r-mm Samba Member
Posted: Sat Mar 12, 2022 2:16 pm Post subject: Bosch AL82 teardown / rebuild info? |
| Hi all - before I do something wrong can anyone point me to a thread or diagram documenting how to tear down an AL82 for cleaning, bearing maintenance and so on? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26388 Location: Olympia Wash Rinse & Repeat
r-mm Samba Member
Posted: Sat Mar 12, 2022 9:37 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
| Got her all apart without much drama. Ordered new bearings, voltage regulator. Does anyone know if the brush assembly is available as a spare part? I can only find the brush assembly for the version with the voltage regulator as part of the assembly where as mine has it in the rear by the fan end. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6473 Location: 37.5N 77.1W
Posted: Tue Mar 15, 2022 6:50 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
| Quote: |
| brush assembly is available as a spare part |
There are places that sell rebuilt alternators on EBay. I sent one of them an email and they sold me the brush assembly. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
r-mm Samba Member
Posted: Tue Mar 15, 2022 7:15 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
| Do you have that seller's name? I presume you are talking about the brush assembly that does not have the voltage reg integral to it? |
Posted: Tue Mar 15, 2022 7:31 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
| r-mm wrote: |
Try this
https://www.ebay.com/itm/383065842672?_trkparms=is...BMytzp3_Ff _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
r-mm Samba Member
Posted: Sat Mar 19, 2022 12:31 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
Got her rebuilt with new bearings voltage regulator a bushing I turned up out of Delran for the battery post and a good cleaning. I am fairly certain there’s approximately 2.75 mm gap his correct base I’m looking at other photos but figured I might as well post to be sure
Posted: Sat Mar 19, 2022 2:18 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
I've never measured that. The 3 screws tight? It is what it is. How is the end and out of the armature? That's what's important.
Speaking of the armature, it looks like this one was clamped in a vise. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
r-mm Samba Member
Posted: Sat Mar 19, 2022 3:39 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
| Yes the previous owner had clamped it in a vise. I cleaned up some of the damage on the Lathe. Thanks for the eBay link that looks like the correct brush holder. |
r-mm Samba Member
Posted: Sat Mar 26, 2022 4:21 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
I am doing an alternator conversion to a 912 using Zim's kit. I'm at the point where the new rear hub they supply is installed on the alternator. I am confused as the hub makes contact with the case. The piece of paper demonstrates this. Surely this can't be the intention as that would be metal on metal contact. The woodruff key is in place and otherwise everything fits up nicely. Am I missing something?
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4155 Location: Seattle, WA
Posted: Sat Mar 26, 2022 6:42 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
You're missing the little spacer ring that goes on the shaft, seats on the bearing inner race, and protrudes a
little out the end. The fan hub seats on the spacer. _________________ '67 bug: seized by the authorities
r-mm Samba Member
Posted: Sun Mar 27, 2022 6:06 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
| Thanks. That spacer would be installed from the rear, correct? I suppose this wasnt included with the used alternator I Bought. Does anyone have a photo of it? |
Posted: Sun Mar 27, 2022 7:07 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
| r-mm wrote: |
Looks like the front one.
Never seen a backing cover like that before  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Sun Mar 27, 2022 7:16 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
they don't always come with the spacer and some get lost if not secured
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
r-mm Samba Member
Posted: Sun Mar 27, 2022 7:20 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
Thanks for the picture. Checking to make sure the piece missing is not this one, which I installed on the shaft as shown, so that its captive in the case. Is that correct and I am missing another spacer, one without a step on it?
Posted: Sun Mar 27, 2022 7:32 am Post subject: Re: Bosch AL82 teardown / rebuild info? |
You have the part in front of the rear bearing circled in red. You need part on the other side of the rear bearing.
r-mm Samba Member
Posted: Sun Mar 27, 2022 1:09 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
Thanks - I had that part sitting in a little box all along.
Does anyone know of a repro source for the front Pully hub for an early Porsche 350w generator? Part 53906201 |
zoti Samba Member
Joined: December 26, 2007 Posts: 2175 Location: Plano, TX USA
Posted: Wed Mar 15, 2023 4:09 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
| I know this post is a year old but do you have a list of parts that you used for the rebuild? Like bearings, rectifier etc? |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7580 Location: Houston, Texas
Posted: Thu Mar 16, 2023 12:04 pm Post subject: Re: Bosch AL82 teardown / rebuild info? |
Send me an email. I can provide you with a parts diagram along with a list of parts with part numbers. _________________ www.vwnos.com [email protected]
