MikeyM73 Samba Member
Joined: December 06, 2016 Posts: 506 Location: Napa Valley, CA
Posted: Thu Dec 01, 2022 4:33 pm Post subject: Question on dash vents - the long, skinny, ones |
Hey all,
Going through the heater cables and replacing them. The defroster vents (on top of the dash within the same piece - the round and oblong) I can feel hot air blowing through them but what are the long skinny vents closest to the front windows for? I would think defrost, as well, but I never feel anything coming out of them.
Also, when am I supposed to feel warm air coming out of the foot vents? I would think about 1/2 way down on the lever, right? My heat distribution cable is a little short so I'm hoping that once I get the new cables in, I'll be able to adjust everything so I can feel hot air coming from everywhere!
Thanks,
Mikey _________________ '73 Pop-top Westy, found sitting in a field for 10+ years, cleaned up, rebuilt furniture, reloved. Original 1.7 block/fully polished crank, 93mm 1.8L balanced AA pistons & cylinders, new 1.8L balanced rods, HAM 42/36 heads, Scat C25 cam & lubalobe lifters, Dual HPMX40s, R2C filters w/ Outerwears pre-filters, functioning thermostat & flaps, Pertronix Flamethrower III, 4-1 exhaust w/ Cherry Bomb 2" turbo muffler & OEM heater boxes, averages about 19-22ish on the highway. |
SGKent Samba Member
Posted: Thu Dec 01, 2022 6:02 pm Post subject: Re: Question on dash vents - the long, skinny, ones |
will this help? https://www.thesamba.com/vw/archives/manuals/73bus.php _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51169 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 01, 2022 6:07 pm Post subject: Re: Question on dash vents - the long, skinny, ones |
The skinny ones at the outer edges are cold fresh air, move the blue lever down while in motion to activate them. They do sort of work as defoggers, but since it's cold air fighting with the warm stuff coming from the center vents it's debateable if they really improve things, YMMV.
The lever position for the foot vents depends on many factors, cable adjustment is a good place to start: https://www.thesamba.com/vw/forum/viewtopic.php?t=646866&highlight=heat+cable+adjustment _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
