HELP! hinge issues on 83 pickup fiberglass tonneau cover instal
Forum Index -> Water-cooled VW Share: Facebook Twitter
orange914
orange914 is offline
PostPosted: Thu May 05, 2022 12:48 pm    Post subject: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Im getting the 83 road ready. Been mostly in hibernation for over a decade.
Just had paint and am installing/trying to figure out the hinge setup on a rare fiberglass tonneau cover. I don't have any info on manufacture or model. It was from a parted pickup years ago and all I have is a box of hinge parts and questions.
I'm hoping there is someone here that may have one of these or know someone with one. Maybe I can get some pictures and/or information. Suggestions to retro fitting to a newer style tonneau hinge set up?
Inside forward passenger side. Pictures to come of other uninstalled hinge parts.
inside forward driver side
Butcher
Butcher is offline
PostPosted: Fri May 06, 2022 6:48 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
I'm certain you know, but it's got to be said. There is not a lot of strength in the sheet metal. I look forward to see how you accomplish this task
orange914
PostPosted: Fri May 06, 2022 9:23 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
True. Im going to lay out the pieces and take pictures. It was designed for and off a truck so...
internet search picture below
orange914
PostPosted: Thu May 12, 2022 7:49 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Finally got some pictures of this wacky hinge craziness. Makes little sense. The best I can figure from the above internet search picture is the "clock-spring" bolts to the top (short end on cover). And the pin slides in and out of the plate/bracket already attached to the underside of the tonneau cover.
Wait wuuuuut?
Butcher
Butcher is offline
PostPosted: Fri May 13, 2022 7:17 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
What about gas struts?
orange914
PostPosted: Fri May 13, 2022 8:12 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Absolutely my thoughts. I should have a $30 gas strut kit here from eBay soon.
After looking over this stone age "Rube Goldberg " catastrophe, my next venture is to find a workable hinge setup??
orange914
PostPosted: Thu May 19, 2022 5:25 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Surprised
2011 thru 18 Ford Fiesta hood hinges may be the answer
Butcher
Butcher is offline
PostPosted: Thu May 19, 2022 8:56 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
I have no idea how much your cover weighs but many new cars hoods are aluminum. Most hoods I lift [that have no struts] and light. Most likely much lighter than your cover.
I'm no engineer but I'm certain there is some calculation that would determine the force that would be needed to keep it cover up.
The hinges look promising.
orange914
PostPosted: Tue Jul 12, 2022 4:57 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
update
A little bit of in the vise pretesting to check operating clearances.
1st thing was to mount the hinge level. I ran two 3' wood rulers to use as reference points. The lower one represents the level bed rail surface plane. The top one showing angle and movement and representing the tonneau mounting surface
next I wanted to see how the rear of the mocked up tonneau would react to the hinge geometry. How close and where would the forward/front end of the cover go? How close to the front of the bed should the hinge be? How deep, long etc... would my hinge mounting bracket have to be?
By opening the hinge we checked where the tail of the cover would be no lower than it was in a closed position. We marked that intersection point.
following by measuring out the "mocked covers" line (plane) @ 5.5' away from the marked intersection (to the rear of the cap). The tail sat @ the actual installed height of 6'.
The perfect angle of 30 degrees accomplished 6 foot total lift height @ the tail or opening end of the cover. The point where the cover front lip would contact the bed left 2" of non interference room in between the bed and cover lip.
The next is the strut mounting points. Will these struts be long enough or too short? Should I mount them bottom to the front or rear of the truck?
To be continued. Same bat time. Same bat channel
orange914
PostPosted: Fri Jul 22, 2022 9:21 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
I measured and calculated everything I could figure may help zero in the actual hinge location. My biggest concern is that the hinge geometry will bind the overhanging rear lip as the lid is raised.
First was to mount the hinge in the vise to map the geometry. I taped a straight edge (wood ruler) on the hinge top mounting surface. Then a fixed straight edge was to represent the fixed level surface.
As the hinge ran through its opening swing it showed how the rear portion of the cover would act from the hinge action (this is where the binding concern would be). The gap actually lifted and increased slightly as the "cover" rose. The first part of the arc the two plains gap increased slightly to then come back together and eventually cross. There didn't appear to be much forward movement until apx. half way thru full opening. Using the rear interference as a limiting factor, the open angle was brought to just under 30 degree. The intersection was the limiting factor, several inches back. This is where the approximate location of the edge/end of the cover would be. A 30 degree opening would roughly put the 5'6" cover @ just under 6' open height when opened.
I'm building a card board mock up as seen below, to test a bit more before using metal. I hope to get it close enough for just minor adjustments once the attaching mounts are done. It will us a 13" x 4" x 1/8" flat bar (creating a flat mounting surface) with an 8" long 3"x3" square tube (bringing the hinges inboard to match the tonneau hinge mount surface)
orange914
PostPosted: Tue Jul 26, 2022 10:39 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
o.k., I've got some more mock ups done. I'm confirming various hinge location measurements. MOSTLY the mock up proving out operation in 1/8" steel. The pictures show (more to come) the 3" hinge mount tubing is an intermittent spacer. The square tubing is needed to space the hinges to match the gap between the covers flat premolded/steel reinforced hinge mount area. The 4" x 12" x1/8" flat bar is the truck bed plate attaching to the 3" square tube mounting surface which in turn the hinge mounts to.
The below mock up represents the tonneau cover and hinge interaction. On the far left is an angle bracket representing the cover lip. The brown cardboard represents the edge that the lip must clear.
Through the hinge geometry the test shows the overhanging rear lip ACTUALLY moves up and clears the lower raised area (0 thru 10 degrees of lift/movement). Then after being fully cleared of interference, the cover continued increasing gap while edging forward slightly.
1 Next step finish drilling/building hinge mounts
2 temporarily mount and test/adjust
0 DEGREES closed position
5 DEGREES
10 DEGREES
15 DEGREES
30 DEGREES full lift position
orange914
PostPosted: Fri Aug 05, 2022 2:53 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
It's a new experience dealing with the atruts. Sometimes I just have to just jump in and go with my instinctive choice. In my learning curve I purchased a set with mounting brackets and designed for a compact car hood. Thru more research I discovered different compressed and extended length and lift strength from 30 to 130 lbs per strut.. although rhe original sets compression travel just made the range needed on the mockup calculations, it was more obvious that they were iway too punny . I think my next choice will be very close. They are 20 inch extended 11 inch compressed and lifting 100 lbs per strut. This doubles the length of travel over the original set giving me a bigger mounting adjustable range.to increas/decrease lift, depending on the top mounting location.
orange914
PostPosted: Sun Aug 21, 2022 11:59 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
A little more progress in 1/8x3" plate & tubeing
orange914
PostPosted: Tue Aug 30, 2022 4:11 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Pipe sectioned from 3"x3" to 3"x2.5" with corner notched to fif bed curvature. A million measurements later, cutting and welding, everything miraculously fit within very tight parameters. Mached-up hood + hinges + brackets. Overall width (bed mount to mount 52 3/4") and height (tonneau flush shut seating surface) pre adjustment specs proved out to literally be right on the money, first shot. That's never happened for me before!
Next will be the hood fore and after measurements
Latching/Locking handle install
20 total nutserts to keep struts and hinges secure and give full adjustability. Then confirmation of extended and compressed strut lengths set within specs
Closed position with mounting brackets installed to check settings
Upward hood liftaway (upward and forward action) confirmation @ 30 degree this calculated out to raise the lid to 6 foot. I can change the strut settings for more or less lift
Hood flush setting on the money in the closed. The foam strip is where it sits on the bed top rail position.
Butcher
Butcher is offline
PostPosted: Wed Aug 31, 2022 8:05 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Nice work. It is frustrating making all the mods and measurements but for some reason, when it works right the first time, it seems to give you a satisfaction that is hard to beat.
orange914
PostPosted: Wed Aug 31, 2022 4:35 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Yeah, was going great, ha. I was going to attempt to mount the brackets to the bed today but the truck didn't want to start. First time ever. It usually will fire 1st time, everytime, even if sitting for months. Then I remembered I had the tank out not to long ago to flush and check the condition. Had it boiled out, sealed (100% rust free)... I'm pretty sure it's got an air pocket that needs bleeding. We'll see.
orange914
PostPosted: Sun Dec 04, 2022 2:53 pm    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Finished!
Butcher
Butcher is offline
PostPosted: Mon Dec 05, 2022 9:41 am    Post subject: Re: HELP! hinge issues on 83 pickup fiberglass tonneau cover instal Reply with quote
Nice!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
