov 21, 2021 2:03 pm Post subject: Re: FNG with my first Baja |
I'm glad you named your mustang abomination lol. I live in Washington
Also, whichever engine you choose I'll rip up some logging rosds with you! My bug is totally stock right now, still trying to decide exactly what to do with it |
cbeck Samba Member
Posted: Sun Nov 21, 2021 5:17 pm Post subject: Re: FNG with my first Baja |
The sacrilege, the only way to make it right is to put the mustang motor in the beetle. _________________ My cut in half and rebuild thread
no1clyde Samba Member
Joined: August 27, 2013 Posts: 365 Location: Elko Nv.
Posted: Sun Nov 21, 2021 7:08 pm Post subject: Re: FNG with my first Baja |
I used a 1992 Subaru Legacy motor and computer in my Baja
Just buy a old Legacy and use as much as you can from it.
Ed |
