1968BlueBug Samba Member
Posted: Sun Jan 09, 2022 10:55 am Post subject: 1968 Bug will go into gear but wont move. HELP! |
My son popped the clutch, and now it won't go anywhere. It makes a banging noise when you push on the gas, and it won't drive. |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sun Jan 09, 2022 11:01 am Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
before pulling the engine to check for broken cloth/pressure plate, check for:
stripped drum splines.
broken axle
broken spider gears |
wheel607 Samba Member
Posted: Sun Jan 09, 2022 11:13 am Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
vwinnovator wrote: |
broken axle
I say broken spider gears. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20383 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jan 09, 2022 1:15 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
broken axle
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9776 Location: Oregon
Posted: Sun Jan 09, 2022 1:29 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
wheel607 wrote: |
broken axle
I've broken spider gears and managed to drive home. Very gently! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
cbeck Samba Member
Posted: Sun Jan 09, 2022 7:35 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
Ladt time I dumped my clutch, I broke both cv joints on the same side. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Sun Jan 09, 2022 7:40 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
cbeck wrote: |
Ladt time I dumped my clutch, I broke both cv joints on the same side. |
'68 should be a swingaxle trans |
SRP1 Samba Member
Posted: Sun Jan 09, 2022 8:08 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
[quote="vwinnovator"][quote="cbeck"]Ladt time I dumped my clutch, I broke both cv joints on the same side.[/quote] '68 should be a swingaxle trans[/quote]
Early 68, late 68 was IRS. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31386 Location: Hot Arizona
Posted: Sun Jan 09, 2022 9:03 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
stripped drum splines. |
A stripped rear drum spline on either side is easiest thing to check, and not too uncommon. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Posted: Mon Jan 10, 2022 10:23 am Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
I bet it is the throw out bearing holder. Or it could be some of the springs in the clutch the fell out. One reason to use the rigid clutch disc. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Jan 10, 2022 10:26 am Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
Maybe i should stop popping clutch in mine... Didnt think a little 1600 has that in it. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Mon Jan 10, 2022 10:38 am Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
gt1953 wrote: |
I bet it is the throw out bearing holder. Or it could be some of the springs in the clutch the fell out. One reason to use the rigid clutch disc. |
If the OP can shift into different gears and still no forward motion that it's not clutch related unless the "entire" pressure plate failed which is very unlikely! |
Cusser Samba Member
Posted: Mon Jan 10, 2022 1:44 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
1968BlueBug wrote: |
Time for son to fix it !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
slayer61 Samba Member
Posted: Mon Jan 10, 2022 1:50 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
Cusser wrote: |
Time for son to fix it !!! |
That right ^^^ there ^^^ is the best advice so far in this thread. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
toxicavenger70 Samba Member
Posted: Mon Jan 10, 2022 3:00 pm Post subject: Re: 1968 Bug will go into gear but wont move. HELP! |
You didn't do any work to the axles or trans recently? If so it could be slipped axles. |
