Drilling CB MAXI 2 for oil temp
Dangib
Dangib is offline
PostPosted: Tue Jan 17, 2023 7:49 am    Post subject: Drilling CB MAXI 2 for oil temp Reply with quote
Anyone ever drill a Maxi pump 2 filter for a oil temp sensor? Wondering if there is a nice spot for it that works like the other external filter mounts.
pump and filter link
https://www.cbperformance.com/product-p/1791.htm?CartID=1
Cusser
Cusser is offline
PostPosted: Tue Jan 17, 2023 8:53 am    Post subject: Re: Drilling CB MAXI 2 for oil temp Reply with quote
I have Maxi2 pump/filters on both my VWs.
I would suggest getting a sender to that replaces the oil relief valve cap or the oil drain plug. I've use the latter since 1977.
Dangib
Dangib is offline
PostPosted: Tue Jan 17, 2023 9:54 am    Post subject: Re: Drilling CB MAXI 2 for oil temp Reply with quote
Thanks ya I read all the post about location of temp sender and I don't really love that location personally I'm sure it can work and probably is just fine, not ruling it out completely but not my 1st choice
balljoint
balljoint is offline
PostPosted: Wed Jan 18, 2023 5:36 am    Post subject: Re: Drilling CB MAXI 2 for oil temp Reply with quote
I don't think its possible given the length of the sensor. Unless you don't mind it sticking really far out using couplers n stuff.
It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi
