jonat Samba Member
Joined: July 16, 2013 Posts: 74 Location: United Kingdom
Posted: Thu Feb 02, 2023 5:20 am Post subject: Where does this decal belong? (42lb/sq.in 3,0atü) |
I found this original decal loose in my 70's 1302s beetle
I'm not sure where it originaly would have been stuck.
measure 65mm L x 20mm W
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Thu Feb 02, 2023 5:51 am Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
That decal goes on the window washer reservoir. Search the gallery in classified, you will find the location in some of the pics. _________________ Come on, It's not rocket science. KISS |
jonat Samba Member
Posted: Thu Feb 02, 2023 7:11 am Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
raydog wrote: |
That decal goes on the window washer reservoir. Search the gallery in classified, you will find the location in some of the pics. |
thanks! Just found an image of it
I'll probably attempt to stick it back using spray mount, unless there is better glue i'm not thinking of to use
Starbucket Samba Member
Posted: Thu Feb 02, 2023 4:29 pm Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
Double stick tape. |
GedasV Samba Member
Joined: December 28, 2022 Posts: 16 Location: Lithuania
Posted: Sat Feb 04, 2023 7:54 am Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
Hi! It seems that there is written air pressure wich has to come from spare wheel to windshield washer reservoir. Sorry my English......................... |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 448 Location: Rhode Island
Posted: Sat Feb 04, 2023 8:22 am Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
Mine was slowly peeling off. I used rubber cement to stick it in place.
I think VW intended the spare tire to be re-pressurized through the washer bottle. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Sat Feb 04, 2023 8:40 am Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
Lost69Convertible wrote: |
I think VW intended the spare tire to be re-pressurized through the washer bottle. |
Yes, but over time few of these really work as intended. I don't think either worked decent on my 1970 standard or 1971 Super (different reservoir bottle shapes, same theory). And I bought each as second owner in 1972 and 1976 respectively.
I changed both to electric windshield washer systems, using universal kits under $20 each. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
jonat Samba Member
Posted: Thu Feb 23, 2023 5:36 pm Post subject: Re: Where does this decal belong? (42lb/sq.in 3,0atü) |
Starbucket wrote: |
good suggestion.
Spray Mount seems to be holding it on so far.. |
