Passat B7 2011 over 100,000 miles
Forum Index -> Water-cooled VW Share: Facebook Twitter
Philipp_Bachowski
Philipp_Bachowski is offline
PostPosted: Sun Feb 05, 2023 6:07 pm    Post subject: Passat B7 2011 over 100,000 miles Reply with quote
Does anybody aware of some usual complaints on B7's with DSG DQ250 automatic and 2.0 diesel? The mileage is nearly 110,00 miles...
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sun Feb 05, 2023 8:08 pm    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
Stay away.
The fuel pumps are prone to failure, when one does, all the shit from whichever fails, takes out EVERYTHING. In-tank pump, pressure pump, & all injectors. All the crap gets distributed throughout & returned to the tank, so it too gets contaminated.
The last several I have had to repair, it was cheaper to buy a junkyard engine & strip the pump & injectors out of it than source them from the dealer.
DPFs clog, which fouls the cat… there’s another $5,000-$7,000…
If it hasn’t been back to the dealer for anything, the moment it does, it gets reflashed & it will lose 8-10 mpg.
Philipp_Bachowski
PostPosted: Wed Oct 18, 2023 2:47 pm    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
TDCTDI wrote:
Stay away.
Thanks for heads-up. I hadn't bought it then. They are mainly come Euro 5 as well, it's going to be a holistic problem. ID4 maybe...
Philipp_Bachowski
PostPosted: Wed Oct 18, 2023 2:52 pm    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
What I would say I 100% love in this car is a gearbox, which operates really smoothly. Thanks for double clutch and dual mass flywheel.
TDCTDI
TDCTDI is offline
PostPosted: Wed Oct 18, 2023 6:35 pm    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
Wait until that dmf or the mechatronic unit take a shit.
Philipp_Bachowski
PostPosted: Thu Oct 19, 2023 5:35 am    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
The last what I had made before I sold it was a dmf replacement. It have been stood 100K miles. That was a quite expensive repair. But mechatronic should last 200K miles without getting any worse, according to dealership mechanic.
TDCTDI
TDCTDI is offline
PostPosted: Thu Oct 19, 2023 12:09 pm    Post subject: Re: Passat B7 2011 over 100,000 miles Reply with quote
While it may last to 200,000 miles, the problem that I’m seeing now is that the parts are being dropped by the manufacturer by the time many are experiencing failure.
The 2011 mentioned at the beginning of the thread is already older than the 10 years that the manufacturer are federally required to keep parts for.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
