New Affordable Crank Trigger Ignition Package!
Page: 1, 2, 3  Next
allamaabroad
allamaabroad is offline
PostPosted: Sat May 20, 2023 8:26 am    Post subject: New Affordable Crank Trigger Ignition Package! Reply with quote
Hey all! Some may be familiar with my budget friendly crank trigger kits that I have been offering. I received multiple requests for a full crank trigger ignition setup, and I'm thrilled to announce that it is now available!
Even more exciting than that, I have launched my own business and website! Debbie's AirCooled Engineering has a focus on making modernizing your VW affordable and simple to do. Go check out the site at https://debbiesaircooled.com/
Anyways, here's what I'm sure you're all here for:
Debbies Crank Trigger Ignition System:
https://debbiesaircooled.com/products/debbies-crank-trigger-ignition-system
Debbie's Crank Trigger Ignition is a full package for converting Type 1 engines to crank triggered ignition, providing high levels of accuracy with full tuneability, replacing your sloppy and old technology based distributor.
Debbie's Aircooled is proud to provide the most affordable, capable, and easy to install crank trigger products on the market!
Features
100% Bolt On - No machining or special tools required
Integrated power distribution - No additional fuse or relay boxes required
Easy wiring - Simple screw terminals for all connections
Tuning through Tuner Studio - The top choice for DIY tuners
Full tuneability - Customizable for MAP, TPS, or ITB load sensing (MAP and TPS sensor option required for Independent Throttle Body algorithm)
Full data logging capability through Tuner Studio
Adjustable rev limit and 2 step
Optional warmup sensor for temperature based timing adjustments
Timing idle control - Smooth and steady idle in all conditions
2.5 Bar MAP sensor - Suitable for NA and boosted applications
Optional IDF/DRLA Throttle Position Sensor - Provides more accurate load measurements for dual carb engines with high duration cam
Our unique ECU features an integrated power distribution system allowing for the simplest and cleanest DIY wiring on the market. Based on the popular Speeduino architecture, this system is tuned through Tuner Studio, allowing for spark tables based on common algorithms.
The ECU features full data logging capabilities through Tuner Studio and includes inputs for temperature and wideband O2 sensors, allowing for more informed tuning of your spark table.
Our innovative wiring system uses simple screw terminals, allowing easy customization of length without special crimping tools. Integrated power distribution means no need for external fuse boxes or relay boards...it's all self contained!
Includes:
ECU with Integrated Power Distribution and EZWire
Debbie's Crank Trigger Package - T1
8' Pre-Terminated Customizable Wiring Harness
Ignition Coil of Choice
Tuning Cable (Short)
Optional: Warmup Sensor
Optional: Dual Carb Throttle Position Sensor
Coils:
Coil options currently include 4 post Subaru and VW coils.
The Subaru coil uses the common HEI terminals (found on many aftermarket VW distributors)
VW coil uses LS2 style terminals. This option includes spark plug ends and boots to convert spark plug wires over to this style of terminal.
LS2 Coil and Coil On Plug options coming soon!
Load Sensing:
Load sensing options include MAP, TPS, or Both.
MAP sensor is best for single carb or stock applications. MAP sensor uses the pressure in the intake manifold for load sensing and requires a vacuum line.
TPS sensor is for dual carb (IDF or DRLA) only. TPS is often the best option for dual carb, large cam, large displacement engines. This option has the quickest and most accurate response for dual carb engines and does not rely on vacuum signal, which is often unstable with high performance engines. Most engines are more responsive with TPS.
The Both option will allow for the use of the ITB algorithm (Independent Throttle Bodies) which closely resembles dual carb engines. This option will provide the most accurate and responsive engine as it uses a combination of TPS and MAP sensors.
To purchase, visit the link below. Thanks, and I hope to hear from you soon!
anthax
anthax is offline
PostPosted: Sat May 20, 2023 10:31 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
This looks interesting.
And affordable too. Just the currency conversion that sucks here at the moment.
slalombuggy
slalombuggy is offline
PostPosted: Sat May 20, 2023 11:52 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Cool, any plans for a TPS bracket for IDA/EPC carbs. Looks like a very well put together kit. Is there any initial maps installed or is it a complete diy? Would love to do a stealth ignition system on my 911 fanned 1968cc with 48s.
Great job!!!!
allamaabroad
PostPosted: Sat May 20, 2023 1:08 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
This may help a litttle, but I'm offering 5% off your first order on the site! Should help a little with exchange rates Smile
allamaabroad
PostPosted: Sat May 20, 2023 1:11 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Great job!!!!
I'm working on getting my hands on a set of IDAs, or just someone that can take some accurate measurements of the geometry of a on an IDA. Definitely shoot me a message if you've got a set of calipers!
Also, stealth trigger is coming soon. I'm getting my lathe set up and will soon have stealth trigger setups
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sat May 20, 2023 6:59 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Is that six IGBT drivers there? Or is it "other" to220 transistors?
Those IGBT's make eome heat. Most put a heat sink on them.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
slalombuggy
PostPosted: Sat May 20, 2023 7:37 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Not so worried about the trigger wheel and pickup. I'm wanting to try to install the coil and wires inside the shroud and have nothing going thru the shroud at the heads.
I have calipers and one of my EPC carbs available if you want to pm me a diagram of the dimensions your seeking I'd be happy to measure them out for you.
allamaabroad
PostPosted: Sun May 21, 2023 6:08 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Excellent observation. That photo is of what is more or less my prototype board. It includes 6 igbt drivers for full EFI control. With the ignition only set up, there's only 2 IGBTs needed and they will have heat sinks Smile
allamaabroad
PostPosted: Sun May 21, 2023 6:10 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
That would be fantastic! I also have a chinese IDA that I've been working with, but it would be great to verify with a higher quality carburetor. Ill throw together some diagrams and send you a message
DeathBySnuSnu
PostPosted: Sun May 21, 2023 9:53 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
I was looking and thinking "expandable"
For the "simple" wasted apark would be a beginner point. But the board is already built to handle ugrades such as COP, Fuel, Sequential....ect
allamaabroad
PostPosted: Thu May 25, 2023 8:12 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Great job!!!!
IDA/EPC throttle position sensor is now available on the site Smile
https://debbiesaircooled.com/products/debbies-crank-trigger-ignition-system?variant=45373524541742
allamaabroad
PostPosted: Thu May 25, 2023 8:15 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Yep, I will be using the same board for all of my different products (Crank Fire, EFI, and a CB Black Box competitor) and just altering the components that get installed on the board to lower the cost of making building it, which allows me to lower the price.
raygreenwood
raygreenwood is offline
PostPosted: Fri May 26, 2023 9:31 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
This looks like a very cool system!
I have a suggestion for you that will help reliability immensely.
The screw type terminals are not a good idea. You will find that in the history of production EFI from 1966 (D-jet) until now, there has never been a millivolt sensitive application (EFI or other engine controls) that has used a screw type wire connector or inline (in the wire loom) solder....for VERY good reasons.
D-jet had its own serious issues as it aged. Every single long term reliable system (which ruled out most GM systems through the 90's) since D-jet has used a dual cantilever female terminal on a male pin.
The problem with screw terminals is that they REQUIRE the use of crimp on ferrules. This allows proper crimp compaction of the wire strands....BUT....does not get rid of the problem that screw terminals are notorious for.
Vibration and heat cycling. The heat cycling causes expansion which makes teh screw tighter...which compresses the metal ferrule harder. When it cools down and shrinks....the dent made by the screw remains deeper. Over heat cycles...with added vibration....the screw to ferrule joint gets loose and connectivity suffers. You will constantly be retightening these connectors chasing gremlins....until the ferrule gets mashed out and then you have to snip and replace. These terminals are also the bane of car stereo people and are only used on large gauge power wires like 10-8 AWG...whose ferrules are very thick walled and do not suffer as much.
These are what the ferrules look like.
I like the thought that special crimping tools are not needed but its really not an issue these days.
You can buy an excellent knock off of the Paladin 1300 crimper pliers for as low as $25. The D-sub dies can be had for $30-ish. This will do virtually all fuel injection ECU and female connector terminals on the market.
Buy a second die set for about $30-ish nd this same crimper will do any chassis and engine harness terminal in your vehicle except flag terminals.
This is a proper dual cantilever terminal used in roughly 98% of all vehicles world wide since ~1974 (except 80's through early 2000's GM...but they use them now):
The leaf springs in these micro D-sub terminals keep proper contact at any angle, vibration and heat cycling....on the males pins. Ray
pig-pen
pig-pen is offline
PostPosted: Sat May 27, 2023 8:48 am    Post subject: Reply with quote
Quick question...
does the unit have boost retard function with the MAP sensor?
1954 L227 Type 113
1964 L31 Type 265
DeathBySnuSnu
PostPosted: Sat May 27, 2023 10:54 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Did say tuner studio.....do yes i would expect boost retard. That on board map would probably do 20 lbs.
My luck with terminal ends is vastly different than mentioned above, but a lot of my needs have been different than "normal".
My number one tip is to have the instructions in plain wording. Less or no theory....more "coil 1 to number 4 terminal. The hardest part about getting a grip on yhe megasquirt stuff was the naming of stuff.....as in at one point a part would be called by its function (map sensor) then later by it's part number, then later again by the brand manufacturer. then later by its digi key refernce.
Pick a name and always referr to it the same. Maybe whatever name it is in tuner studio.
raygreenwood
PostPosted: Sat May 27, 2023 11:19 am    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
When one is dealing with either fuel injection or....in the case of this ignition system which is using inputs and data from common fuel injection system components (TPS, MAP, CHT etc.) all of which are millivolt sensitive.....you need to have very solid connections that cannot degrade over time.
Crimping is designed to do this as it compacts the wire strands at the connector on the open end of the wire forcing out air and moisture from between the strands so that oxidization cannot form. It's not a worry back inside the wire insulation. Just at the cut/stripped end.
The use of copper wire (best electrical conductor short of silver)....once uncrimped ...unsealed...uncompacted wire strands oxidize roughly to the color of "dark penny" their conductivity drops by 40-50%. This means resistance goes up. Resistance is interpreted as signal....changing output.
Once the copper oxidizes to white before going green....it is a "0" conductivity situation.
If this were just "power" to something like a relay, a fan or a coil....it's not that big of a deal. So you lose a volt and maybe gain an ohm or 2. Not a big deal.
But a volt or a couple of ohms difference from any of the type of components I listed above.....which are being used as sensors....is a huge change.
I can make any wire conduct. Basic conductivity. Keeping it millivolt sensitive and reliable over time takes a little more work. Not much....but a little.
The screw terminals are fine. Like I said, I appreciate the reason....keeping it simple and affordable.
But it would be far better at the worst to require crimped ring terminals if you wanted to be dirt simple. I can buy a bag of 100 tinned copper micro ring terminals to use with a basic crimper and heat shrink for about $15.
Or, the set screw terminals should be made square profile (same cost) and for $20 I can buy a huge box of ferrules and a proper square profile crimper on Amazon.
For those wanting to use ferrules and set screw terminals, here is a great tutorial. Yes, I realize it's a car stereo site (an excellent one by the way)....but it's high end enough that it more than matches what is being done here.
https://youtu.be/sMFFzpzKhFg
Here is the crimper and ferrule set.
https://www.amazon.com/Crimping-Insulated-Terminal...H0QAvD_BwE
I mean...$20 to get far better and more reliable connectivity? Wink
Ray
clonebug
clonebug is offline
PostPosted: Sat May 27, 2023 5:10 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Megasquirt (B&G) relay boards have been out for 20 plus years with screw terminals.
It does work and I used the same Relay board from 2013 thru 2021 and never had a wiring issue.
Any wiring can have an issue but if you take a little time to make it neat and tight it can work well........even with screw terminals.
Keep it out of the weather....which it was meant to be... and you should have many trouble free miles.
First pic is the 2013 thru 2021 version with many additions and changes throughout those years.....and the reason there are so many terminals from adding features and upgrades.
This is the new wiring for 2022 to current.....Still getting changed as needed but was tied into all the original EFI wiring back to the engine.
Someday I might do a complete rewire using smaller gauge wires to shrink the harness size but it works for now and I'm not that bored to tear it completely down.
Last I counted there were over 40 wires running to the engine.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
clonebug
clonebug is offline
PostPosted: Sat May 27, 2023 5:24 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
allamaabroad wrote:
Great job!!!!
Are you buying those warmup sensors from theDubshop.net and reselling or is it a direct copy and you are claiming it for your own????
Not only that....but you try to advertise your stuff on his FB EFI site?????
That's bullshit......
Audi TT intercooler
EcuMaster PMU16
raygreenwood
PostPosted: Sat May 27, 2023 6:53 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
Yep! I remember watching your build!
My point and your point combined....yes....many have done just fine with the MS screw terminals. But....just as many have not.
My point in this thread is that if one is building a NEW system from the ground up....why not do it better in the least or correct at the best.....seeing that it really costs very little to do so.
By better.....I mean even keeping the screw terminals....spending $20 for the ferrule crimper and enough ferrules to do the whole system is orders of magnitude better than just wires mashed under screws
Best would be correct duel cantilever Ev-1 type terminals in sealed plugs just like modern cars. You can also buy many components (temp sensors, MAPS, TPS etc.) That already have the matching male plugs.
I can see why MS started out with screws....back then, the cost of AMP plugs and terminals and crimper to do a system was prohibitively high.
Now that a lot of the patents have expired.....you can get plugs from all over the world for cheap, terminals are universal and cheap and damn good crimper and dies (if you shop) can be had for dirt cheap.
Anyway....it was just a suggestion since he is just starting out production and it's easy to do.
The connector that MS uses that probably causes more issues than the screw terminals are the damn soldered, screw down serial cable connectors they use on MS complete systems. Not made for, automotive, should not be used in a car at all and never have been by OEMs for good reasons. Ray
clonebug
clonebug is offline
PostPosted: Sat May 27, 2023 7:51 pm    Post subject: Re: New Affordable Crank Trigger Ignition Package! Reply with quote
The connector MS uses on the MS1 and MS2 is really just a computer D-Plug but like I've said.....It has been flawless for many years.....Is it ideal? Maybe not but it does work and works well.
I have switched to a MS3Pro-EVO and it has AMP style plugs on them. While they might be better they do have their own issues and could cause people problems too. Getting a good crimp if you are new to them is a bit of a challenge.
My new go to is the Deutsch Connector. I am totally impressed with them and once you have the solid pin crimper they are very simple to install and remove and work well.
Most all my connections are replaced with them except the factory connector on the sensors and injectors.
My suggestion is to check your connections every winter as a maintenance item.
I pull my buggy apart every winter to either upgrade it or just look it over. The electrical connections get checked and cycled every time and I do not have any issues with them.
It is a Volkswagen and therefore needs a certain amount of maintenance......My upgrades do reduce that to oil changes and valve adjustments and that's about it.
Audi TT intercooler
EcuMaster PMU16
Page: 1, 2, 3  Next
