Bring out your dead - Kman 71 vert build
Page: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
kman
kman is offline
PostPosted: Wed Oct 09, 2013 8:09 am    Post subject: Bring out your dead - Kman 71 vert build Reply with quote
I've had this 71 Vert sitting around for 7 or 8 years. I came to the conclusion a few years ago that it was a lost cause, but circumstances lately have found me with more time than money. That means fixing what's there, only replacing what is absolutely necessary, and making what I can.
So far so good. At least I have the tools to make it happen. I am going to get a lot of practice in metalforming. I should be an expert by the time I'm done.
KGCoupe
KGCoupe is offline
PostPosted: Wed Oct 09, 2013 8:37 am    Post subject: Reply with quote
Looks great so far!
Keep up the good work.
Disc
Disc is offline
PostPosted: Wed Oct 09, 2013 9:14 am    Post subject: Reply with quote
Nice start!
The glory never gets old, just need new paint.
Nick
kman
kman is offline
PostPosted: Wed Oct 09, 2013 9:24 am    Post subject: Reply with quote
It can only get better. I pieced together different floorpans until I had metal all the way around. Made me wish I had the $400 for new ones. I fixed up and put adjusters on a used beam. The one from this car was a gonner.
Altema
Altema is offline
PostPosted: Wed Oct 09, 2013 9:44 am    Post subject: Reply with quote
Wow, that looks scary. And I fret about the little spot behind my headlight that needs cutting out....
tisius
tisius is offline
PostPosted: Thu Oct 10, 2013 9:03 am    Post subject: Reply with quote
that shit will buff out Twisted Evil
nice work on the pan and running gear, keep it up.
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
kman
kman is offline
PostPosted: Thu Oct 17, 2013 5:32 pm    Post subject: Reply with quote
Put on a brake reservoir and filled it. Brakes work. Mounted transmission and put in a new plastic clip on the shift rod. Goes into all gears. Replacing heat adjustment cables. Repacked axles and gave good boots. Mocking up engine and mounted. Going to test its condition and then fix up all its pieces.
Backstory- This was an autostick but I never got the transmission or engine for it. Many parts of this build are off a manual coupe which was just as rusty but didn't have a title. What it did have was a working tranny and engine. So this car it being built with the best off of both cars and new bits as needed.
Hopefully I can drive the chassis around when I can get back to it in a couple of weeks.
kman
kman is offline
PostPosted: Fri Oct 25, 2013 7:49 am    Post subject: Reply with quote
I wired it up to start yesterday and installed a seat and steering wheel. The good news: I got it to start and run enough to back it out. The bad news is that it seems to be only running on two cylinders at the moment.
I will probably have to move on to some serious bodywork before I sort this engine out. I will likely have to rebuild it. It's pretty gummy inside. I'm not the best with engines so this will be a challenge.
I was hoping for the best but expecting the worst. I got something in the middle.
KGCoupe
KGCoupe is offline
PostPosted: Sat Oct 26, 2013 9:06 am    Post subject: Reply with quote
You're not alone.
My marriage worked out about the same as well.
Altema
Altema is offline
PostPosted: Sat Oct 26, 2013 9:24 am    Post subject: Reply with quote
I guess we're opposites; body work scares me, but engine work is almost second nature. How far away from Novi Michigan are you? If not too far, I'd be glad to take a look at the externals and see how your compression and valves are...
If not, then I'd recommend an oil change, valve adjustment, ignition check, and compression check.
Paul
Altema
Altema is offline
PostPosted: Sat Oct 26, 2013 9:25 am    Post subject: Reply with quote
KGCoupe wrote:
You're not alone.
Ouch, ouch, ouch! Laughing
kman
kman is offline
PostPosted: Sun Oct 27, 2013 1:48 am    Post subject: Reply with quote
Paul
Thanks for the offer. I can do some of the basics. I'll mess around a little bit next week and report. I'm just 44 miles away from Novi according to google maps. Chelsea.
kman
kman is offline
PostPosted: Tue Nov 26, 2013 9:56 am    Post subject: Reply with quote
I am testing a second engine that may be in better shape. It has an alternator instead of a generator. Do I have to buy the external voltage regulator below that goes with the alternator or can I use the old one that goes with the generator for testing purposes. I am unable to get spark.
http://www.rockauto.com/catalog/moreinfo.php?pk=937028&cc=1284207
c21darrel
c21darrel is offline
PostPosted: Tue Nov 26, 2013 12:04 pm    Post subject: Reply with quote
Some alternators have internal regulators, one below is internal. The older ones are external, not sure if the reg is the same.
http://www.thesamba.com/vw/classifieds/detail.php?id=843290
kman
kman is offline
PostPosted: Tue Nov 26, 2013 1:12 pm    Post subject: Reply with quote
Yes. I have the alternator that is external. I need to know if I can use the external regulator that worked for the generator for the alternator also. I'm guessing not as voltmeter readings aren't looking good.
c21darrel
PostPosted: Tue Nov 26, 2013 3:14 pm    Post subject: Reply with quote
They are different. Dont use the generator reg. I just learned why it is desireable to get the internally regulated alternator...ouch.
I payed less for my Bosch L82X Alt. Maybe a less expensive regulator out there...i dint know.
http://www2.cip1.com/ProductDetails.asp?ProductCode=BOS%2D0%2D190%2D600%2D017
kman
kman is offline
PostPosted: Sat Nov 30, 2013 9:24 pm    Post subject: Reply with quote
It always looks worse before it gets better.
kman
kman is offline
PostPosted: Tue Dec 24, 2013 7:29 am    Post subject: Reply with quote
Removing paint and doing some body work. I wasn't able to sandblast underneath before it got cold and wet, so I'm going to work around that and blast it later.
Relief cuts to help the decklid fit better
Some front end metal work. I plan on eliminating the 71 square turn signals and put in 69 bullet turn signals that I have. Don't hate.
Making Parts. A little more time spent on the parts you see. A LOT more of this to do.
kman
kman is offline
PostPosted: Tue Dec 24, 2013 1:05 pm    Post subject: Reply with quote
Making more parts. I decided it made more sense to go from the outside in so I can make sure everything fits as I go.
You can see I have a lot to go by.
Some of the process toward a finished part (NO, it's not done yet)
kiwighia68
kiwighia68 is offline
PostPosted: Tue Dec 24, 2013 1:36 pm    Post subject: Reply with quote
kman wrote:
Making more parts. I decided it made more sense to go from the outside in so I can make sure everything fits as I go."
You're doing great work, mate. Keep going and have a merry Christmas and a happy Ghia New Year. I'm learning from you, so keep the posts coming. I agree with you on the corner flasher lights. They look much better in the old style.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Page 1 of 10
