58ragman Samba Member
Joined: September 29, 2014 Posts: 404 Location: OC to ontario
Posted: Fri Jul 15, 2022 1:25 am Post subject: oil cooler how much torque to install properly |
Im installing a new doghouse oil cooler its got the step seals.
My question is how tight do i tighten the oil cooler to the adapter , till the seals start to bulge.
I can tighten it till it almost bottoms out.
Book claims 60 lbs per inch.
does that also spec out for the adapter to case torque
Thanks in advance |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79896 Location: Sneaking up behind you
Posted: Fri Jul 15, 2022 3:52 am Post subject: Re: oil cooler how much torque to install properly |
5 ft-lbs.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3386 Location: Hamble, Hampshire, UK
Posted: Fri Jul 15, 2022 12:38 pm Post subject: Re: oil cooler how much torque to install properly |
Somewhere on the Samba there is an good picture showing all the permutations of oil coolers, washers and standoffs. Some of them are tightened down onto washers, with others the standoffs of the cooler define the limit.
The squash of the seals is usually limited by metal to metal contact around the studs. _________________ Ancient vehicles and vessels
Notchman65 Samba Member
Posted: Fri Jul 15, 2022 3:52 pm Post subject: Re: oil cooler how much torque to install properly |
mikedjames wrote: |
Somewhere on the Samba there is an good picture showing all the permutations of oil coolers, washers and standoffs. |
That would make a great sticky. Possibly even saving someone from making a costly mistake. |
Glenn  Mr. 010
Posted: Fri Jul 15, 2022 4:40 pm Post subject: Re: oil cooler how much torque to install properly |
Member #1009
#BlueSquare
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4527 Location: viroqua wi.
Posted: Fri Jul 15, 2022 5:38 pm Post subject: Re: oil cooler how much torque to install properly |
60 lbs per inch may be the same as 60 inch pounds but it sure thru me. 5 foot pounds or 60 inch pounds. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
