Variable Compression Ratio Connecting Rod
Chickensoup
Chickensoup is offline
PostPosted: Fri May 13, 2022 5:44 am    Post subject: Variable Compression Ratio Connecting Rod Reply with quote
Me wants Shocked Imagine the possibilities! Hopefully china copies this concept and makes an affordable aftermarket. Maybe even some numatic valve train as well.
It would probably be a pain in the booty hole to fit that giant end cap in large stroke dubs but i dont think it really matters at that point. especially in a t4 application.
And then imagine the possibilities in boosted engines! high compression before the boost kicks in, then just keep lowering CR as RPM goes up.
'65 Tourist Delivery Build
'66 RIP
nsracing
nsracing is offline
PostPosted: Fri May 13, 2022 7:52 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
Im sure it is very good for a locomotive. Laughing It has no place in a race engine or street for that matter.
That is a lot of weight to lug around for so little benefit.
You want really high compression - get a diesel. Very Happy
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Fri May 13, 2022 8:07 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
Infinity was first to market with a VCE in 2019 with the QX50.
Dan Ruddock
Dan Ruddock is offline
PostPosted: Fri May 13, 2022 8:31 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
The VCE benefits are mostly in turbo apps. The rod above looks too fragile for my tastes.
Chickensoup
PostPosted: Fri May 13, 2022 8:34 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
Who says I cant drive a train? Slap some mickies on it and i should be ready to go Wink
Aluminum?
already got one Shocked Cool
'66 RIP
Chickensoup
PostPosted: Fri May 13, 2022 8:39 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
The shape does scare me as well, but!... They use these rods in 7+ liter 4 cylinders. It is also supposed to help with secondary balance issues found in I4's. Not sure if that applies to H4's.
Is this the infinity rod? Shocked Wow thats a lot to take in Laughing [/youtube]
'66 RIP
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri May 13, 2022 11:17 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
Saab came out with a VCE in 2000-ish that the cylinders were attached to the head, but they floated in the block. The cylinder head was raised & lowered to alter the CR.
This design was killed when GM took over.
https://en.m.wikipedia.org/wiki/Saab_Variable_Compression_engine
VWFIXER
Banned
VWFIXER is offline
PostPosted: Fri May 13, 2022 11:28 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
I was kinda wondering who had ever started a 6 volt bug with 30 wt oil in freezing weather this morning, idkw.
The rod ideas have been better accomplished in automotive applications by VVTi
While my parents may have walked through a blizzard to get to school, I had an Omen experience every day, between viscous black Rottweilers and black birds every day.
( ) Cheap
( ) Fast
( ) Reliable
Choose 2
Over a million air cooled miles driven and 15,000+ cars serviced.
jimmyhoffa
jimmyhoffa is offline
PostPosted: Fri May 13, 2022 11:35 am    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
I designed and implemented the National Instruments EFI system that currently runs the Waukesha CFR engine in the basement of the Missouri S&T Mechanical Engineering hall. The serial tag shows a 1937 production date. It was variable compression the same way SAAB did it! I thought it was pretty slick.
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
KEGZ
KEGZ is offline
PostPosted: Fri May 13, 2022 12:55 pm    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
yeah, most people here are still trying to get their a/f ratio and timing correct.
modok
modok is offline
PostPosted: Fri May 13, 2022 4:51 pm    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
My favorite is the opposed piston engine.
Altering the timing between the two crankshafts allows variable compression.
VWFIXER
Banned
VWFIXER is offline
PostPosted: Fri May 13, 2022 5:03 pm    Post subject: Re: Variable Compression Ratio Connecting Rod Reply with quote
There’s a sweet spot between wankle and turbine just wanting to make ufos. Using ions to spin the apparatus in a vacuum. Oops I just bogarted that one. Laughing
( ) Cheap
( ) Fast
( ) Reliable
Choose 2
