kdnguyen61 Samba Member
Joined: June 14, 2019 Posts: 109 Location: Houston, Texas
Posted: Fri Jul 15, 2022 3:06 pm Post subject: 1972 Ghia IRS Plate |
Dear Members,
From the picture below, how can I take off the CV plate mounted on the side of the IRS transmission? I searched on internet but couldn't find instructions or video. Also what would be the name of that CV plate so I can buy online for a new one?
Thank you.
Starbucket Samba Member
Posted: Fri Jul 15, 2022 3:18 pm Post subject: Re: 1972 Ghia IRS Plate |
VW IRS Transmision side cover just google it about $75 on Ebay. |
Posted: Fri Jul 15, 2022 3:48 pm Post subject: Re: 1972 Ghia IRS Plate |
Of course after I sent out the post, I found the video on youtube.
https://www.youtube.com/watch?v=xN_l0w7sHxs
Thanks for where to buy the plate on eBay. I will also go ahead and buy the drive flange plug, may be new C clip and seal.
Do the new seal flush all the way in? is there any step I need to watch out for? |
Joined: August 31, 2013 Posts: 13303 Location: North Carolina
Posted: Fri Jul 15, 2022 3:55 pm Post subject: Re: 1972 Ghia IRS Plate |
Judging by the broken bolts, I think you are referring to the output flange or CV flange (thus the “flange seal”)
You might want to try a local VW shop to see if they have a core transmission laying around. CV flanges are available new, but most of them are for converting to larger CVs. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jul 15, 2022 3:57 pm Post subject: Re: 1972 Ghia IRS Plate |
Nothing special, just install the seal until it bottoms and lube the lip with a smear of grease and polish the CV flange with 400 W/D where the seal rides if there is a groove worn in. |
