russelltatedotcom Samba Member
Posted: Sun Jul 23, 2023 12:17 am Post subject: Remove chrome seat adjuster? |
Apologies if this has been covered before (I could not find anything?)
I am trying to take of my seat adjust lever to get it re-chromed but it looks like it's not easy to remove from the seat!
Anybody else tackled this, It looks like a retaining pin might have to be bent back? Appreciate any help before I dive in and start damaging things
tri356 Samba Member
Posted: Sun Jul 23, 2023 5:33 pm Post subject: Re: Remove chrome seat adjuster? |
tri365! this info looks great, I never noticed the pin ... glad I asked first.
Thanks for the offer of answering questions, I'll see how things go from here
Cheers
RT |
Posted: Tue Jul 25, 2023 1:06 am Post subject: Re: Remove chrome seat adjuster? |
Hi Mike, with a couple of carefully aimed blows I did manage to get the pins out! My question now is did you have any problem getting tension on the spring section when re-assembling it all again? |
tri356 Samba Member
Posted: Tue Jul 25, 2023 7:09 am Post subject: Re: Remove chrome seat adjuster? |
Nice, and congrats Russell!
No, there wasn't an issue with tension on that spring. I had a TON of problems with peening new dowel pins back in though. Take a close look at the re-assembled seat bottom that I show in my post. You can see that the dowel pins are nowhere near as smooth and nice as what came from the factory. I just couldn't do it, and neither could a body guy I took the seat to. You're trying to hold the lever in place, perhaps put a dolly in the back, not scratch your new paint, etc.., all while not getting poked and shredded by those very sharp tabs. I experimented with a variety of stainless steel pins (mcmaster-carr was great at sending small samples), but they were all really hard. Aluminum or some other softer metal should work better, IMO. Maybe experiment before repainting/rechroming, so you know what works?
Mike |
Posted: Tue Jul 25, 2023 8:34 pm Post subject: Re: Remove chrome seat adjuster? |
Good call on dry fitting the pins Mike, I may opt for a slightly undersized pin that fits well ( but hopefully with no play) The seat lever and plate with the teeth are a super tight fit already so hopefully they help to hold all together as one slid unit) |
