1982 2.0 ABA swap blowing blinker fuse
rooncicle
rooncicle is offline
PostPosted: Mon Jan 13, 2020 5:26 pm    Post subject: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
New to the forum, so I apologize if there are other threads that discuss/solve this. Also not electrically savvy.
I purchased an '82 in early October that the previous owner had swapped in a 2.0 ABA from a 97 Golf. The PO seemed to know what he was doing, so I'm going to chalk this up to my bad luck with old cars (just ask my '74 BMW).
After a couple of days of having it, the van stalled on me at ~40 mph. I traced the issue back to a blown fuse and after popping in a new one, I was good to go. The PO was surprised because this had never happened to him after all the years of ownership. Fast forward to a couple days ago, I blew the same fuse while getting onto the freeway.
In addition to the fuse blowing, over the past couple weeks the cold idle became progressively more rough, even stalling when shifting from 2nd to neutral. Once warmed up, it wasn't as noticeable - maybe the slightest shudder.
The cat was removed during the swap so the post cat O2 sensor doesn't really do anything, but I've seen in other threads mention of a faulty O2 sensor causing shorts. Not sure if that would still be the case with all the emissions parts removed.
The pump seems to be properly grounded to the frame. I ran through each fuse to see what they corresponded to and found that the fuse being blown is for the blinkers. Again, forgive me for my lack of electrical knowledge, but what's weird to me is that when the 8amp fuse blows, the whole van dies, but pull the fuel pump's 25 amp and the blinkers still work.
Hopefully this is enough information to go off of.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Jan 13, 2020 7:09 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
What number (position) stock fuse is blowing?
Did the PO wire in a new (25 amp) fuse for the fuel pump and possibly another
fuse for the ABA engine management?
If you remove the blinkers fuse that is blowing does the engine still start?
Im familiar with the OBD 1 (one o2 sensor) ABA swap but would suggest
that a missing pre or post o2 sensor shouldn't by itself cause a stall.
The rough running and outright stall at speed could be related or not.
The stock fuse blowing could be due to separate unrelated reasons. Or....
Theory: if someone intended to connect the [edit fuse or fuses for the] ABA
swap engine management
and vanagon fuel pump to an open spade connector on the supply side of
a stock 8 amp fuse but instead connected it to an open spade on the load
side, this might be the issue.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
MarkWard
MarkWard is offline
PostPosted: Tue Jan 14, 2020 7:09 am    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
A slow blowing fuse would indicate not a short, but too much load. When adding accessories or engine conversions it’s common to add on to existing bat power and key on power leads. Your going to need to search it out. The PO if they did the conversion would be your resource.
On my conversion I added a power relay in the engine compartment to take all the load off the ignition switch. The switch just operates the relay now. For someone familiar with the VW wiring diagrams could quickly pinpoint what the problem is.
The 82 had the ceramic fuse type box and did not have fuses larger than 16 amps. The fuse box is not rated for higher amp draws. Good news it’s a much simpler design to understand.
rooncicle
PostPosted: Thu Jan 16, 2020 4:55 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
Here's how I understand the wiring to be organized.
The fuse that blows is #12, an 8 amp fuse. The fuel pump is #13 and is 16 amp (not 25 amp like I said earlier).
If I remove the blinkers fuse, the van will crank but won't the fuel pump isn't running.
rooncicle
PostPosted: Thu Jan 16, 2020 5:03 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
I'm taking it to Peninsula Auto at the end of the month. They are totally packed with Vanagons right now - I guess people are getting ready for the camping season. When I told the guy on the phone that I had an ABA conversion, he immediately told me about the swap that Dave (I think) did on his Syncro, so it sounds like working on swaps is no biggie for this shop.
rooncicle
PostPosted: Thu Jan 16, 2020 5:06 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
The PO has been pretty responsive and helpful with problems I've ran into, but I don't want to wear out my welcome, so to speak. Anyway, when you buy these old cars, it's on you to get to know it and how to fix it, right? I just wish I had a mentor. Any volunteers? Very Happy
dkoesyncro
dkoesyncro is offline
PostPosted: Thu Jan 16, 2020 6:19 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
At this point you've decided to farm it out, I've had my share of ABA and have recently made another ABA management re-do. I can't figure what the PO may have done, although I've seen cases where the fuse block is bad and causing weirdness? Have you dropped the fuse/relay panel and checked the in/outs
I'd like to help but I'm stumped here!
Vanagon Nut
PostPosted: Thu Jan 16, 2020 8:30 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
Ok so with fuse 12 removed, the starter turns the engine but the engine won't "catch" or fire at all?
When you turn key to ignition on but don't try to start the engine, does the fuel pump go on briefly then turn off? It should.
The Bentley manual for this engine shows how to bypass the fuel pump relay. If you do that, you can test for sure if pump runs with or without fuse 12 installed.
Along with Markwards comments, the stock Vanagon fuses shouldn't be involved with the conversion. I'm not saying the PO used stock fuses to power the ABA stuff though.
When doing the conversion, one should install new fuses for things like the fuel pump circuit along with a new source or sources of positive power for the engine management. ECU, fuel injectors, fuel pump relay etc.
Neil.
(VW Gas I4)
VE7TBN
rooncicle
PostPosted: Sun Dec 25, 2022 3:39 pm    Post subject: Re: 1982 2.0 ABA swap blowing blinker fuse Reply with quote
The fuse panel got completely torched around 6 months after this post. There was a short in the heater circuit that caused the panel to melt which allowed two fuses to touch. It couldve been catastrophic, but luckily the van didn’t burn down.
Found a mechanic that rewired the front electrical with new relays and a more modern fuse panel. Good to go for the most part. There’s still a short causing a fuse to blow, but it’s isolated on its own circuit and doesn’t cause a failure of anything else. Funally able to hunt down the culprit.
Neil.
