05gh Samba Member
Joined: September 01, 2011 Posts: 157 Location: The Netherlands
Posted: Tue Nov 29, 2022 3:08 pm Post subject: swap axle and RGB from a 181/thing gearbox to a split bus |
Will a RGB box/axle from a 181/thing fit on a split bus? do they have the same with? _________________ 63 doubble door panel van
79 de luxe micro bus
Be the change that you wish to see in the world. |
el_safari Samba Member
Joined: January 01, 2005 Posts: 375 Location: Nouvelle Aquitaine,France
Posted: Thu Dec 01, 2022 5:28 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
yes and yes _________________ La terre n'est qu'un seul pays |
05gh Samba Member
Posted: Sat Dec 03, 2022 2:11 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
el_safari wrote: |
yes and yes |
Thanks _________________ 63 doubble door panel van
05gh Samba Member
Posted: Wed Dec 07, 2022 4:12 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
comparing bug nut traany (H-code) with a Thing/181 tranny (AK-code) it looks that they have the same dimension. The advantage is thatthe tranny has a ratio 3.875 and the RGB 1:26
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Wed Dec 07, 2022 5:42 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
What 4th gear though? |
05gh Samba Member
Posted: Wed Dec 07, 2022 12:57 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
buseric wrote: |
The transmission code is AK and the ring pinion is 3.875. The 4th gear ratio i guess .82 but I could not find any information to confirm that. _________________ 63 doubble door panel van
thomas. Samba Member
Joined: July 31, 2010 Posts: 1293 Location: South West (Pa.)
Posted: Fri Dec 09, 2022 8:12 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
That surprises me. I always thought the things were equipped with full independent rear suspension. With 2 CV joints per axle like the beetle. The USA only got them in '73 & '74 .The swing axles must have been on older models that this is referring. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Dec 09, 2022 8:40 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
thomas. wrote: |
that is correct. german 181 came with RGBs _________________ regards
Uli
perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Sat Dec 10, 2022 9:27 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
mandraks wrote: |
thomas. wrote: |
that is correct. german 181 came with RGBs |
not all of them, right? mine is a german 74 and has CV joints. RGB's on 181 came on 69..probably 70? They are rare... _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Sat Dec 10, 2022 2:02 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
not all of them but they did come with RGBs at first. In the US they never did. _________________ regards
Uli
Posted: Sun Dec 11, 2022 2:35 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
05gh wrote: |
buseric wrote: |
The transmission code is AK and the ring pinion is 3.875. The 4th gear ratio i guess .82 but I could not find any information to confirm that. |
That is right 4th gear ratio is 0,82, I have the official VW repair manuel.
181's with RGB's from september1969 till 28/2/1973 civilian and military. _________________ La terre n'est qu'un seul pays |
storm Samba Member
Joined: April 28, 2008 Posts: 299 Location: Juneau, Wisconsin
Posted: Mon Dec 12, 2022 5:47 pm Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
That’s tall gearing. I have a similar setup with a 82x88 thick wall engine with lots of low in torque. You will need that or a stock engine will over heat. _________________ always ready to learn and give advice |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Thu Dec 15, 2022 12:11 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
they fit, but careful that often they have also ZF limited slip diff, and some of them reguire special oil, and that they have smaller brakes, |
Posted: Thu Dec 15, 2022 5:07 am Post subject: Re: swap axle and RGB from a 181/thing gearbox to a split bus |
storm wrote: |
That’s tall gearing. I have a similar setup with a 82x88 thick wall engine with lots of low in torque. You will need that or a stock engine will over heat. |
Agree. I ran this exact ratio combination with stock 15" wheels and tires. I had a 74x88 stroker with dual IDFs. I wouldn't want to run it with much less power especially if you live near hills/mountains |
