Jimbosmith Samba Member
Posted: Sun Apr 02, 2023 2:40 pm Post subject: 2276 48idf jetting issues |
Hello all.
2276
FK47 cam 10.5/1
1.4ratio rockers
1 3/4 4-1exhaust
DPR wedgemated crank
45-37.5 cb super pro heads
Duel 48idf carbs
Current jets
Idle 65
F2 tubes
150mains
200airs
40mm vents
Carbs stripped floats set to 10mm and new gaskets
AFR monitored via Fueltech 02 wideband
Engine pulls hard no stutters or coughs. No back fires I can hear (solid mounts and no sound deadening)
Mixture screws set roughly 1 1/4 turns out for best running.
At idle tuned by ear. 1k idle speed
0.85
3k constant, barely any throttle cruising. AFR 0.76
Seems to lean out when I go wot to a better 0.88-0.90
Any thoughts? Am I chasing numbers here. It pulls super hard and drives fine.
Potential things I’m thinking of trying 42-44mm vents 🤔
Video here https://youtu.be/_AB29ml3GVc |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9791 Location: Oregon
Posted: Sun Apr 02, 2023 2:52 pm Post subject: Re: 2276 48idf jetting issues |
Jimbosmith wrote: |
Hello all.
2276
FK47 cam 10.5/1
1.4ratio rockers
1 3/4 4-1exhaust
Duel 48idf carbs
Current jets
Idle 65
F2 tubes
150mains
200airs
40mm vents
0.85
Any thoughts? Am I chasing numbers here. It pulls super hard and drives fine. I can attach a video shortly.
Potential things I’m thinking of trying 42-44mm vents 🤔 |
Your floats should be 5.5mm. 10 Seems a bit much. Otherwise, all the jetting seems semi ok.
I assume your afr readings are being reported as Lambda. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Apr 02, 2023 3:04 pm Post subject: Re: 2276 48idf jetting issues |
Yes so translate to roughly 11-11.8 at cruise
5.5mm? Seems low. All the Weber books I have say 10-12mm. I don’t think I’d get 5mm. |
Posted: Sun Apr 02, 2023 3:13 pm Post subject: Re: 2276 48idf jetting issues |
Jimbosmith wrote: |
Dammit! Reading comprehension is fundamental.
Yes 10-12 is correct for an IDF carb.
My mind read IDA.
I set my IDF's at 10.4mm. I have a 3/8 socket extension that is that exact diameter.
Sorry for misreading your thread title. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Apr 02, 2023 3:16 pm Post subject: Re: 2276 48idf jetting issues |
Ha no worries, would love a set of Ida but next step is EFI I think
67rustavenger wrote: |
Jimbosmith wrote: |
My mind read IDA.
Sorry for misreading your thread title. |
Posted: Tue Jun 06, 2023 2:57 pm Post subject: Re: 2276 48idf jetting issues |
Still the same if anyone has any ideas.
Took it to the drag strip and it really sooted up the exhaust. After 4 passes |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Jun 06, 2023 5:44 pm Post subject: Re: 2276 48idf jetting issues |
Try F11 e- tubes and a 55 idle _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Your cruise readings are rich. Lower the size of the idle jets, incrementally, if you have them.
It seems odd that you're getting sooted up exhaust with 150 main jets.
Curious, what ignition system are you running? _________________ I have learned over the years.
Buy Once, Cry Once!
RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Tue Jun 06, 2023 9:48 pm Post subject: Re: 2276 48idf jetting issues |
Surprising that you got sooted up after those passes...but....spark plug is the better tell. Exhaust could just be getting sooted up at any point and your AFR shows that, if anything you're leaning out up top. (plus excessive accelerator pump squirting can juice up exhaust)
As for jetting.....I'd move to at least the following....
60 idle
160 main
200 up to 230 air and you'd probably notice no difference at all unless you kept your eyeballs glued to AFR gauge here so worry less about air than idle & main.
Remember too......you can have high or low AFR at **ANY** idle jet depending on what you do with your mixture screws. Your idle jet doesn't determine your idle AFR...it only determines your lower rpm cruising attitude and somewhat...AFR. (-Conolly)
BTW, motor sounds great and if you start to get frustrated at ANY point playing with this crap....go back to where you feel it runs best and ignore the gage and forums for a bit...you can always come back to it....carb crap can make you crazy! (Don't ask me how I know) |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3467 Location: Paradise, Ca
Posted: Tue Jun 06, 2023 11:45 pm Post subject: Re: 2276 48idf jetting issues |
FYI, Because your car doesnt sputter, or do something horrible, it can still be horribly off. And Seat of the pants only tells you your lean enough to haul ass. Your soot might be from idle circuit, and might be crazy lean everywhere else.
Your combo should be needing alot more fuel then what your mains/airs can deliver as is.
Whats your 4k+RPM full throttle AFR?
I have a more mild combo then you, and it was 15.8:1 afr with your jetting anything 4k rpms and above. It felt fine. I had no idea it was horribly lean till i put a wideband on it.
I ended up with
1.65 air, and 170 main before the AFR got into range with enough fuel, and thats with 38 vents and F2's. (Same 60 idles) _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Wed Jun 07, 2023 1:11 pm Post subject: Re: 2276 48idf jetting issues |
Ignition im using
MSD 6AL2
Pertronix Billet flamethrower distributor
8.3mm plug leads
i have a whole host of jets, so i can try some more combos. I have had a play around. It Just felt weird going down on the jets given how much fuel it should be wanting in the first place hence why im questioning it.
I dont tend to monitor it too much when im just driving around but when i have glanced over i have seen it sometimes as rich as 10.73 AFR
i have a set of Custom 43mm Vents that i could try too but i havent got that far yet.
Here are the plugs after a drive.
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Fri Jun 09, 2023 4:22 am Post subject: Re: 2276 48idf jetting issues |
I run a 2276 in my road race car. Was running an FK43, 48 IDFs with F2, 160 mains, 180 air, 60 idles, at sea level.
It sees a Lot of WOT, and midrange. The poor thing takes a serious beating every time we race.
_________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Posted: Sat Jun 10, 2023 4:16 am Post subject: Re: 2276 48idf jetting issues |
jbbugs wrote: |
What size vents are you running in the carbs?
I dropped down to a 60 idle and up to a 160main but it’s still reading 0.80 11.8 at cruise and above
Thinking swapping to from a 40mm vent to a 42 or 44 is gonna give it some more air. |
jbbugs Samba Member
Posted: Sat Jun 10, 2023 4:41 am Post subject: Re: 2276 48idf jetting issues |
I’m running 40 mm vents. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
nsracing Samba Member
Posted: Wed Jun 14, 2023 2:47 pm Post subject: Re: 2276 48idf jetting issues |
40mm venturis for street? And no stumble? So you must rev to 4500rpm just to get out of your smoke? |
John Connolly Samba Member
Joined: September 22, 2015 Posts: 48 Location: Sandy, UT
Posted: Wed Jun 14, 2023 7:18 pm Post subject: Re: 2276 48idf jetting issues |
I ran custom 51IDFs from NS Racing with no venturis, it sounds like a Ferrari. No stumble, massive power.
FK47 isn't a street cam, FWIW.
Try 57.5 or 60 idles. Prob 150-160 mains, 180 airs (to begin with).
The other big mistake a lot of guys do is
plugs too cold, and/or too much plug gap. Don't go over .030" gap (.75mm), even with a high output ignition.
Run NGK 6 or 7s. _________________ it's advice. If you don't like it, ignore it. Don't argue.
If you want no-BS technical advice privately, feel free to DM me. Donations appreciated (food gift certificates, etc). |
Posted: Thu Jun 15, 2023 10:42 am Post subject: Re: 2276 48idf jetting issues |
I remember - them carbs, John.
HEre they are w/ stainless steel custom plates i machined/ precision ground.
[/img] |
Posted: Sun Feb 25, 2024 9:01 am Post subject: Re: 2276 48idf jetting issues |
Right, i gave up but im back to trying to sort this out.
Here is the current setup
Fuel pressure is checked and perfect
43mm Vents
F11 Tube
155 Mains
200 Airs
60 Idles
So from idle to WOT the engine pulls fine no stutters or flat spots
F11 tubes
Cruise AFR (5-10% throttle input) is reading 11.9
WOT AFR is reading 13.97
F2 tubes were
11.03 Cruise
13.38 WOT
above is with same jets only changed the tubes
Now i tried a 55 idle and a 180 Air on F11 Tubes and the Cruise Afr 12.79 came up and i think i needed a bit more mains as it was leaning out too much. However there was a big lean spot before the mains kicked in. You could power through it quickly but if you rolled the throttle on it hit that spot and struggled.
With the current setup listed above its great through all RPM but i just wish the cruise was a bit leaner. I have a set of 57idles on order. Any other suggestions?
Maybe worth looking at timing? |
Posted: Sat Apr 13, 2024 2:32 pm Post subject: Re: 2276 48idf jetting issues |
From a recent day at the drag strip. Can’t seem to catch a 12sec |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Sat Apr 13, 2024 10:30 pm Post subject: Re: 2276 48idf jetting issues |
My best ETs at the drag strip were with AFRs between 12.9-13.1 on the top end. _________________ 1963 Manx copy
1968 Bus |
