69bluebugboi Samba Member
Joined: August 23, 2022 Posts: 10 Location: Orange county
Posted: Mon Oct 10, 2022 8:05 pm Post subject: Offset distributor points |
So initially I figured out that my distributor points were touching since the car didn't want to start. Went ahead and adjusted them and boom turned on perfectly, and ran for the rest of the afternoon with no issue (ran some errands for like an hour and then came back home).
I decided to head out again about 2 hours later and the car started okay but I noticed some small loss in power (very small) after only driving for about 3 minutes. I've been down this road (not literally 😂) before so I knew I'd rather pull over than get stranded on the street so I ended up making it into a shopping center and the car barely made it and it turned off on me as I was parking.
Looked at the points again and I saw that it was a small amount too close (error on my part? Didn't tighten the screw tight enough? Possible) so I adjusted again and I noticed the two points weren't aligned. Again the car started perfectly and then I still felt the car wasn't running too well since I noticed the loss of power a bit again and again when accelerating (any gear, lower and higher speeds).
My adjustments were:
- find TDC
-remove dizzy cap and rotor
- ensured I was in fact at the highest point of the cam lobe
- used a .4mm feeler gauge to set the gap and had slight resistance
- tightened screw
-noticed the offset
TLDR, noticed my points are not aligned, is this normal?
I'm new to the VW world so I don't know too much, go easy on me 😂, tia!
Using leverage on the arm to align the points:
As they are with the screw already tightened:
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7587 Location: Houston, Texas
Posted: Mon Oct 10, 2022 8:24 pm Post subject: Re: Offset distributor points |
I've heard of this happening but it is rare. It could be the points, the breaker plate, or the screw holding it down.
When screwing in the screw that holds the points you want to tighten it down but not so much that it strips out the plate that is inside.
If you remove the points and look at the bottom side does it look like it is flat? _________________ www.vwnos.com [email protected]
Posted: Mon Oct 10, 2022 9:15 pm Post subject: Re: Offset distributor points |
So I took the points off and noticed the issue was still present as they were still offset.
I did notice a small gap on the lower left of the arm.
Should this have an E-clip or a washer? That's the only thing that I can think of.
Adjusting the arm manually so that the points align causes that gap to disappear. Thoughts?
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Oct 10, 2022 9:34 pm Post subject: Re: Offset distributor points |
| You want to adjust them so the contacts line up, and close flat. Odd they seemed to bend on their own. Maybe lack of lubrication on the cam? It looks completely dry. |
Posted: Mon Oct 10, 2022 9:44 pm Post subject: Re: Offset distributor points |
@Pruneman99 Dry cam...Possibly.... I can confirm that the cam is not lubed at all so I can see it potentially causing this (any brand recommendations on cam lube? or will something like "Permatex Dielectric Tune-Up Grease" work?).
I know these points are pretty cheap but I'm OCD about these types of things I wanna be prepared in the future since I wanna see if this is something expected or if this is something out of the blue |
Posted: Mon Oct 10, 2022 10:26 pm Post subject: Re: Offset distributor points |
I use Bosch distributor grease. I ordered it from Heimlich (vwnos.com) He actually commented above.
I've also used super lube? I think it's called. Horrible Freight carries it.
You want a grease that won't be flung everywhere. Just a dab will do. Anything is better than completely dry. |
Posted: Mon Oct 10, 2022 10:29 pm Post subject: Re: Offset distributor points |
@Pruneman99
ok will do.
Question, if I change out these points for the same drop-in replacement, do I need to buy a new condenser as well or can the same one remain? |
Posted: Mon Oct 10, 2022 10:37 pm Post subject: Re: Offset distributor points |
| 69bluebugboi wrote: |
@Pruneman99
ok will do.
You can use the same condenser. |
Nicholas D Samba Member
Joined: November 06, 2012 Posts: 272 Location: Charleston, SC
Posted: Tue Oct 11, 2022 4:36 am Post subject: Re: Offset distributor points |
If it were me I would just replace the points and throw the old set in the "just in case of emergency" bin in the bug. I think they are around $15 at cip1. Definitely lube the cam too. _________________ 71 Westfalia
73 Beetle |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Tue Oct 11, 2022 6:03 am Post subject: Re: Offset distributor points |
I would get new Bosch points and condenser from heimlich at vwnos.com. _________________ Repeat after me "I am smarter than metal!" |
Joined: August 31, 2013 Posts: 13366 Location: North Carolina
Posted: Tue Oct 11, 2022 6:07 am Post subject: Re: Offset distributor points |
It looks like the pivot pin is bent, probably during manufacture. This leads to the downward angle of the arm, dry cam lobes were not the cause of this. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36457 Location: Conejo Valley, CA
Posted: Tue Oct 11, 2022 8:15 am Post subject: Re: Offset distributor points |
X2. Unless the camera introduced some optical distortion, that pivot is cracked.
Keep your old parts as spares. New condensors do not seem to last. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80683 Location: Sneaking up behind you
Posted: Tue Oct 11, 2022 8:20 am Post subject: Re: Offset distributor points |
Personally I like the older style 2 piece points but all aluminum models use the 1 piece.
I use needle nose pliers to "gently" adjust the arm so the points make full contact and are parallel.
Remember, cars don't have distributors or points so making quality parts is not a high priority.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33587 Location: Hot Arizona
Posted: Tue Oct 11, 2022 8:54 am Post subject: Re: Offset distributor points |
When I worked at a dune buggy/VW rental business back in the 1970s, I found a bunch of distributors in the vehicles that had ZERO lubrication on the distributor cams, so the plastic rubbing blocks were wearing down quickly and the points gap was decreasing. I'm postulating that this is the issue here.
I made several road service calls where customers' buggies had stalled out due to this and I had to re-set points and add grease to the cam, and then check/reset the timing.
I still have a vintage tube of Bosch distributor grease, a tube lasts forever. But I also haven't had issues using a little wheel bearing grease there. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KTPhil  Samba Member
Posted: Tue Oct 11, 2022 9:04 am Post subject: Re: Offset distributor points |
| Cusser wrote: |
| I still have a vintage tube of Bosch distributor grease, a tube lasts forever. But I also haven't had issues using a little wheel bearing grease there. |
I have the original tube (yellow) from the mid-'70s. Fearing it was getting hard to find, I bought newer (white) tube. This is the 225ml size, not the little 45 ml size (which will last you many years).
I'm still only half way through my old tube. And at one point I had five active VWs!
I am thinking my grandkids can fight over it. Or THEIR grandkids. Lifetime supply in one tube! |
heimlich  VWNOS.com
Glenn  Mr. 010
Posted: Tue Oct 11, 2022 9:55 am Post subject: Re: Offset distributor points |
| KTPhil wrote: |
| Cusser wrote: |
I must be older than dirt
Member #1009
#BlueSquare
69aircooled Samba Member
Joined: August 04, 2004 Posts: 263 Location: North Carolina
Posted: Tue Oct 11, 2022 10:03 am Post subject: Re: Offset distributor points |
Not old, you just care about the work you do and doing things right! |
Cusser Samba Member
Glenn  Mr. 010
Posted: Tue Oct 11, 2022 1:28 pm Post subject: Re: Offset distributor points |
| Cusser wrote: |
| Glenn wrote: |
I must be older than dirt  |
No, but your distributor grease tubes are.... |
Nope... I have plenty of fresh tubes.
Member #1009
#BlueSquare
