bmarkstopspeed Samba Member
Joined: March 01, 2016 Posts: 17 Location: Cincinnati, OH
Posted: Sun Dec 05, 2021 9:22 pm Post subject: 912 engine into a '69 Single Cab Bus... |
I recently picked up a 912 engine that is the perfect candidate for an easy refresh/rebuild.....as luck would have it, I have a '69 Single Cab in need of some extra power and a ready & willing engine bay.
I see quite a few conversions the other way, but can't seem to find any photos and/or insight on installing this 912 engine into the Bus.........I get it the tins are going to be an issue and I'll need to modify some type of 912 engine brace, but the Scab has plenty of space in that engine bay and it's not a concours build so wanted to see what TheSamba forum has to say....
Any help would be great !
Brian
Cincinnati, OH
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79647 Location: Sneaking up behind you
Posted: Mon Dec 06, 2021 4:28 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
bmarkstopspeed wrote: |
I see quite a few conversions the other way, |
Thats because a 912 engine is VERY expensive to get parts for and only produces under 90hp.
Sell it and use the money to buy a new Type 1 engine with more horse power and torque. Then buy your wife something nice with the money left over. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1998 Location: FL Panhandle
Posted: Mon Dec 06, 2021 9:04 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
Agree! Plus you want low end torque for a heavy boxy bus. Should be easy to sell and replace with T1 built engine. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Joined: December 28, 2016 Posts: 310 Location: atlanta ga
Posted: Mon Dec 06, 2021 9:26 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
I too, agree, put the engine out there with the engine id number, someone is looking for it to put in their 912.
CB performance and others have perfected the type 1 engine these days, and it is far superior to the old 912 engine.
If you want to have some fun, just doll up the sheetmetal and parts and put it back together as best you can so it looks more complete |
Starbucket Samba Member
Posted: Tue Dec 07, 2021 4:51 pm Post subject: Re: 912 engine into a '69 Single Cab Bus... |
The 912 is a Hemi and those 90 HP are thoroughbreds and will eat alive any flat top VW of equal HP. The 912 has mounting bosses you just need to make an adaptor for your existing mustache bar. Just shorten the throttle cable and mount a ball socket connector as the 912 linkage connects from the back. Use a 356 muffler or make your own from the 912 muffler mounts (they are oblong as you can see). I used a Center Force dual friction disk & pressure plate. Make a templet from the VW sheet metal engine compartment seal and cut the 912 sheet metal and put some edge guard around the edges. |
bill brown Samba Member
Joined: August 16, 2000 Posts: 37 Location: Lincoln NE
Posted: Wed Dec 08, 2021 7:42 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
I ran a Super 90 engine in my old 67 15 Deluxe bus......and it ran hot in the bus......you need to get some fresh air to the fan. |
Glenn  Mr. 010
Posted: Wed Dec 08, 2021 8:40 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
Starbucket wrote: |
The 912 is a Hemi and those 90 HP are thoroughbreds and will eat alive any flat top VW of equal HP. |
Not many people are racing their VW Bus.
For what I can sell a complete running 912 engine for i can build a 2017 (90.5x78.4) Type 1 engine with 50% more HP and lots more torque.
I can then use the spare cash to buy my wife something nice. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Dec 08, 2021 11:57 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
Glenn wrote: |
Starbucket wrote: |
You don't need to "Race" your VW Bus to have a Porsche motor in it as the Driver will be happier just cruzing around town with it than any 2017 gas sucking monster motor. The 356/912 has the perfect cam etc. to get great gas milage and still have the guts to pick `em up and lay `em down and It just gets worth more money every day you hold on to it. I bet Porsche owners are watching this thread hoping he sells. |
Glenn  Mr. 010
Posted: Wed Dec 08, 2021 12:11 pm Post subject: Re: 912 engine into a '69 Single Cab Bus... |
Starbucket wrote: |
Glenn wrote: |
Starbucket wrote: |
2017cc with EFI and crankfire. 145hp, starts with the turn of the key, idles smoothly @ 800rpm and gets mpg in the mid 30s.
And i bet it cost less than a "correctly" rebuild 912 engine. _________________ Glenn
Member #1009
#BlueSquare
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Sun Oct 23, 2022 11:40 am Post subject: Re: 912 engine into a '69 Single Cab Bus... |
Glenn wrote: |
And i bet it cost less than a "correctly" rebuild 912 engine. |
I'm just reading this a year later, but I'm with the VW guys.
a 912 engine MIGHT have made 90 hp but it is a direct evolution of a 36 HP VW. And that means all the parts are dinky small. Overstressed a lot, the 356 SC engine lasted well in a 356 and less so in a 912 that was just a bit more load and heavier. MANY grenaded the cranks at about 100,000 km. 61k miles. One CAN get the 912 motor stronger with a modern Scat Crank and modern rods and LOT of other expense, but it is very hard to get more than about 120hp reliably.
A moderate, lightly stressed 1800-2000cc stroker motor is the way to go. Others can say what valve size and carbs/ injection to get good performance.
Another way would be a Subaru, IF you want to do the radiator thing, but that also will get you a full winter modern heater. and 140 UP horsepower. and a motor designed in the 1990's instead of 1960 of the type 1 motor. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
