113 501 331A cv joint
el_safari
el_safari is offline
PostPosted: Sat Aug 20, 2022 2:28 pm    Post subject: 113 501 331A cv joint Reply with quote
Hi
Somebody know if the 113 501 331A cv joint fit our Thing?
I can't find which application this part number is for.
Thanks
La terre n'est qu'un seul pays
Joe 20
Joe 20 is offline
PostPosted: Sat Aug 20, 2022 7:34 pm    Post subject: Re: 113 501 331A cv joint Reply with quote
CV Joint, IRS Type 1 and 3, GERMAN, 113-501-331 are usually GKN/Lobro brand CV Joints.
These joints are for Beetle, Superbeetle, Ghia, and Type 3s.These CV Joints are capable of 12 degrees max angle.
The VW THING (Type 181s) uses a Type 2 (Bus) CV Joint, which is a higher-angle joint, it is is capable of 17 degrees of angle. The next CV Joint in line is the Type 4 CV Joint, which is Type 2 and THING Size, but is capable of a 5 more degrees of angle for a whopping 22 degrees of angle! And then the hard core guys use the Porsche 930 CV Joints, which is bigger again for even more power handling, and it handles a 25 degree angle!
This info is from Aircooled.net Hope it helps you.
"Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy
Al Capulco
Al Capulco is offline
PostPosted: Sat Aug 20, 2022 11:57 pm    Post subject: Re: 113 501 331A cv joint Reply with quote
U.S. delivered VW Things came from the factory with the Type 4 CV joint part number 113 501 331 D.
el_safari
PostPosted: Sun Aug 21, 2022 4:16 am    Post subject: Re: 113 501 331A cv joint Reply with quote
Thank you!
OK 113 501 331 D is for the thing but 113 501 331 A?...
FJBLF
FJBLF is offline
PostPosted: Sun Aug 21, 2022 3:05 pm    Post subject: Re: 113 501 331A cv joint Reply with quote
el_safari wrote:
Thank you!
For a 181 you need the "D" the "A" is for the Bug which requiers a less steep angle as explained earlier.
I just double checked the parts manual, and it calls for the "D" for ALL 181's with CVJ
1972 VW 181 SAFARI 1500 cc GRB Trans-axle
Wildthings
Wildthings is offline
PostPosted: Wed Aug 24, 2022 11:39 pm    Post subject: Re: 113 501 331A cv joint Reply with quote
There is no interchangeability between a Beetle CV joint and a Thing joint as they mate to different size flanges. That a VW part number has the same 9 digits but a different suffix in no way implies the parts are even similar in appearance or size.
