mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
Posted: Wed Apr 20, 2022 10:58 am Post subject: Deck Height Calculation for CB Aluminum Raised Deck |
Ok - I am preparing for a 94/86 - 2387 in a CB White Rhino Aluminum Case over the summer. I was calculating the deck height to see which case to buy (which raised deck height). They come in 0, 3.5, 7 or 9.5 mm raised deck (if they ever get some back in stock).
So I am trying to calculate this properly so i need don't need shims or minimal shimming - maybe an experienced engine builder can correct me or verify. This 2387 would technically be my 4th engine build if you count the first bearing failure on an old 1500 case, second 1904, and third 1968.
An 86mm crank with 5.5 inch rods (139.7mm) and "B" 94mm pistons with a CB White Rhino Case with a 3.5mm raised deck would give me a final deck height of 0.452 mm or 0.017795 inches. this is without any shims or spacers. Is that too small? Might it cause valves to hit the cylinder? What is the target deck height for a 2387 given the info below?
(I derived this from some other peoples calculations I found - which is why I am not 100% sure it is correct). In theory I could bump up the rod length to 5.6 inches, and also bump up the case deck height from 3.5mm to 7mm. since 0.1 inches is 2.54 mm, but the case bumps out by 3.5 mm, this would adjust the 0.0178 deck height to be +0.96mm or +.0377 making it 0.055 inches, so I would require 0.04 worth of shims. I read that the 5.5 would be better at low RPM, and also seems to require no shims, so I was planning on going with that.
I just want to decide between the White Rhino case that is 0, 3.5, 7 or 9.5 raised deck, and if I want to use the shorter 5.5 inch rods, it "appears" that the 3.5mm raised deck is the correct one to get.
(I was considering an 84mm crank, but then thought why not go for it on the 86 so I have no regrets...)
Using the CB Performance Engine Calculator - I get:
Bore: 94
Stroke: 86
Deck: 0.0178
Chamber: 66cc
Compression: 9.6
Displacement: 2387 _________________ Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Posted: Wed Apr 20, 2022 1:01 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| UK Luke 72 wrote: |
17 thou is too little.
Based off that, get the 7mm mock it up and then have the cylinders trimmed to get 40 thou with no shims.
Then order your heads with enough chamber volume to get the CR required for your cam/fuel/elevation etc... |
ok.
I did see a bunch of posts where the setup resulted in unshimmed -.020 with 0.040 shim making the final deck height 0.02
so in an ideal world, what compression do I want in a 2387? 9.5?
and in an ideal world, what deck height for valve clearance etc...? 0.02 or 0.04? Ok - now I see several posts saying 0.04 minimum or 0.037 minimum. Sounds like I would need 0.02 worth of shims to get to 0.0377, assuming the 5.5 inch rods and 3.5 raised deck Rhino Case.
The heads I was looking at have a 66cc chamber, so that is pretty large, allowing for a small deck height, but I want to be sure I clear the valves, even if I go with 1.4 rocker arms...
So if I plug in those numbers with the 0.02 shims, compression goes down to 9.2.
Bore: 94
Stroke: 86
Deck: 0.0378
Chamber: 66cc
Compression: 9.2
Displacement: 2387
If I trim out 10cc of chamber but add 0.01 more deck height I get:
Bore: 94
Stroke: 86
Deck: 0.0478
Chamber: 56cc
Compression: 10.3
Displacement: 2387
The best seems like if I trim out 5cc of chamber and leave the deck at 0.0378:
Bore: 94
Stroke: 86
Deck: 0.0378
Chamber: 61cc
Compression: 9.8
sled Samba Member
Posted: Wed Apr 20, 2022 2:32 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
well, I appreciate the direction you're approaching this build from, but I think you're over complicating a few aspects of it.
this is for a bus right? if so, I highly doubt you're going to end up choosing a cam with enough lift you will run into valve/piston clearance issues. The size of the engine doesn't have anything to do with it, its purely valve lift and valve timing related to deck height.
as far as deck height goes, anything from .040 to .050 is generally the acceptable range (others are soon to chime in and say thats BS )
compression is entirely dependent on the cam chosen and the vehicle it will be installed in.
what "off the shelf heads" come with for chamber volume is somewhat arbitrary as you will most likely need to have the heads flycut for the proper chamber volume for YOUR engine combo. Look for heads with large chamber volumes to start with, that can be flycut down as necessary.
I think before you go making any decisions on heads or cam or compression, you need to think about what kind of performance you want out of this engine for your bus. Realistic ideas that is. And don't forget if you let this snowball and turn into some 180hp+ monster, you're going to need to upgrade other parts of the system. I know your trans builder said the trans would handle it, but a strong 2387 in a bus can, and probably will eat parts like crazy
also just another note...the difference between building with an 82 crank, or an 84, or an 86 isn't quiiiiiiite as easy as it sounds. _________________ drive your split. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4237 Location: Georgia
Posted: Wed Apr 20, 2022 2:58 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
Also, keep in mind the width of the engine.
You don’t want to have to modify the bay or the cooling tins.
I just built a 2276 so I can appreciate how you are trying to work out the deck to try to avoid a bunch of hassle.
And yes .040 is the minimum unless you’re one of those people that use copper gaskets between the cylinder and the head.
Don’t know if you’ve ever seen these. They’re definitely enjoyable and provide a lot of good information.
_________________ Volkswagen!
(Compression 8.7:1) |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Apr 20, 2022 3:54 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
This a nice reference chart I stole from another thread. It was not my work, but it's very helpful when mentally mocking up an engine build. |
Posted: Wed Apr 20, 2022 6:03 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| I think all of the 94's including Mahle all have the 35mm pin height now. But don't take my word on it. I'm sure someone here knows for sure, or contact the vendor before ordering. |
Joined: May 17, 2003 Posts: 4877 Location: Harmony, PA
Posted: Wed Apr 20, 2022 6:49 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
Not wanting to be a buzz kill on 4/20, but do you already have cases in your possession to choose from? The only Aluminum case listing that CB has in stock is a 9.5mm deck that is a standard 85.5 bore without the head studs drilled yet. When/if they get the others back in may be anyone’s guess. I would be tracking down some cut to length 94 cylinders, so you could use basically any case.
Here is something to consider from crank centerline to cylinder top on one side.
Crank stroke / 2 + rod length + compression height of the piston + deck height
A stock 1600 with .055 deck height
(69/2) + 137 + 39.6 + 1.4 = 212.5mm
2386 with a 5.5 rod, Mahle B 94, and .040 deck;
(86/2) + 139.7 + 35 + 1 = 218.7mm
That’s 6.2mm / .244 of a difference. I can’t remember the cylinder lengths off hand of a standard 85.5, and a common 94, but that will enter into it as well. |
Posted: Wed Apr 20, 2022 7:15 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| [email protected] wrote: |
There are none of the 3.5 mm White Rhinos (94) in stock, so I’ll have to wait. There are also no 7mm White Rhinos (94) either. But I could probably make either one of those work, as long as I get the rods/pistons/shims.
Hopefully they will have one in the next month or two. SCAT has an aluminum case but no raised deck.
I guess you mean that the block will be 6.2mm wider? I suppose push rods may need to be longer or other considerations, but since some people use 5.6 or 5.7 inch rods, it seems like with 5.5 I should be able to make it work… _________________ Here is my 1961 Beetle Restoration:
txoval Samba Member
Joined: January 23, 2004 Posts: 3916 Location: The Woodlands, TX
Posted: Wed Apr 20, 2022 7:19 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
I did the math in a similar thread and it got deleted…maybe it was the same poster
I’d by pistons with a 33mm pin height to help with width…they are available |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Wed Apr 20, 2022 7:20 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
43+139.7+35=217.7
103.5+114=217.5
so, .008" in the hole, probably?
it would be easier to check you math If you put it in the form of math.
modok Samba Member
Posted: Wed Apr 20, 2022 7:23 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| ACN |
modok Samba Member
Posted: Wed Apr 20, 2022 7:25 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| yes |
Posted: Wed Apr 20, 2022 7:45 pm Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
| mikelars wrote: |
I guess you mean that the block will be 6.2mm wider? I suppose push rods may need to be longer or other considerations, but since some people use 5.6 or 5.7 inch rods, it seems like with 5.5 I should be able to make it work… |
The 6.2mm is how much wider the engine will be from the crank/case center line to the top of the cylinder on one side of the engine. So the engine will be 12.4mm from cylinder top to cylinder top wider total than an average 1600 dual port.
Another thing to think about is compression ratio. You would need a 68 cc combustion chamber with a .040 deck to get you 9.0:1 static. |
txoval Samba Member
Posted: Thu Apr 21, 2022 3:48 am Post subject: Re: Deck Height Calculation for CB Aluminum Raised Deck |
CSP also sells a really nice set of 33mm pin height 94mm pistons
AA does as well, they are JE race pistons |
