GB2S Samba Member
Posted: Sun Aug 30, 2015 7:02 pm Post subject: rear apron repair / replace |
O.K. to begin with I am a originality freak, so I have a problem. The rear apron on my 63 is pretty beat up. How difficult is it to remove, disassemble, repair it. Or should I replace it.
I have found a 64. Is this a correct replacement?
Geoff _________________ 1963 Ragtop |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Sun Aug 30, 2015 7:22 pm Post subject: |
If you have the tools and the know how it is not all that hard but those are some big things to have. For example. If I was to do it would take about 4 days to do it.
Day one - Remove parts around the area and mark the cut areas.
Day Two - Cut parts away and weld new parts on
Day three - Clean new are and paint it
Day four - Put parts back on after paint dries. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
grandpa pete Samba Member
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Mon Jan 10, 2022 8:33 am Post subject: Re: rear apron repair / replace |
ok guys, I need a new rear apron.
But... Im looking for a quality aftermarket unit. To me, the apron fitment and curvature is one of the most important pieces on whether a beetle looks like a quality build.
Ive been looking at the Auto craft rear aprons. But, there seems to be mixed results.
Who else makes quality aprons?
Im looking for the 64-66 style, although id be fine with an early, no exhaust exit apron as well.
how are these?
https://www2.cip1.com/c24-111-813-301/
thanks _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
downsbs1 Samba Member
Posted: Mon Jan 10, 2022 7:43 pm Post subject: Re: rear apron repair / replace |
yes, ive spent lots with WW.
whos makes that apron tho? BBT? _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
'66 RIP |
