MMKGreenMachine Samba Member
Joined: April 18, 2023 Posts: 16 Location: Vancouver Island, BC
Posted: Tue May 09, 2023 8:51 pm Post subject: Camper Fuse/Wiring Help! |
Hi,
I recently purchased a 1983 Westy (1.9L Watercooled) and am trying to get the water pump for the sink and fridge working off the 12V system again.
One of the POs did a few strange things with the relay and wiring for the fridge/sink.
The best I can tell, the PO was piggybacking their stereo amp off the power wire that runs to the battery from terminal 87 on the relay, they installed a new water pump for the sink with new wiring, and bypassed the original 16A and 8A fuses (likely with some sort of in-line fuse) which is why the wires are spliced.
I have to replace the relay because it was fried. My question is, how do I go about restoring the original wiring configuration?
I know the blue wire will go on terminal 86, the red/black wire on 85, and the red wire bundled with those two wires will go on one of the 87 terminals, but which of my wires goes to terminal 30 and which goes to the other 87?
My guess is the red (spliced with black) goes to 30 and the white goes to 87 - is that right?
How do I go about re-wiring those through the original fuses?
Thanks!!!!
69aircooled Samba Member
Joined: August 04, 2004 Posts: 263 Location: North Carolina
Posted: Wed May 10, 2023 4:21 am Post subject: Re: Camper Fuse/Wiring Help! |
I have recently gone through a similar exercise. Here are some pictures I took from a donor camper. Hope this is helpful.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19160 Location: Retired South Florida
Posted: Wed May 10, 2023 4:25 am Post subject: Re: Camper Fuse/Wiring Help! |
Last picture heavier gauge is for the 16 amp fuse. Lighter gauge is for 8 amp fuse. From memory the 8 amp fuse powers the LED display under the sink, the water pump and possibly the fridge cooling fan. The 16 amp fuse powers the fridge on 12 volt. I’d have to sit down with the manual to explain the relay connections and I see non factory wire in your pictures. Wouldn’t want to tell you wrong. If you have a coach battery in addition to the starter battery there are much better solutions to the factory relay. I just opened a small box the other day with the factory relay, wire, and 2 fuse box I removed from our 82. Was surprised I still had it.
edit: On my PC now.
The relay has two 87 terminals. One has a heavy gauge wire running to the starter battery positive terminal. It should have power all the time. The other 87 pin goes to the smaller 8amp fuse. It should not matter which wire ends up on either 87 terminal.
Terminal 30 on the relay goes to the 16amp fuse for powering the Dometic fridge. 85 and 86 are the holding coil for the relay. They are wired to isolate the power to the 16 amp fuse during cranking and to connect when the engine is running. At rest, 85 is likely seeing a ground from the starter solenoid and 86 is seeing a ground through the alternator. For the relay to energize, One of the terminals see's power and the other sees ground. When you go to start the engine, terminal 85 should get power. When the engine starts and runs, you should get power on terminal 86 and terminal 85 now acts like a ground for the holding coil. It's difficult for me to translate this into text. Early relays had an external ground wire. This diagram does not show an external ground.
Alos because of the different years, I have found the Factory Manual as it relates to the camping electrical to not always be exactly what I am looking at. Also, in general, most relays would have constant power on terminal 30, this relay is the exception to that rule. Hope that helps some. There are other members that will likely chime in and point out my errors.  |
Ziegel Samba Member
Posted: Thu May 11, 2023 10:26 am Post subject: Re: Camper Fuse/Wiring Help! |
| Thanks, everybody! I think I've got it more or less figured out now. Grabbed some fuse and a new relay (plus a spare) and will give reconnecting a go. Will let you know how it turns out! Thanks again! |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Thu May 11, 2023 11:03 am Post subject: Re: Camper Fuse/Wiring Help! |
this is what the stock relay wiring looks like on my van:
Wire - Terminal (stock)
1. Red/Blk - #85 (ground through starter solenoid)
2. Blue - #86 (ignition trigger)
3. Red from dash - #87 (outside) (Constant power)
4. Small red - #87 (middle) (from aux. fuse box)
5. Large red - #30 (from aux. fuse box) _________________ 89 Westy 2.1 Auto |
Chilepines Samba Member
Joined: October 11, 2022 Posts: 251 Location: New Hampshire
Posted: Mon Jun 05, 2023 6:57 am Post subject: Re: Camper Fuse/Wiring Help! |
Would the relay still work if terminals 30 and 87 were reversed? I just found that n my relay terminal 30 has constant power and terminal 87 is going to the fridge fuse behind the driver seat.
Related question - what does the other circuit behind the driver seat run? The wiring diagram in my Bentley shows 80-85, but that does not match what I see in my 89.
I'm trying to get my sink running from a new house battery. I have green wires to the water pump and yellow for the pump switch.
Where that green wire comes from is a mystery. In the sink cabinet you can see a green wire coming from the LED panel. Can I tap into that green wire to run the pump? (The fridge is disconnected and being replaced with a compressor fridge which I will wire directly.)
_________________ White 89 Westy with 2004 Subaru EJ25 and Subarugears 5MT - Betty |
Timwhy Samba Member
Posted: Mon Jun 05, 2023 8:41 am Post subject: Re: Camper Fuse/Wiring Help! |
| Chilepines wrote: |
[Pic] |
The relay is wired correctly in the 30 and 87 positions.
The 87 wire goes to the larger red wire on the small black fuse box, you'll need a 16 amp fuse and it goes to the fridge.
The other smaller red wire powers the sink pump 8 amp fuse.
The green wire comes off the water tank sensors to show the water level to the LED panel.
The yellow wires go to the sink faucet.
Look at your water tank and see if your pump is plugged in after you connect power thru the small black fuse box. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
kamzcab86 Samba Moderator
Posted: Mon Jun 05, 2023 9:34 am Post subject: Re: Camper Fuse/Wiring Help! |
| Chilepines wrote: |
| In the sink cabinet you can see a green wire coming from the LED panel. Can I tap into that green wire to run the pump? (The fridge is disconnected and being replaced with a compressor fridge which I will wire directly.) |
The green wire goes from the LED panel to the water tank level sensor. It works in conjunction with a black ground wire.
The pump's wire connections:
Brown to black
Blue to yellow
Open the rear horizontal cabinet, remove the metal cover, and have a look a what's connected, or not connected:
Level sensor is missing in ^that van.
The Dometic fridge wiring can be removed. It's a loom bundle stuffed into another loom. Pull that bundle out, cut and cap the fatter red wire.
If you install an auxiliary fuse panel in the kitchen area, you can wire your new fridge to it, and reroute the thinner pump/panel red wire to it as well to bypass the silly factory fuse "panel" on the B-pillar. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
fxr Samba Member
Joined: December 07, 2014 Posts: 2709 Location: Bay area CA
Posted: Mon Jun 05, 2023 10:50 am Post subject: Re: Camper Fuse/Wiring Help! |
| Timwhy wrote: |
| Chilepines wrote: |
[Pic] |
Look at your water tank and see if your pump is plugged in after you connect power thru the small black fuse box. |
Surely the power in from the main fusebox goes to 87, the sink etc is connected to the other 87 (there's no normally closed contact 87a in this relay), and the fridge is connected to 30. This can seem counter-intuitive to those who are accustomed to relays always having both a NO (87) and a NC (87a) contact. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Jun 06, 2023 7:21 pm Post subject: Re: Camper Fuse/Wiring Help! |
Thanks for the replies. I was stuck on looking for continuity from the 87 wire to the pump - without realizing there is no continuity when the faucet switch is open!
I have a fuse panel in the hidden space and another under the driver seat. Since the 87 wire is in the drivers box I'm using that for the load and the one in the rear near the pump for the negative.
And it works!
DavenpoWE Samba Member
Joined: August 11, 2022 Posts: 15 Location: Port orchard Washington
Posted: Tue May 14, 2024 4:38 am Post subject: Re: Camper Fuse/Wiring Help! |
| To be honest this is a lot to fallow but I have a 1985 vanagon With aux battery that the fresh water pump has not been working, this is some great info thanks! |
