sidemarkers Samba Member
Posted: Sat Jul 15, 2023 3:06 pm Post subject: Re: ICON VW pistons |
Maybe a reverse dome (dish) version for the turbo guys wanting a tight quench? |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2081 Location: Gardnerville, NV
Posted: Mon Jul 17, 2023 8:49 am Post subject: Re: ICON VW pistons |
I wish I could give everyone a piston that would do all, slay all the dragons, win all the races, etc.
oh wait... we have a custom department .. we can do that too!
There is no sarcasm in my statement above. We can build customs along the lines of the normal ICON piston but it does cost significantly more money and you are looking at a order minimum of 8 pistons.
as far as a production piston that would have those options... that gets difficult. making a piston that you could put .100 -.150 dish in the crown require more material , which means more weight.... sure I could make pistons with a certain cc dish in the crown, but I would need some sort of consensus on what is the ideal volume. Head cc, deck height and rod length vary so much in VW building , and everyone has a setup they seem to prefer.. some folks like stock length rods while others like to go with the longest rod they can get their hands on with a super short compression height piston. this is in comparison to most other engines builds that dont have 7,8, 9 different strokes available , and 4 different rod lengths.
Long story short. I can build you whatever you want... how much do you want to spend? _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Tue Jul 18, 2023 2:57 pm Post subject: Re: ICON VW pistons |
Your wish is your command, we can do this.
Just need about a 10cc reverse dome to bring a tight quenched 55 cc chamber 2276 safely under 9:1 for turbo antics.
I can test them out, if it helps the cause
In 4032 those icon pistons would likely sell like hotcakes |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3302 Location: Rapid City, SD
Posted: Tue Jul 18, 2023 3:17 pm Post subject: Re: ICON VW pistons |
The much better option would be to just get some decent modern heads that come with a big proper chamber, and leave the pistons alone with a nice flat top.
Brian _________________ www.type-emotorsports.com |
Posted: Tue Jul 18, 2023 3:31 pm Post subject: Re: ICON VW pistons |
Maybe for a future build. Can you post some examples something in the 65 cc range with a fat quench - maybe a dual quench, like the factory bathtub design? |
Posted: Tue Jul 18, 2023 3:40 pm Post subject: Re: ICON VW pistons |
CB CNC wedgeports come with a 67cc chamber. Its even a butterfly chamber with huge quench flats, and material around the valves exactly where it should be. I really don't think you could get a much better turbo head for VW. And for the price and what you get....They are cheap.
Even AA 500, 501, and 502 heads come with a 61cc kidney bean chamber. By the time you re-cut the seats, and un-shroud the valves, you will be real close to 65cc.
Posted: Tue Jul 18, 2023 3:55 pm Post subject: Re: ICON VW pistons |
Those CBs are pretty nice looking. I'm am though in the hot part of AZ and need ALL the cooling surface area for the heads. Has to be factory style castings with the in between intake port finnage and cooling air flow. |
Posted: Tue Jul 18, 2023 4:06 pm Post subject: Re: ICON VW pistons |
sidemarkers wrote: |
I love it when someone will discount a far superior product due to one small insignificant detail. The inside of an OE cylinder tin has a small deflector to route the air AWAY from the center area between the intake ports. I am 98% certain you would see no difference in head temps with or without the air moving through the coolest part of the head. There is plenty of meat there...You could always drill some holes if it bothered you that much.
The near perfect chamber, the large chamber volume, the super nice casting quality, and the extra weight of the casting itself will far outweigh the non-issue boxed intake ports.
Posted: Tue Jul 18, 2023 4:31 pm Post subject: Re: ICON VW pistons |
It's an AZ thing. Please don't be bothered, it's just 35 degrees warmer here than SD at this particular moment in time.
35+ years of building/driving air cooled in this climate does affect ones outlook on all things heat related. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9827 Location: Oregon
Posted: Tue Jul 18, 2023 4:51 pm Post subject: Re: ICON VW pistons |
Brian_e wrote: |
Brian |
CB 044 Wedgeport head. Chambers are 44cc on these.
Limited cooling passages,
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jul 18, 2023 5:33 pm Post subject: Re: ICON VW pistons |
Don’t worry we get plenty far away from SD every summer. 3000mile road trips in a baywindow with a 2332cc. 100deg+ and 90% humidity last summer in Tennessee. Same thing the year before in the middle of Wyoming. 68-72mph for hours and hours. Heads never got over 350deg. 🤷🏼♂️ It does get hot in other areas of the USA.
Back to Trevor’s original topic about his great pistons...... _________________ www.type-emotorsports.com |
Posted: Tue Jul 18, 2023 6:15 pm Post subject: Re: ICON VW pistons |
Pretty sure Wyoming means Center of the Sun in some language
And props to Icon for supporting the VW community |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3596 Location: Sarasota, in my adopted state of Florida
Posted: Wed Jul 19, 2023 4:58 am Post subject: Re: ICON VW pistons |
67rustavenger wrote: |
Brian_e wrote: |
Brian |
Drill baby drill. |
Posted: Fri Dec 08, 2023 9:28 am Post subject: Re: ICON VW pistons |
LETS TALK DUBS. Thank you to Bill for having me on!
I listen to the Lets talk Dubs podcast all the time love this show!
https://letstalkdubs.libsyn.com/ep-246-icon-pistons-trevor-cleveland
have a listen guys! _________________ Schnell, SCHNELL!
Clatter Samba Member
Joined: September 24, 2003 Posts: 7561 Location: Santa Cruz
Posted: Fri Dec 08, 2023 2:34 pm Post subject: Re: ICON VW pistons |
Congrats, Trevor!
You, me, Brian..
Wonder how many of us regulars here have been on that podcast so far now?
_________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Mar 19, 2024 10:42 am Post subject: Re: ICON VW pistons |
UPDATE!!!!!!!!!!!!!!!!!
IC10077's are in production ... "what are they?" you may ask.. well let me tell you
IC10077-STDK1 are 94mm "C" (1.054 C/H) Pistons
Basically the same quality 4032 pistons we already make but with a much shorter compression heigh... making up to 90mm strokes more easily attainable with a dropped cam case like the TF-1 or 86mm with a standard clearance case and long rods.
Specs
94mm bore
1.054" compression height
1.2mm 1.2mm 3.0mm Ring pack w/spacer rail for oil ring.
same heavy duty .160 wall pin
anodized crown and first ring groove.
Full round design for strength and durability
M42 Coated skirts.
We will have 20 set available in roughly 2 months , sooner if I can light the fires with backorders.
SECOND MAJOR ANNOUNCEMENT!
IC10144-STDK1 85.5mm Forged 4032 ICON pistons
Wanna build a mighty mouse motor? Lots of boost? CLASS 11 Baja Style engine? We got you covered! and yes my internal voice sounds like a carnival shouter....
1.5mm 1.5mm 4.0mm Ring pack with all the same features and strength all the other Icons offer.. best yet... they will be 360 grams compared to the Stock piston weight of 419-430.
These will be going into production later this week, with the same timeline as the 94c's . If I get back orders for them it will help push them through production faster.
If any of you have ANY questions feel free to reach out I do not mind. these sets will be in a similar price range as the sets we already offer, pricing is being sorted and will announce shortly.
Thank you all for your support and interest. I love being able to give back to the community with high quality parts. I hope to have pictures soon.. right now all i have are 3D models. _________________ Schnell, SCHNELL!
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7241 Location: Videbaek Denmark
Posted: Tue Mar 19, 2024 11:14 am Post subject: Re: ICON VW pistons |
VWporscheGT3 wrote: |
Specs
94mm bore
M42 Coated skirts.
Me likes that ring pack. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1312 Location: Modesto, CA
Posted: Tue Mar 19, 2024 1:13 pm Post subject: Re: ICON VW pistons |
Clatter wrote: |
Congrats, Trevor!
You, me, Brian..
Lanner...
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3471 Location: Paradise, Ca
Posted: Tue Mar 19, 2024 9:58 pm Post subject: Re: ICON VW pistons |
Very cool! Is there any drawbacks? like is the piston pin so far up that there is some compromises? _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
