Johnnyw Samba Member
Joined: May 12, 2017 Posts: 64 Location: San Clemente, CA
Posted: Tue Aug 08, 2023 5:08 pm Post subject: 1974 Thing Clunking sound when starting from a stop. |
Hello,
Originally, I heard this sound when turning left from a stop and would soon go away when accelerating. But, it seems to be getting worse and now I hear the sound when starting from a stop and going straight. I hear the clunking sound when starting out in first or second gear. I realize it could be a number of things, but I have determined the sound totally goes away while still moving and depressing the clutch pedal. The sound seems to be louder when under a greater
load as in starting from a stop going uphill. Recent work as been to replace both axles but I heard the clunking sound before replacement. I would appreciate hearing of any possible problems.
Regards, John
San Clemente, CA |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 488 Location: Grove City, OH
Posted: Wed Aug 09, 2023 6:05 am Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Check your CV Joints. _________________ '74 Thing
'83 Westfalia |
Posted: Wed Aug 09, 2023 10:21 am Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
I replace both axles and CV joints with new units supplied from the thing shop. The noise was the same before and after installing new axles and CV joints. |
KAmes Samba Member
Joined: February 16, 2014 Posts: 884 Location: Illinois
Posted: Thu Aug 10, 2023 7:44 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Make sure the large stub axle nuts are good and tight, may not be visibly obvious if they are just snug. Weird things can happen if they can move under load. Stub axle bearings? Is there a lot of play when jacked up? The change in sound while turning would lead me in that direction. |
Posted: Fri Aug 11, 2023 1:02 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Thanks for your replies. I値l check the axle nuts this weekend.
Someone else had the idea this car may be lifted more than it should. This car was almost as tall as a Thing with a 3 inch body lift. I知 thinking to get the extra height the previous owner adjusted the rear torsion bars.
From the bottom of the front bumper to ground in 17 inches and from the bottom of the rear bumper to ground is 19 inches. Do you think too much angle is a possibility?? If it is lifted too much, what would be the easiest way to bring it down. Re-adjust the torsion bars, adjustable spring plates, or maybe smaller tires. Currently I have 215/75/15 size tires.
Thanks for your help.
John
Posted: Fri Aug 11, 2023 1:14 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
I just checked my axles angle. Parked in the garage they are at an 18ー angle.
KAmes Samba Member
Posted: Fri Aug 11, 2023 1:45 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
I have 16" inches under the bumper front and rear, if I let my air shocks out it's closer to 15". I know people use different cv joints for high lift but I don't know which ones. It would be easy to test, get someone or two to sit in the back and weigh it down for a test ride.
Edit: If you use your spouse don't say you need something heavy in the car. |
Posted: Fri Aug 11, 2023 3:03 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
KA,
Thanks for your reply. That was my thought exactly. This weekend I値l gather up a couple of people and go for a ride around the block. Good tip on not making a comment to my wife.
I値l keep everyone posted.
John |
Posted: Sat Aug 12, 2023 2:08 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Today after reducing the air pressure down to 20 psi in all 4 tires my son, my wife, and a toolbox sat in the luggage area and I went for a short drive. There was reduction in the clunking noise. Very possibly the rear torsion bars are indexed to high creating my problem. I was considering ordering a smaller size tire and I値l probably follow through with that. My current size is 215/7515 and I will probably buy a 205/7515 size tire.
After the tire purchase next month, I will then look into re-indexing the torsion bars.
If anybody has additional comments, I壇 like to hear them.
Regards, John. |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 187 Location: Englewood, New Jersey
Posted: Mon Aug 14, 2023 2:38 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Hi John,
Going from a 215/75R15 to a 205/75R15 is not going to lower the car.
205 is 8" wide, so it's narrower not lower. I run 205/70R15 which is within
a half inch of the stock 14" tire, so the speedometer is close to original.
_________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
Posted: Mon Aug 14, 2023 4:34 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Harp,
Thanks for your reply. I was looking at the tire rack specs when I decided on 205 75 as a possible size. Tire rack specs for a 215 75 has a diameter of 27.7 inches. 205 75 has a diameter of 27.1 inches.
The 205 70 size tire has a diameter of 26.3 inches. That size is also a consideration. What brand and model 205 70s are you currently using.
Regards, John. |
Posted: Mon Aug 14, 2023 4:39 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Harp,
What is the height of your wheel arch from the ground on the front and rear wheels. Curious what the difference is with your current tires vs mine.
My front measures 30 1/4 inches from arch to ground and the rear is 31 1/2 inches. Based on your dimensions will give me an idea how much I need to lower the front and rear to get closer to a stock spec.
Thanks for your help, John
Posted: Tue Aug 15, 2023 4:31 am Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Hot Rod Harp wrote: |
Hi John,
205/75R15 is absolutely lower than 215/75R15 because it has a shorter sidewall. The height of the sidewall is calculated as a percentage of the width of the tire - that's why they call it the aspect ratio.
215mm x .75 = 161.25 mm
205mm x .75 = 153.75 mm _________________ '74 Thing
'83 Westfalia |
Posted: Tue Aug 15, 2023 4:51 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
I just measured wheel arch to ground, front 27 7/8" , rear 28 3/4". The tires are Yokohama Geolandar A/T G015 from Tire Rack.
Posted: Tue Aug 15, 2023 6:45 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Harp,
Thanks for your reply. Very helpful information.
John. |
Posted: Wed Oct 04, 2023 7:29 pm Post subject: Re: 1974 Thing Clunking sound when starting from a stop. |
Update:
After purchasing new tires, 205/70/15 and re-indexing the torsion bars from 27ー spring plate angle down to 22ー. My problem has been solved. A quick measurement today showed my rear arch ranging from 28 5/8 to 29 inches side to side. And the rear rockers measuring 12 to 12 1/4 inches side to side. These are similar differences I had before starting the project. Today I thought I might try and fine-tune the difference but in the heat of the battle I decided to make the same change on the driver side as I did earlier on the passenger side.
Thanks again for your comments and recommendations.
John. _________________ 1974 Thing with a 1776
San Clemente, CA |
