Split Bus Luggage Platform Felt Strips
pvlocal
pvlocal is offline
PostPosted: Fri Jan 07, 2022 10:42 am    Post subject: Split Bus Luggage Platform Felt Strips Reply with quote
On the luggage platform of every bus I've owned there are a series of 3-inch-wide felt or horsehair strips glued into the wide channels pressed into the metal above the engine bay. These strips are usually covered by the woven luggage area mat.
(My last bus was a bay window, and it definitely had these felt strips. But my memory of earlier buses is a little hazy.)
My project is a 1966 Deluxe Bus, shown below. Did VW install these strips in split buses? Anyone know what those strips were made from? Is there a close-to-stock replacement for it? Apologies if this was addressed elsewhere, I could not find any reference to it. Thanks.
Clara Premium Member
Clara is offline
PostPosted: Fri Jan 07, 2022 10:49 am    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
they are sometimes called tar boards, or tar strips:
https://www.thesamba.com/vw/forum/viewtopic.php?t=320690&highlight=tar
https://www.thesamba.com/vw/forum/viewtopic.php?t=148902&highlight=tar
pvlocal
pvlocal is offline
PostPosted: Fri Jan 07, 2022 12:23 pm    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
Thank you, very helpful.
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jan 07, 2022 2:47 pm    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
Pretty sure the supplier to VW used coconut coir instead of horse hair. VW did use coconut coir for in the seat padding.
In Stereo, Where Available!
hitest
hitest is offline
PostPosted: Sat Jan 08, 2022 10:07 am    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
I believe it is the same material (and possibly thickness) used under the gas tanks in buses. I wonder if they're the same width? Think
FU#5
pvlocal
pvlocal is offline
PostPosted: Sun Jan 09, 2022 8:18 pm    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
Thanks for the feedback.
I found several sources of industrial and designer felt, black, pliable, one eighth of an inch thick, in lengths up to 70". Seems like an improved substitute for tar board. I'm going to order some and see how it looks on my project.
Link: https://thefeltstore.com/collections/thick-2mm-3mm...7223892045
andybla
andybla is offline
PostPosted: Mon Jan 10, 2022 3:28 am    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
So does it really help for sound deadening?
pvlocal
pvlocal is offline
PostPosted: Mon Jan 10, 2022 5:25 am    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
I guess that remains to be seen. Given that this was a feature of Deluxe buses, I’m tempted to say it was intended to create a more comfortable passenger environment by reducing engine noise in the cabin. Since it was hidden under the luggage-area carpet, its purpose doesn’t seem to be structural or cosmetic. Primitive sound-proofing seems the likely intent, and for that I think dense felt would serve nicely, and look good too.
PostPosted: Mon Jan 10, 2022 10:10 am    Post subject: Re: Split Bus Luggage Platform Felt Strips Reply with quote
Yes, although I believe more modern sound deadening products work better.
(I haven't tried that myself)
If you don't have a back seat installed, this makes a big difference too.
Whatever you use, it may be worth doubling up in the area hidden behind the back seat.
On my 23-Window a previous owner (or dealer?) installed a lot of padding behind the rear seat and it's quieter than other Buses I've owned.
I'm interested to know how solid and dense the felt material is above.
The original tar boards are pretty dense.
