Motomazzo Samba Member
Posted: Tue Jun 16, 2009 6:18 am Post subject: EMPI VS. CB Disc Brake Conversion Kits |
Hey Guys,
I feel sure this has been discussed to death, but I just haven't had much luck searching the forum.
I am about to purchase disc brakes kits...front and rear. Assuming cost is not an issue, which kit is better? And I only mention CB as a VS. to EMPI becuase that's about the only other brand of kit I've heard mentioned on here. But please mention any other kits that you think are the best, or on the contrary, kits to stay away from at all cost. Although I'm not too worried about cost, both kits WILL be a lot of money and I'm not in the habit of throwing money away!!
FYI - I am rebuilding a 66', B/J front end and I will be getting the kit with the 2.5" lowered spindles.
Thank you so much for your input!! |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Tue Jun 16, 2009 7:07 am Post subject: |
I've got the CB front kit. Aside from having to grind .010 off one of the calipers to get it not to rub on the rotor, it went on as it was supposed to and works well. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3899 Location: Eastern WA
Posted: Tue Jun 16, 2009 8:45 am Post subject: EMPI VS. CB Disc Brake Conversion Kits |
Empi or CB, CB without question! I have CB on both ends since 2001, still have the OG pads.
If money is no object, I would go Airkewled on both ends, or CSP on the front if you don't want 4 wheel disc. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
john7 Samba Member
Joined: August 06, 2003 Posts: 1563 Location: Garden grove ca
Posted: Tue Jun 16, 2009 10:10 am Post subject: |
go CB way better kit and much lighter _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Posted: Tue Jun 16, 2009 10:38 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
| Quote: |
| If money is no object, I would go Airkewled on both ends, or CSP on the front if you don't want 4 wheel disc. |
I guess I should clarify. I did not mean to imply that I have unlimited funds. I have seen the Wilwood stuff and others in that category. I'd like to stay in the "working-man's" category, if you know what I mean.  |
Posted: Tue Jun 16, 2009 10:43 am Post subject: |
Okay so....
EMPI = 0
CB = 3
Keep em' coming!!! |
ronbdavis Samba Member
Joined: January 27, 2009 Posts: 62 Location: Virginia
Posted: Tue Jun 16, 2009 11:31 am Post subject: |
| How about AC Industries kits, which claim they don't push the front wheels out the ~.25" that other kits do? |
Hotrodvw Samba Member
Posted: Tue Jun 16, 2009 1:47 pm Post subject: |
The question was between CB or Empi.
I run CB's wide 5 kit all the way around.....They work well. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Tue Jun 16, 2009 2:32 pm Post subject: |
EMPI = 0
CB = 4
Anyone out there bought/running EMPI disc brake kits?? What did you think?? |
dubkrzy Samba Member
Joined: July 02, 2006 Posts: 485 Location: One step behind
Posted: Tue Jun 16, 2009 3:28 pm Post subject: |
I have the CB kit.
Works great and went on easy. _________________
| vwracerdave wrote: |
| always modify the cheapest part and never modify the most expensive part. |
| Glenn wrote: |
| Sure... you can take a grinder to them. You can also use an adjustable wrench to assemble it. |
| Jake Raby wrote: |
| That looks like Tom Jones |
JamnJM Samba Member
Joined: February 08, 2005 Posts: 2165 Location: Green Valley, AZ
Posted: Tue Jun 16, 2009 8:00 pm Post subject: |
AC / So Cal imports or CB Perf.
Support the original thinkers and not the copy katters!  _________________ Werksberg Products....Products that work!
Follow my Facebook page "Werks Berg"
Click the below ADs link for products & feedback.
Please remember to buy "American made products!" Like my own products |
hoghead5150 Samba Member
Posted: Wed Jun 17, 2009 9:26 pm Post subject: |
okay, i've ran both the empi and cb kits in the past. i will say this (let the flaming begin) i had NO problems with either one. both worked well. i did have a wheel bearing go out on the empi kit about a year or so after installation. but i can't blame the kit, i had the front end apart 3 days before and i could have messed up reinstalling the bearings.
i personally would run either the cb kit or the ac industries if money was not an issue. only reason for this is piece of mind. MOST empi stuff has problems, and brakes is one place you DON"T want problems. _________________ "i got a friend that knows a guy who's best friend has an uncle that used to have a bug just like yours!"
i measured once, cut it three times, and the damn thing is STILL to short! |
Posted: Thu Jun 18, 2009 5:52 am Post subject: |
Wow!! Great answer. Thanx Hoghead. Really good information. Unless things change dramatically (more people chime in about EMPI), I guess I will not be buying them. Can't argue with the numbers:
CB - 7
EMPI -1
I guess it's true that maybe people just didn't buy the EMPI and give them a fair shot. But here you are the first to say you have run them and you had an issue, albeit hard to blame on the kit. But you didn't have any bearing problems with your CB kit. Hmmmm........
Who else?? Any EMPI out there?? |
atye Samba Member
Joined: September 02, 2004 Posts: 580 Location: Peachtree City, GA
Posted: Thu Jun 18, 2009 7:56 am Post subject: |
I'm running the EMPI wide-5 kit on my car (with a '72 pan). I drive this car 20k miles/yr or so, it's my daily driver and weekend road trip machine. I have had this kit on my car for about 2yrs now, still on the original pads, and have had no problems at all. It was very easy to install and one thing that hasn't been mentioned yet, as far as I know, the EMPI kit is about the only zero offset front disc conversion out there. (I am also running the CB 2½" dropped spindles along with this kit, even though it is not suppossed to work.)
Regardless of what disc brake kit that you buy, even it is a swap for stock Ghia discs, this is one of the best things you can do to your car, hands down. There is no adjusting, no loss of brakes on rainy days, no fading problems and the stopping power is a huge increase over drums. _________________ Alex
1990 Audi 90q 20v sedan
1998 Suzuki Sport Sidekick
2002 Suzuki Grand Vitara
2005 Subaru Legacy GT wagon 5spd Turbo AWD |
Posted: Thu Jun 18, 2009 3:04 pm Post subject: |
| Good info Atye. Hey....just another quick question. Is it really necessary to run an aftermarket master cylinder for 4-wheel disc brakes? I have read some advertisements that say it is. Others don't mention it. Likewise, one local VW shop around here says I need to purchase one and the other (who does far more custom work instead of just selling parts) says it has been their experience that an aftermarket master cylinder of larger capacity is not needed. Sound off. What do you guys think? |
Posted: Thu Jun 18, 2009 3:11 pm Post subject: |
No, run a stock '67 dual circuit m/c. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Thu Jun 18, 2009 4:19 pm Post subject: |
i always ran a stock d/c master cylinder _________________ "i got a friend that knows a guy who's best friend has an uncle that used to have a bug just like yours!"
akokarski Samba Member
Posted: Thu Jun 18, 2009 5:10 pm Post subject: |
I've been running CB wide5 on the front, yes it's linkpin and dropped spindles.
Went on w/o any problem, but I did have to replace bearings. They are china, wore out before even 1st normal repacking interval. Could've been alignment issue or the fact that I drove the crap out of them in the mountains.
You can always change out bearings to something like Timkens which are made in France and Poland and can be obtained through most local bearing places.
I would as well stay away from empi, especially with something like brakes those guys are hit and miss, mostly miss.
Anton |
Teeroy  Samba Member
Posted: Thu Jun 18, 2009 7:47 pm Post subject: EMPI VS. CB Disc Brake Conversion Kits |
I used a modified (Oldspeed) bus master (single circut) with a 2lb residule valve (CB Performance) in the rear circut. _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Thu Jun 18, 2009 9:03 pm Post subject: |
Why would you intentionally use a single circuit master cylinder? _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
