oprn Samba Member
Joined: November 13, 2016 Posts: 12756 Location: Western Canada
Posted: Sat Mar 02, 2024 8:22 am Post subject: Re: Isetta EV Hot Rod Build |
The E brake on the 944s is on the driver's left side next to the door. Just a suggestion... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
electricolive Samba Member
Posted: Sun Mar 03, 2024 6:24 pm Post subject: Re: Isetta EV Hot Rod Build |
Good idea to relocate the e-brake, oprn. It is likely going to want to occupy the same spot on the tunnel as the shifter - just in front of the seats. The shifter itself also has possibilities for a unique solution - planning a 2 speed gearbox by modifying the Type 1 transmission so just need a simple fwd and back shift pattern... _________________ Check out the video of Olive here: https://www.youtube.com/watch?v=L54eqGnPGRI&ab_channel=MonolithMotors |
finster Samba Member
Joined: May 26, 2012 Posts: 7955 Location: north o' the border
Posted: Thu Mar 07, 2024 9:08 am Post subject: Re: Isetta EV Hot Rod Build |
we've got to think outside the bubble - an external handbrake would introduce an extra note of individuality...it could stick up out of a slot in the side pod _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sat Mar 30, 2024 5:39 pm Post subject: Re: Isetta EV Hot Rod Build |
External Handbrake would be fun... Did more work to see how I will fit in the car. Bought a Wilwood reverse swing pedal assembly for the clutch and brake with some compact cylinders - seems good to fit the cylinders rearward away from the suspension and the gauge cluster will mount right above them.
Cut a notch out of the body at the package tray and the removed most of the old seat mount on the floorpan so I could sit in the space and see how it feels.
The site lines are good with at seat back angle leaned back to 55 deg from horizontal and the top of my head is about 1" above the top of the windsheild which should be fine). But, it is not a very comfortable seating position...
Could use more legroom. 3 more inches would be ideal. Right now, the seat bottom is as far back as possible at the rear of the floorpan. I could cut the rear of the floorpan out and gain a few inches by moving the seat bottom back to the axle tube. That will be a bit of work. The easier thing would be to lengthen the wheelbase. Here is the side view at the 84.5" wheelbase that I prefer the look of.
And here is +2" - 86.5" wheelbase.
And here is +3" - 87.5" wheelbase.
Will contemplate the wheelbase while I work on other things. Will either stick with the short wheelbase or go with the +2" wheelbase and tweak the rear floorpan as necessary... _________________ Check out the video of Olive here: https://www.youtube.com/watch?v=L54eqGnPGRI&ab_channel=MonolithMotors |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sat Mar 30, 2024 8:41 pm Post subject: Re: Isetta EV Hot Rod Build |
So you're essentially lying down in it. One thing that might make that slightly more comfortable is an added headrest/cushion that props your head up some (think F1 seating...in fact, those guys are literally lying down like astronauts with feet propped up nearly at eye-level).
On that subject, I'd strongly lean toward your notion of lengthening where necessary to add that legroom you're after while it's (relatively) easy at this point; you risk potential disappointment down the road when it turns into nuisance discomfort. I'd be very interested to see a seat mockup, it sounds real similar to what I'm doing with my Bus at the moment. I haven't measured my seat angle yet, but it's similar to a supercar ergo. I won't be turning my head much for checking blindspots, some other provisions will be in order. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Posted: Sat Mar 30, 2024 8:52 pm Post subject: Re: Isetta EV Hot Rod Build |
And now I see where "electric olive" comes from (or do I ), I just watched your doka video. Pretty slick ride there.
Seeing the Vanagon parking brake setup under your truck (specifically the equalizer underneath) gives me some more ideas as I'm also in a parking brake quandary with my highly modified Bus. I'll likely be gleaning more ideas from you as this build progresses. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
