rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 419 Location: Ortonville, Minnesota
Posted: Mon Feb 21, 2022 9:50 pm Post subject: Short slicks for 150 HP? |
M&H Racemaster Drag Race Slicks
Tire, Drag Slick, 23.00 x 7.50-15
I'm building a bug truck with a 2180 and pro street rancho 3.88 transmission.... I'm hoping for 13s maybe break into the high-12s someday... compared to 26x6x15s. _________________ Like some other respectable members, "why buy what you can build" |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15326 Location: Deep in the 405
Posted: Mon Feb 21, 2022 10:28 pm Post subject: Re: Short slicks for 150 HP? |
Little more details on the 2180. It could have 120 HP or 180 HP.
What 3 & 4 gears are in the transaxle.
1/8 or 1/4 mile. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Feb 22, 2022 4:51 am Post subject: Re: Short slicks for 150 HP? |
Hey Rodger, seen ur project,cool, I use that same short slicks for the 1/8 mile strips _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Thu Apr 28, 2022 8:41 am Post subject: Re: Short slicks for 150 HP? |
Things are progressing nicely. I've ben compiling all my parts for my new motor....2180,42x37 vw 040 heads 38 cc, fk89, with valve pockets should be 11.5 compression. New china carbs came today 48 ida clones....$480 delivered...
Nightshift Samba Member
Posted: Thu Apr 28, 2022 9:19 am Post subject: Re: Short slicks for 150 HP? |
Hosier will work the best. Choose your compound carefully. |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
rodgersbadassbus64 wrote: |
SMALL ports for such large valves and cam...
your gonna choke that FK89 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu Apr 28, 2022 9:27 am Post subject: Re: Short slicks for 150 HP? |
they look... virgin _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Sat Sep 10, 2022 4:15 am Post subject: Re: Short slicks for 150 HP? |
short slicks in action ,800+ H.P. Hell Kitty Vs. Turbo Bug
1/8 mile Drags Bug did 7.8 @93 mph
Kitty did 9.00 @ 92 mph
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3304 Location: Rapid City, SD
Posted: Sat Sep 10, 2022 5:31 am Post subject: Re: Short slicks for 150 HP? |
Those head ports are bone stock with bigger valves stuck in. I say 115hp TOPS with those. Cut for thin 92’s also.
Ditch those heads quick. They will need lots of welding and serious port work to get anywhere near able to support an FK89.
Order some CB wedgeports with 44mm intakes. And get a set of 94mm cylinders. Then you will have a 2276cc, and much closer to the power you are hoping for. I would also drop the cam down a notch or two. Fk87/fk10/86c range.
With the wedgeports and a smaller cam, you should be closer to the 175ish HP range, and make more usable power to get you off the line harder.
Brian _________________ www.type-emotorsports.com |
raymon covey Samba Member
Posted: Sat Sep 10, 2022 6:07 am Post subject: Re: Short slicks for 150 HP? |
I had the same combination with good ported street eleminator. 1.58 3rd and 1.26 4th. 12.5 compression. 1.4 rockers. 40 mm vents. Best time 7.28 in 1.8 mile. 1915 CC FK89. I had a lot of fun with the little motor. |
rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Mon Sep 19, 2022 6:44 pm Post subject: Re: Short slicks for 150 HP? |
What is meant by “short” slicks _________________ CHEAP - FAST - RELIABLE
You can only pick two of the above. |
b-man Samba Member
Posted: Mon Sep 19, 2022 7:00 pm Post subject: Re: Short slicks for 150 HP? |
rrcade wrote: |
What is meant by “short” slicks |
Smaller in diameter than the usual 26” tall slicks used most often by racers.
Something 23” or 24” in diameter would qualify as a ‘short’ slick in this case.
It changes the effective gear ratio of the combo, depending on the transaxle gearing the shorter slicks may help on a shorter 1/8 mile track. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9828 Location: Oregon
rrcade wrote: |
Quote: |
Tire, Drag Slick, 23.00 x 7.50-15 |
From the Op's first post. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Wed Apr 05, 2023 10:46 am Post subject: Re: Short slicks for 150 HP? |
Progress on my build...
Purchased 26x7 slicks and centerlines..
Better heads 42x37 with some porting and longer type 4 valves with 650 springs
sig erson 1.5 rockers
Valve pockets Mahles forged.
Fk89 and I'll run as much compression as possible based on clearance with the valve pockets that I have.
Chinese 48 IDA'S
still hoping for 150 + HP...
So now back to a wish list question...
Current transmission is a fresh o mile rancho pro street 3:89 with.89 fourth.
So what 3/4 close ratio gears might I start looking for. My car weight is still in question...it will be what it will...
slayer61 Samba Member
Posted: Wed Apr 05, 2023 12:59 pm Post subject: Re: Short slicks for 150 HP? |
Sounds like you already have chosen rear end and 4th gear. 3.89:1 rear gear and 0.89:1 4th gear. Good freeway flyer combo. Not sure it's going to be a good drag race combo, though.
PS I really like your build. You have serious vision. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
Posted: Wed Apr 05, 2023 1:46 pm Post subject: Re: Short slicks for 150 HP? |
I'm looking for direction for a good 3 and 4 gear ratios using the tall slicks, 3:88 along with stock 1 and second gears...🤔 _________________ Like some other respectable members, "why buy what you can build" |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed Apr 05, 2023 2:56 pm Post subject: Re: Short slicks for 150 HP? |
Sorry I missed this post for so long....
Shorter slicks have an issue with contact patch. While you have a gearing advantage with a 23" tall tire, your contact patch will be very small.
The taller 26" tire lays down nicely at the hit and gets great traction for a relatively narrow (6") tire. Good find there...
Looks like you have some nice parts going on there, I'll be following progress. Glad to help as I'm a drag racer myself. Been down your exact path and help many others...
Heads look like they need some port cleanup work and chamber smoothing to be successful at higher rpms and work with your cam.
Typical gearing for a car like yours all things considered:
4. 125 R/P with Stock 3.78/2.06 mainshaft, 1.54 3rd and 1.21 4th. You'll want some tight gears to make a smaller size/big cammed drag motor work. Powerband with that cam is kinda narrow and peaky around 6,500rpm max tq. So the more you can keep the motor close to that rpm, the better. Typical gear spacing for light drag car puts 2nd, 3rd, and 4th very close together. The 1/2 drop is handled by clutch slip. The rest of the gear changes are only 1500rpm drop or less.
If the heads can flow, max rpm can be as high as 8,500rpm, but I don't think your heads will go there. (why I recommend port work).
If you need help with gearing, I'm here. I think I have a few close 3/4 gears in-stock. Glad to help a drag racer any way I can... So few of us left..
I'm on |
Bill Schwimmer Samba Member
Posted: Thu Apr 06, 2023 8:27 am Post subject: Re: Short slicks for 150 HP? |
If you have the stock Sig Erson shafts, they are not going to play well with the CB 650's and the rpm potential of the combination. Just trying to save some headache. |
Posted: Thu Jun 15, 2023 7:04 pm Post subject: Re: Short slicks for 150 HP? |
Newly acquired motor Hoping for 200 HP plus went with 26 inch slicks.... can't wait currently wiring car... _________________ Like some other respectable members, "why buy what you can build" |
Dauz Samba Member
Posted: Thu Jun 15, 2023 9:57 pm Post subject: Re: Short slicks for 150 HP? |
speaking of..
