white_one Samba Member
Joined: January 04, 2022 Posts: 115 Location: California
Posted: Sun Jan 01, 2023 3:28 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
Happy New Year!
Posted: Mon Mar 27, 2023 8:13 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
After several months away from the forum, I'm back at it.
The A-pillars in Nina were cracked since I got her. The driver's side was terrible, the passenger side was just beginning to crack. I looked and looked for replacements to no avail. It was mandatory the grab handles were maintained, so aftermarket reproductions were out. Finally, over xmas, several pairs appeared on eBay.
I didn't take a picture of the old ones in the van, but this gives a good idea of how cracked they were. These are the worst 2 cracks, but there were another 5 or so!
passenger side - It's cracking around the screw hole.
Looking at the used ones I bought, while much better than mine, they were still cracking. I did some reinforcement on the back, hoping to extend their life:
Driver side installed!
I missed taking a picture with the screw cover installed.
I'll do the passenger side next weekend, if the California deluge ever ends...
This has been a massive relief to have fixed. It was so annoying to see cracked trim everytime I got in. |
VanGeek Samba Member
Joined: September 25, 2022 Posts: 230 Location: New England
Posted: Tue Mar 28, 2023 3:41 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Nina looks great! Good approach for reinforcing the new pillars. |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2543 Location: Ocean Beach in Beautiful BLUE California
Posted: Tue Mar 28, 2023 8:15 am Post subject: Re: New to the family 2001 Eurovan Weekender |
So for the mechanically inept, that is drywall tape? Fiberglass tape? Covered with 5 minute epoxy? Something else?
Thanks,,, _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Tue Mar 28, 2023 10:55 am Post subject: Re: New to the family 2001 Eurovan Weekender |
OB Bus wrote: |
Thanks,,, |
The reinforcement is metal mesh and JB weld. I figure (hope!) the plastic will have a hard time cracking through the combination of reinforcement. |
Posted: Thu Apr 13, 2023 5:29 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
Quick pic of camping at Bodega Bay. This was the first camping trip of 2023!
Kevin_IN Samba Member
Posted: Tue Jul 11, 2023 3:57 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
white_one wrote: |
Time for stereo upgrade
I have this exact model of 2001 EV (as far as everything you've shown).
Seeing your dashboard reminded me: did you happen to find/see the flasher relay somewhere in there?
I can NOT find mine, and it recently died a slow death. It is NOT behind/built into my emergency triangle button, that is purely a switch in my van. It is nowhere to be found on the two banks of relays and fuses under the driver's side. (In fact no wiring diagram I have been able to find comes anywhere close to being correct for my van -- it may have had some rewiring under there.)
There's one unidentified relay up near the back of the radio, but it has four feet, and the replacement I bought only has three.
I don't mean to derail this thread, but it's the best long detailed thread on the same model of van that I've ever seen here, so I thought one of your readers might truly know the answer... _________________ 2001 Eurovan MV Weekender Pop-top (blue) |
Posted: Wed Jul 12, 2023 5:07 am Post subject: Re: New to the family 2001 Eurovan Weekender |
I also have a 2001 weekender and recently removed the flasher switch. My switch contained the integrated flasher relay -- yours should as well unless a PO modified the wiring.
See photos of my switch and other info here. https://www.thesamba.com/vw/forum/viewtopic.php?t=765790&highlight=flasher
Pls post a photo of your switch |
Posted: Mon Jul 31, 2023 9:17 am Post subject: Re: New to the family 2001 Eurovan Weekender |
I have not posted in a long time, and there is a good reason. Nina sleeps outside, and the winter was not kind to her.
Here is a picture from a distance. She looks pretty good.
However it you get closer, things are so goo. I had clear coat peeling all over the van.
On the rear hatch
The fiberglass top was not looking good
It has bugged me from day one that the black vinyl between the windows was in poor shape
Nina had been repainted under previous ownership and it was not well done. The rear hatch never matched the rest of the car. |
Posted: Mon Jul 31, 2023 9:19 am Post subject: Re: New to the family 2001 Eurovan Weekender |
I decided to have the damage repaired. I used a high volume facility I've used in the past. Things escalated quickly! Everything you see marked in green is getting worked on.
Posted: Mon Jul 31, 2023 9:26 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Here are some work in progress pictures.
Here you can see some preliminary sanding and filling of dents. Keep in mind that I had over 20 dents repaired by PDR when I purchased Nina. I knew there was some remaining damage, I did not know it was this much.
The top was sanded to to fiberglass and then covered in a polyester high fill primer
Posted: Mon Jul 31, 2023 9:27 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Here is Nina immediately after paint, prior to polish. Getting to this point took 7 weeks. There is a nationwide shortage on paint that delayed this project.
Posted: Mon Jul 31, 2023 9:29 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Here is Nina during the polish and reassembly phase. You will also see that she received fresh strips and black vinyl between the window.
Posted: Mon Jul 31, 2023 9:40 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Here are the results. These were taken in full sunlight by iPhone.
She received a new hood vent. It has been cracked since I got her.
I like this last photo, it shows the pearl and metallic in the color. Ignore the water drop!
Posted: Mon Jul 31, 2023 10:08 am Post subject: Re: New to the family 2001 Eurovan Weekender |
Wow! Looks $$$ but also looks great!
I have a little clearcoat peal on the drivers side area above the window although the basecoat still looks excellent. I've seen some good DIY 2K clearcoat repairs and mine is artic white so I think it can be done well as a DIY job. I may get to it this Fall.
I also have sun damage to the black vinyl inserts on the driver's side and have the materials to replace them. Gotta sort out how to remove the window trims...
Enjoy reading your posts and Nina looks great -- keep up the good work! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22681 Location: NYC/Upstate/ROW
Posted: Mon Jul 31, 2023 11:50 am Post subject: Re: New to the family 2001 Eurovan Weekender |
I was going to comment that the clearcoat and pop top cracking were nt serious…. But obviously one of us has standards that far exceed the other
It looks beautiful. My poor Colorado Red 2002 has lots of character marks that are a natural part of its beauty. _________________ .ssS! |
Posted: Mon Jul 31, 2023 12:57 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
It's an affliction I have. I was excited to buy a van I didn't need to baby, and then I let this happen. Oh well... it's still been a lot of fun! |
shirk Samba Member
Posted: Mon Jul 31, 2023 4:46 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
Looks great. |
Endopotential Samba Member
Joined: February 13, 2012 Posts: 186 Location: Pacifica, California
Posted: Mon Jul 31, 2023 8:31 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
Gorgeous paint job! Make sure you get a nice solid cover to protect that beauty.
I live around SF as well. Which shop did you use? |
Posted: Wed Aug 02, 2023 2:52 pm Post subject: Re: New to the family 2001 Eurovan Weekender |
Endopotential wrote: |
It was Calibre Collision on Hillcap in SJ.
My new license plate will make it easy to spot me. Say hi if you ever run into me!
