Rustybettle68$ Samba Member
Posted: Mon Dec 22, 2025 8:33 pm Post subject: Torsion Arms |
Have two questions about these torsion arms. The one pitted is it damaged beyond repair? Seems the major pitting is between the bearing and sleeve area. Second is the one with the end cap popped off. Is there a way to repair this? Are both of these issues a waste of my time? If so should I replace all four of them and who to purchase from? Thank you for any help.
Schepp Samba Member
Posted: Mon Dec 22, 2025 9:02 pm Post subject: Re: Torsion Arms |
They don’t look bad to me. What’s important is the bearing areas. I don’t see any pitting or wear marks in that area. How to the bearings look? That is most important too.
I see nothing wrong those parts. The cap you should be able to tap back on. You can stake it to prevent it from falling out again. _________________ Bandit #19
1972 Baja Rallycross Bug |
Posted: Mon Dec 22, 2025 9:38 pm Post subject: Re: Torsion Arms |
| Schepp wrote: |
I see nothing wrong those parts. The cap you should be able to tap back on. You can stake it to prevent it from falling out again. |
Bearings don’t look to far gone. But I am replacing them with rebuild of front beam. So just wire wheel, light emery cloth, and some rust converter for the pitting? I’d only like to have to do this once for right now and hopes it will all last a couple of years |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11501 Location: Huntington Beach, CA
Posted: Mon Dec 22, 2025 11:47 pm Post subject: Re: Torsion Arms |
Those look good to me, too! Spray some Ospho on them for the rust. Then get them greased up so they cannot get wet again! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
74 Thing Samba Member
Posted: Tue Dec 23, 2025 12:45 am Post subject: Re: Torsion Arms |
| I forgot if it was a sliver dollar or half dollar piece that can replace the end cap. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3390 Location: Memphis
Posted: Tue Dec 23, 2025 4:49 am Post subject: Re: Torsion Arms |
Id be iffy on that inner bearing surface, it doesn’t look great. Really and truly though with the amount of use VWs get, it probably won’t amount to a hill of beans,.. would just wear the inner bearing/bushing faster.
Another way to say it: If you have other options, explore those first, but if you absolutely cannot find a deal on some cleaner trailing arms, just stick those in and keep an eye out for any weird tire wear. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1939 Location: Warren, PA
Posted: Tue Dec 23, 2025 5:55 am Post subject: Re: Torsion Arms |
Where are you located, even here in the rust belt I could find a better set. But check the classifieds here they shouldn’t be too much. They made millions of these things. My opinion is get a better set, you already have them apart _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2208 Location: Wichita, KS
Posted: Tue Dec 23, 2025 5:56 am Post subject: Re: Torsion Arms |
| Rustybettle68$ wrote: |
I had this issue on one of my old torsion arms several years ago, and ended up filing down and installing a metal cap used to plug knockout holes in home electrical boxes. More details and pics in this old thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8398890 _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6468 Location: 37.5N 77.1W
Posted: Tue Dec 23, 2025 9:29 am Post subject: Re: Torsion Arms |
swap arms to the other side. The arms wear more on one side of the bearing surface than the other. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
empi3 Samba Member
Joined: October 03, 2015 Posts: 386 Location: SW Wyoming
Posted: Tue Dec 23, 2025 10:24 am Post subject: Re: Torsion Arms |
| runamoc wrote: |
| swap arms to the other side. The arms wear more on one side of the bearing surface than the other. |
Dang I always thought they were position specific
Steven
Reconditioned arms....there are probably other places too
https://wolfgangint.com/search?controller=search&s=torsion+arms _________________ The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle
1968 Ghia |
