How to adjust window scraper on a '72 - '74 door
22manybugs
22manybugs is online now
PostPosted: Thu Oct 29, 2015 5:59 pm    Post subject: How to adjust window scraper on a '72 - '74 door Reply with quote
I am replacing the rubber in the window scraper on a 1972 - 1974 Ghia door. It's been impossible to get the rubber adjusted correctly - it's either too tight against the glass (so it drags against the glass and I can't hardly roll down the window) or there is a gap (so the rubber does not block water from running down the window into the door). I did this once before, but that time the rubber was too tight against the glass and tore within a year, so this time I want to get it set right. I've been trying to adjust it by bending the lip at the top of the door that the scraper mounts to, but it seems I can't get fine enough adjustment that way. Does anyone know a trick to get this adjusted correctly?
Lon
1969 Karmann Ghia convertible
1971 Westfalia camper
kiwighia68
kiwighia68 is offline
PostPosted: Thu Oct 29, 2015 6:48 pm    Post subject: Re: How to adjust window scraper on a '72 - '74 door? Reply with quote
There's a very good sequence with photos by Disc at
"Replacing Door Glass Rubber - Another View" in the Stickies.
You know about the Stickies? If not, search the title I've given.
PS I have to do this same job tomorrow. Can't say I'm looking forward to it.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
22manybugs
PostPosted: Thu Oct 29, 2015 8:56 pm    Post subject: Reply with quote
Yes, I saw that article. But it's for a '71 door, and VW completely changed the design of the scrapers for '72 - '74 doors. I don't see any articles covering '72 - '74s.
Lon
22manybugs
PostPosted: Fri Oct 30, 2015 10:41 pm    Post subject: Reply with quote
Okay, I finished it. I kept hoping I'd have an "AHA!" moment and find a simple way to adjust it, but no luck. The steps are: install the scraper assembly, mark sections with masking tape that are either too close to the glass or too far from the glass, remove the scraper assembly, tweak the metal lip in or out by eyeball, and keep repeating. Plus the metal trim is very flimsy, so every time you pull it off, it bends and you have to bend it back to shape. Plus you have to install the trim with the clips that lock the trim to the door because without the clips the rubber doesn't sit in exactly the same position, so removing the trim is always difficult. What a PITA job! I did learn a few things, maybe this will help others in the future.
The scraper and trim is one integrated piece, not like earlier Ghias where the separate pieces are installed on the car. I assume the one piece makes it quicker/cheaper to assemble the car - just take the one piece, pop it on and you're done (as long as the gap is correct to begin with so it doesn't require adjustment). Here's a picture of the integrated trim (sorry it's blurry):
Here's a cross-section. The rubber scraper is sandwiched between the trim, then a metal piece with cloth (felt?) is attached/glued over that. I replaced the rubber by slightly prying apart the trim, digging/cutting out the rubber with a knife (kind of a pain), then spraying the new rubber with some silicone lube and sliding it in from one side (very easy), then clamping the trim piece back down. I don't think I got it clamped as tight as originally, but it seems to work fine.
Here's one of the clips that holds the trim to the door, then the next two pictures show it installed in the trim and installed in the door. There's a lip on the clip that fits into slot in the door to hold it in place. I found it was much easier to put the clips on the door first then push on the trim, versus putting the clip into the trim then pushing onto the door.
Do this first, then push the trim on:
One thing I noticed was that I had a curve to the door lip. I figured it would be a straight line...
But then I checked the glass and found it also has a curve. From the middle, the glass curves out 2 mm on each side. So expect that the door lip and trim should have a curve. (It would be so much easier to adjust if it were a straight line!)
One other thing, when I was done, the gap from the glass to the door lip (with the trim removed) was 0.4 inches across the entire door. If that holds true for other doors, then that might make it easy to setup the trim - just bend the lip to get the 0.4 inch gap everywhere. At least that's a good place to start.
Here's the finished trim. It seems to fit well without the rubber binding against the glass.
Lon
carl4x4
carl4x4 is offline
PostPosted: Sat Oct 31, 2015 1:26 pm    Post subject: Reply with quote
Nice write up, never seen one for a late Ghia before. Mines an earlier car but I do find occasionally it helps to lubricate the scraper seals with some silicon rubber lubricant to stop them sticking to the glass.
1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight=
22manybugs
PostPosted: Tue Nov 03, 2015 12:31 am    Post subject: Reply with quote
I'd be worried about getting the lubricant on the glass, then the glass transfers the lubricant into the felt liner below the rubber, and then you would always be streaking the glass. Doesn't the lubricant smear on the glass and make a mess?
One more thing I wanted to mention. After installing the new scraper, the felt liner is pulled away from the trim piece at both ends. You can see the gap here:
While sitting in the car, I can see the metal that should be hidden behind the felt piece. I didn't notice it at first, but it just looks bad, so I'll pull off the trim and glue (probably use Liquid Nails) the felt piece back up to cover the metal. Man, I really hate pulling off this trim piece. If you have the same issue, glue the felt piece back up before the final installation.
Lon
akcarter
akcarter is offline
PostPosted: Tue Nov 03, 2015 6:11 am    Post subject: Reply with quote
Hi 22manybugs. Where did you purchse the window scraper rubber? I can find the felt easily, but I haven't found a retailer that has the rubber for 72-74.
didget69
didget69 is offline
PostPosted: Tue Nov 03, 2015 8:05 am    Post subject: Reply with quote
1972-74 Window Scraper Rubber Seal -
http://www.karmannghia.com/viewDetail.asp?strMasterCat=1126&idproduct=4500
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
carl4x4
carl4x4 is offline
PostPosted: Tue Nov 03, 2015 1:35 pm    Post subject: Reply with quote
I must have just been lucky so far, but I get your point !
hopkin Premium Member
hopkin is offline
PostPosted: Tue Nov 03, 2015 2:56 pm    Post subject: Reply with quote
I had a similar problem when I did the scrapers on my Beetle (needed some lubricant). The rubber would fold down as I raised and lowered the window.
I sprinkled Baby Powder on the rubber, I only had to use it once on the driver's side and a couple times on the passenger side and the problem went away. That was 2 years ago.
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (past)
2015 Golf GTI (current)
2017 Dune Edition (daughter's car)
didget69
didget69 is offline
PostPosted: Tue Nov 03, 2015 6:00 pm    Post subject: Reply with quote
Two options I've used -
http://www.autogeek.net/1z-einszett-rubber-care-stick.html (I like this one best)
http://store.blackforestindustries.com/wuruca.html
bnc
22manybugs
PostPosted: Wed Nov 04, 2015 12:09 am    Post subject: Reply with quote
bnc
Yeah, that's the one I used. It says "difficult to replace", haha, no kidding. It's not hard, just tedious, and the metal part is easy to bend and warp. If you take your time, no problem. It's $17 for the rubber, or about $120 for the entire scraper assembly (metal trim, felt, rubber already assembled) from KGPR.
Lon
didget69
didget69 is offline
PostPosted: Wed Nov 04, 2015 6:16 pm    Post subject: Reply with quote
bnc
I'm in the same boat; good moldings & bad seals/felt...
bnc
Sterck
Sterck is offline
PostPosted: Wed Jan 31, 2018 8:31 am    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
Hello,
I'm French and new on this site.
I drive a 1971 Karmann ghia but i don't know the year of my doors and the sytem of their window scrapper
As you can see the clips dooesn't fit that's why i had to cut it and stick them all...
Thanks for your help !
c21darrel
c21darrel is offline
PostPosted: Wed Jan 31, 2018 12:46 pm    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
unless the holes are filled over you have a later door. This thread should set you straight.
https://www.thesamba.com/vw/forum/viewtopic.php?t=438734&highlight=door+differences
GhiaBuild
1967 DC build
Sterck
Sterck is offline
PostPosted: Thu Feb 01, 2018 3:53 am    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
Hello,
Thanks for the answer !
Is it possible to have a picture of :
"71 down has a thin chrome blade with a flat piece of rubber riding against the window"
Era Vulgaris
Era Vulgaris is offline
PostPosted: Thu Feb 01, 2018 9:38 am    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
Good pics in this thread of the 71 and earlier scraper seal
https://www.thesamba.com/vw/forum/viewtopic.php?t=563175&highlight=window+scraper
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
Sterck
Sterck is offline
PostPosted: Fri Feb 02, 2018 4:29 am    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
Thanks for your answer.
But as you can see above, they are no hole on my doors Sad
Sterck
Sterck is offline
PostPosted: Fri Feb 02, 2018 4:39 am    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
the white doors have a curve "lips"
Mine are vertical and smaller
Safety_third
Safety_third is offline
PostPosted: Thu Nov 25, 2021 11:28 pm    Post subject: Re: How to adjust window scraper on a '72 - '74 door Reply with quote
This was very helpful.
I haven’t ventured to try and resolve the issue, but at least I understand what could be leading to the problem.
Had the car repainted and used all new rubber. Shop has glass so tight the winders barely budge them and the glass is scratching in places (!) … this will help me as I try to rectify.
Thanks!!!
