Ghia Coupe Headliner - DIY
Craigbro
Craigbro is offline
PostPosted: Thu Feb 17, 2022 12:13 pm    Post subject: Ghia Coupe Headliner - DIY Reply with quote
After not finding a lot of information I've attempted to make a DIY headliner for my 64 coupe. I'll provide a short description and a few pictures just in case anyone else may be interested now or in the future.
I started with a 60x40 foam board from the local hobby store. I cut and fitted it a little large to catch the bow spring mounts and provide a natural bow to the top that extend past the lip all around.
Next I used a second foam board and cut it to fit right inside of the lip all around. this board was covered with modern headliner material adhered with 3M-90.
I used the 3M-90 at the edges and secured the headliner to the base board. Note that the headliner board was cut to fit snug so it has the same bow as the first board and top.
I then used carpet binding (Instabind) to provide a trim around the border and also the wrap over the frame between the headliner and rubber seals. I used a coat of contact cement to secure the binding.
A couple of tips:
- I initially used brown paper to get a rough shape and traced it on the foam board and trimmed as needed.
- the foam board can crease easily so work slowly and do not over bend it
- I only applied contact cement to the frame for the binding and let it dry. I tested it on the binding and it leaks through and discolors it.
kingkarmann
kingkarmann is offline
PostPosted: Thu Feb 17, 2022 12:21 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Thanks for sharing Cool
What did you use for the edging?
Craigbro
Craigbro is offline
PostPosted: Thu Feb 17, 2022 12:44 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
The edging is the Instabind. Its a binding used on carpets, rugs, etc. Its a non-sew product that I found when researching my next project...DIY carpet Very Happy
kingkarmann
PostPosted: Thu Feb 17, 2022 1:46 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Looks great!
I installed stock headliner. It's a PITA!
Your solution is a nice option.
Tom K.
Tom K. is offline
PostPosted: Thu Feb 17, 2022 2:07 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
I really like your approach here. My '65 currently has an ugly red interior that I plan to replace without emptying the bank. I've listed some questions below.
How thick was your foam board? Did you apply adhesive to this first foam board to stick to the ceiling of the car? Or was the curvature enough to hold it in place?
This second foam board is of the same thickness? Second board was glued to the first? Was the modern headliner material already cut to fit the Ghia? Or did your cut it yourself? And you adhered the headliner to the second foam before installing in the car?
"Base board" was the first foam board installed? I'm a little confused by the description of this step.
Thanks for clarifying!
'91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight=
Craigbro
Craigbro is offline
PostPosted: Thu Feb 17, 2022 2:41 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
The foam board is 3/16" (got it at Hobby Lobby) - Fyi the outer layers on the board at HL is much better than at office stores. Both boards were the same size.
I did not apply adhesive to the first board. It was wedged in place and the lip holds it in. It was really for a spacer. it is wedged tight to contour to the roof.
I also glued a few pieces in the corners (on top) of the headliner (2nd) board, between the two boards, to get it to fit flusher with the lip of the car.
When I installed the actual headliner board I used contact adhesive around the edges to adhere it to the first board. You could maybe glue the whole board, I was just worried that I might have problems lining it up if it "adhered" too well. Note, the actual headliner board fits inside of the car lip.
I bought bulk headliner material and cut/glued it to the foam board before installing.
Yes, "base board" is the first foam board installed, as a filler board basically.
Hope this helps, let me know if you have any more questions.
Rome
Rome is offline
PostPosted: Thu Feb 17, 2022 5:07 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Nice work.
I suppose one could use a large bulk sheet of original white vinyl headliner material with black polka-dots like the OG material instead of the modern headliner material.
Craigbro
Craigbro is offline
PostPosted: Thu Feb 17, 2022 5:44 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Rome wrote:
Nice work.
For sure, its pretty much a blank canvas. You can use anything that you can glue to it I suppose.
Tom K.
Tom K. is offline
PostPosted: Thu Feb 17, 2022 6:39 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Crystal clear, Craigbro. I'll be doing this. Thanks! I look forward to seeing your carpet ideas.
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Feb 18, 2022 4:07 am    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Thanks Craigbro, a very useful option, just added to the "How To" Stickies. Smile
John.
Tom K.
Tom K. is offline
PostPosted: Fri Feb 18, 2022 4:25 am    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Happen to know off hand where to source this vinyl headliner?
Rome
Rome is offline
PostPosted: Fri Feb 18, 2022 4:37 am    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Tom K, just before I submitted my response I made a quick search of that material. I checked the 2 biggest sources JBugs and Sewfine, was surprised that neither lists it in their usual catalogs/sites- they only have perforated. My concern with perforated vinyl is that the base material layer might show through, but then again if you look at an original old headliner which does have perforations, the holes are so small that you don't see anything inside. My next search was going to be with Porsche 356 headliner material.
gorbur
gorbur is offline
PostPosted: Fri Feb 18, 2022 8:38 am    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Awesome innovation Craigbro.
I did a similar process on the bug i just finished. I did mine in panels secured with velcro on the leading edge and a thin strip of pvc on the trailing edge (just to retain the alignment of the surfaces). No reason it couldn't be done this way on a Ghia.
The fabric was sourced at a local discount fabric shop. Took a bit of time to find a exterior black with 4 way stretch. 3M #90 sticks it to the close cell 9mm foam. Not evident is a patch of sound deadening material in the centre. Goes a long way to reduce noise.
73 - Ghia Cabriolet, currently under resto
76 - Type1, 1776, full restomod
Figment
Figment is offline
PostPosted: Fri Feb 18, 2022 1:15 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
wow that looks great.
I used a cheap material when I did my headliner a few years ago. Big mistake, I already want to redo it, and this method makes that prospect far more appealing!
'71 Ghia coupe
Craigbro
Craigbro is offline
PostPosted: Fri Feb 18, 2022 2:04 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Great job gorbur! Came out fantastic.
Tom K.
Tom K. is offline
PostPosted: Fri Feb 18, 2022 2:15 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
For sound deadening, did you use the stick-on stuff to reduce just metal vibration? Or some thick stuff to reduce air noise and other outside noises?
gorbur
gorbur is offline
PostPosted: Fri Feb 18, 2022 2:34 pm    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
In my case it was a bit of both. I used a square foot of Eastwood's equivalent to Dynamat dead centre of the roof (metal vibration). Its crazy how well just a small bit of it works. The 9mm foam / fabric my guess just absorbs any sound bouncing around the cabin.
kingkarmann
PostPosted: Sat Feb 19, 2022 8:30 am    Post subject: Re: Ghia Coupe Headliner - DIY Reply with quote
Very cool!
This is a nearly identical process used for headliners in modern cars.
