Mitey62 Samba Member
Joined: August 01, 2008 Posts: 537 Location: Everett, WA
Posted: Fri Mar 03, 2023 11:23 am Post subject: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
I currently have a 1-3/8" merged header on my bug, with a single glasspack style muffler. Everything from the header back I welded up myself. It fits well and while it's a hair louder than I'd like it sounds pretty good.
I've got a 1-5/8" ceramic coated header hanging around that I'd like to install, however the muffler side mounting pattern is obviously larger. Sooner or later I'd like to pick up a nice ceramic coated muffler system to match, however I'm having a fairly hard time finding more than a few options, so for the time being I'd like to simply cut off the old 1-3/8" flange and weld on one to fit the new 1-5/8" header.
Does anyone sell exhaust bits and pieces that might have just the flange and short section of properly sized flared pipe that I could pick up? I could make the flange part fairly easily, but it would be great if I could just order the thing, cut to length and weld it on. I believe when I welded the current muffler, the header came with a stinger which I cut the mounting bit off of and used that.
Thanks in advance. |
VeloMikey Samba Member
Posted: Fri Mar 03, 2023 12:36 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Why not convert it to V-Band? Simple, easy clean. Summit Racing sells them.
You can text Tiger at A1 and ask him if you can sell you parts. His number is 714/836-7201 _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
Posted: Fri Mar 03, 2023 1:16 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Never heard of v-band before. Looking it up however appears that I'd need to weld another flange onto my header to match, and since it's ceramic coated I'd like to avoid that. That would also mean that when I end up with a different muffler system (which will probably also end up being ceramic coated) I'd have to modify that one too.
Just looked up A1, they look like they have some nice stuff! I'll try to get a hold of him and see what he says.
Thanks. |
b-man Samba Member
Posted: Fri Mar 03, 2023 3:03 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Gene Berg sells a variety of exhaust flanges. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Mar 03, 2023 10:48 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Columba River has universal flanges in stainless but they make mild steel ones...
http://www.mandrelbends.com/flanges-gaskets/exhaus...nless.html
The have 3 bolt flanges which would be better to join ex pipes with less leakage.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Sat Mar 04, 2023 9:59 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
It looks like the Gene Berg site has a ton of goodies! It's a shame there aren't any pictures. I'll call them Monday and see if they can help, thanks b-man!
earthquake, I'll be stashing away that website for future use, thank you. And yes, I'm looking specifically for the 3 bolt flange you find at the header/muffler joint, not the 2 bolt flanges like you linked to, which would be from the head/header joint. It looks like they've probably got something that would work with some measuring, but nothing that comes with a short section of flared pipe to retain the flange... I don't want to weld the flange directly to the muffler tubing if I don't have to. |
modok Samba Member
Joined: October 30, 2009 Posts: 26794 Location: Colorado Springs
Posted: Sat Mar 04, 2023 10:16 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Flanges do not come with pipes welded on already, but a muffler shop could make that for you very easy. |
Posted: Sat Mar 04, 2023 10:19 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
The flared pipes aren't welded to the flange on the muffler side, so that it can be rotated to fit. I'm looking for the muffler side 3 bolt flange, with a short section of flared tubing that fits inside the flange - imagine a stinger... the flange is captured by the flare, but free to move and rotate.
Hope that helps clarity. |
modok Samba Member
Posted: Sat Mar 04, 2023 10:48 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
neat idea, but i don't really see any advantage.
It will still need to be welded on in-place if you want it to line up perfect. |
Posted: Sat Mar 04, 2023 10:53 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
We must have a communication issue somewhere... that's how most muffler/exhaust systems work. One flange is welded solid (header side), and the other is allowed to rotate and move freely, and clamps/aligns the muffler side exhaust tight once it's bolted together. Its a very common practice and has been for decades. |
modok Samba Member
Posted: Sat Mar 04, 2023 11:04 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
it's common practice in other situations but you are here in this situation, and apparently you"never heard" of a v-band.
You need to visit a muffler shop and tell them they are doing it all wrong. |
Posted: Sat Mar 04, 2023 11:13 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
How many muffler shops do you think have made custom ACVW exhausts? I'd bet the number is very small. In case you haven't noticed, our cars are a bit "different" than 95% of other cars in the world.
I'll go tell the muffler shops they're doing it wrong, you go talk to the well known suppliers of vintage VW parts and tell them the same. Fair?
Either way, thanks for the advice. I trust you can see yourself out?
Thanks again to the others with helpful replies and sources. Come Monday, I'll make some phone calls. |
modok Samba Member
Posted: Sat Mar 04, 2023 11:36 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
We can agree to disagree on the usefulness of the thing, but I do hope you find it anyway. Sorry jumped in without fully understanding the question. |
b-man Samba Member
Posted: Sat Mar 04, 2023 1:44 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
Ask them to get you the 3-bolt flange that they use on the GB 933HBH like the ones pictured, they’ll be able to get the exact one you need.
edjose17 Samba Member
Joined: November 04, 2019 Posts: 24 Location: Puerto Rico
Posted: Sun Mar 24, 2024 7:01 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
b-man
Is that the muffler from CB perfromance (3676)? if not which one is it?
b-man wrote: |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 89 Location: South Bay LA, California
Posted: Sun Mar 24, 2024 11:56 am Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
you could also check SoCal Imports - They might (???) have a business relationship with Tri-Mil if I remember correctly.
I've bought 1 3/8 flanges off the shelf from them when I was creating a spacer for my muffler. They might have 1 5/8 in stock too. |
74 Thing Samba Member
liquidrush Samba Member
Posted: Sun Mar 24, 2024 2:23 pm Post subject: Re: Who sells muffler-side exhaust flanges to fit 1-5/8" headers? |
I recently redid my exhaust and every 3 bolt flange and piece of pipe I used came from amazon. They have every exhaust part you might need. Stainless too. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3296 Location: Rapid City, SD
