AlexandMary Samba Member
Posted: Sun Jul 03, 2022 9:08 am Post subject: 95 Camper - How to read engine codes using blinking? |
Guys, help me out. I have an engine light but can't read the code, stupid OBD1.
I have this black and white 2x2 plugs where the fuses are. I also have the adaptor cable that I can connect to them, but how do I force the ECU to blink codes?
Thank you. |
Skitter Samba Member
Posted: Mon Jul 04, 2022 1:02 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
http://www.a2resource.com/electrical/codes/digifant1.html
Here’s a link to access the codes with a paper clip. Click on the codes link and it’lll give you even more codes you can look up. |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Thu Jul 07, 2022 6:17 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
Thanks for the input.. Question.,my 93 was changed from a auto to a five speed and it has no wires under the boot..any tips where to access the brown & black wires/connection?? |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Fri Jul 08, 2022 7:33 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
@Skitter, Thanks for posting this. I learn new things everyday.
@volkybus, T4 has the connectors at the fuse box location to the left of your knees in the driver seat. |
KillerGriller Samba Member
Joined: June 15, 2022 Posts: 52 Location: Ontario, Canada
Posted: Fri Jul 08, 2022 9:09 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
Cheers! |
Posted: Sat Aug 06, 2022 6:57 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
Thank you all,
I finally was able to read the codes, so happy! Using the blinking method provided from member.
My codes was "O2 sensor control exceeded" I'm going to replace the O2 sensor and see how this will help.
Stay tuned! |
Posted: Sat Aug 06, 2022 12:30 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
I would also check your vacuum lines for any leaks or disconnections. I think I had the same code message as you did 2341 / O2 exceeded limits and it turned out to be a leaking vacuum line between the cylinder head and t-line thtat eventually goes to the ECU. Note the 2341 code does state it could be a intake leak somewhere. My vacuum line was brittle and cracking everywhere which is probably the condition of all our EV vacuum lines. No harm getting a new O2 sensor tho. |
Posted: Sat Aug 06, 2022 2:48 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
Skitter wrote: |
Thank you for the your vacuum tip. I should get me a vacuum gauge. But, you are correct, it di mentioned about vacuum leak. |
bcolins Samba Member
Joined: December 04, 2020 Posts: 734 Location: Austin, TX
Posted: Mon Nov 27, 2023 12:35 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
I just did this on my 95 EVC that I have been getting a CEL on. When I jumped the white and black connectors at the top and front of the fuse panel, I got no flashing CEL,...but, when I removed the paper clip, I started seeing flashing. I got four sets of four flashes followed by one single flash.
The Digifant page referenced here says that 4444 means that no fault was recorded,.....so,....can anyone tell me what might be going on?
Brian in Austin |
bjanaszek Samba Member
Joined: December 29, 2011 Posts: 30 Location: United States
Posted: Thu Nov 30, 2023 8:41 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
bcolins wrote: |
Brian in Austin |
Is your CEL on when the engine is off, but the key is in the "On" position? I have a periodic CEL in my 95 that I wasn't really able to chase down until I bought a VCDS unit. _________________ 1995 EVC - 5 cylinder manual |
Posted: Thu Nov 30, 2023 1:08 pm Post subject: Re: 95 Camper How to read engine codes Using Blinking |
bjanaszek wrote: |
bcolins wrote: |
Brian in Austin |
Is your CEL on when the engine is off, but the key is in the "On" position? I have a periodic CEL in my 95 that I wasn't really able to chase down until I bought a VCDS unit. |
Something like this? https://www.ebay.com/itm/354777407433?chn=ps&_...MgEALw_wcB |
Posted: Mon Mar 25, 2024 7:52 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
bjanaszek wrote: |
bcolins wrote: |
Brian in Austin |
Can you tell me which VCDS unit you bought and where you found it? |
Posted: Mon Mar 25, 2024 11:06 am Post subject: Re: 95 Camper How to read engine codes Using Blinking |
bcolins wrote: |
I have a Ross-Tech unit, with the OBDI adapter. There are other OBDI units out there, but they tend to be at least as expensive as the Ross-Tech unit + adapter. I also own another VW (2012 Golf TDI), so owning the Ross-Tech unit is doubly helpful. _________________ 1995 EVC - 5 cylinder manual |
