MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Tue Sep 05, 2023 9:00 am Post subject: AA Type 4 Heads and exhaust port question. |
| I'm at the initial planning stage of rebuilding my 77 Westy 2.0 engine. Even though my current heads have low miles, about 40K I'm considering replacing them with new AA heads as a fresh start. Not sure it's worth sending the originals out seeing as some won't touch them anymore. Once I tear it down I'll inspect and decide. If they're not worth doing, my question is would you stick with oval port replacements or change to square ports? I have to replace my whole exhaust system anyway and planned on a 72-74 heater box swap. I could always go the Federal 1979 style. Was there any advantage to flow etc, or was it strictly a better sealing surface at the head? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5573 Location: Holland, MI
Posted: Tue Sep 05, 2023 10:14 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
In case you didn’t know, the AA casting is a replica of the early 2.0 heads, found on the Porsche 914. They have different spark plug locations than the later 2.0 heads used on the bus.
The AA head castings are real nice, but they are pretty much a carbon copy of the 914 head, which means it has the same weakness. They have thin tops to the chambers and thin exhaust ports. The 914 2.0 heads are notorious for cracking around the spark plug and in the exhaust ports.
Also, you 100% MUST ditch the 2.0 bus pistons!!! Those engines had too low of compression from the factory. Using the Aa 2.0 head castings will make that already bad situation much worse because the combustion chambers are bigger than all other type 4 heads. If you use those heads, you need flat top pistons. If you don’t, you will really struggle to get the engine to run well. Low compression and T4 engines do not go hand and hand. You will roast that engine in short order unless you get that compression back up.
Some people do use the 914 2.0 heads on busses, but I personally wouldn’t. Save it for a higher performance street car.
I would suggest the 1.8 heads. Much more durable. A little secret, the intake and exhaust ports have (as far as I can tell) the same internal profile. The camber is smaller and slightly more shrouded than the 2.0 914, but the flow difference is only minor until you are near max lift. The spark plugs are in the same location as your bus engine, so you won’t need to modify the cooling tin or find 914 upper tins.
If you want the 914 chamber and spark plug angle, AMC has 1.8 heads which are welded and profiled to match the 914 2.0. More expensive, but the benefit is thicker chambers and less likely to crack.
As far as flow difference between the oval port and rectangle port 2.0 bus heads, they flow so close it makes no difference. The later ones are easier to assemble, but I prefer the earlier ones. The rectangular port heads have a full length port, and all that heat stays in the head. The earlier heads are basically just an opening into the exhaust bowl, and the exhaust makes up the majority of what normally would be the port. They run cooler that way. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7976 Location: Videbaek Denmark
Posted: Tue Sep 05, 2023 12:50 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
What have you been drinking?
Look at their site again.
There are the 914 2,0 heads AND the "VW" style heads.
Muzzo, if you are going to replace the entire exh system anyway, I would definitely go with the square port heads as they do flow a little better out of the box and are easy to improve further. Also, the exh gasket is easier to work with compared to the copper one.
I kinda agree on the dished pistons, as I like more static too in almost any case. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Tue Sep 05, 2023 1:19 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Alstrup wrote: |
I kinda agree on the dished pistons, as I like more static too in almost any case. |
Thanks both of you however Alstrup... I was about to make the same comment. I actually had to go back and double check their site to make sure I wasn't dreaming. I also tend to agree with the pistons, especially for the fact that right now my cam selection is a toss-up between the web 142 and the 73/86 profile. Another question, am I correct in remembering that if you use a flat top 2 L piston with a stock CC head and Factory deck height that that will bring you up to about 8:1 compression? I still need to research this detail and do some calculations. I think this is something I remembering from 30 years ago but good luck with that |
Posted: Tue Sep 05, 2023 2:08 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
No. Flat tops give more CR. Like 8,5ish i think.
The 73/86 solution is a widely used solution for a "cheap" cam. IMHO it is too much exh. duration. It costs power and especially torque. The RAT 7550 (I think its called) has less exh. duration and is better suited for a bus with a good exhaust sytem. Also, the 86 grind doesnt like high static compression, so the properties go against each other (IMO)
I know what is recommended for CR with that and similar cams. We have slightly colder climate here, and a hair better fuel. That said, when I do engines like that I never go below 8,5 with the 7550, still on 91 octane. In fact the engine really wakes up at 9-1 with 93 octane, and the "fun" part is that the heads stay nice and cool, - if you know how to set your ignition timing up.
As I use to say for you US based guys, Set the CR up for premium fuel at sea level and use the octane needed at the altitude you are driving in. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Tue Sep 05, 2023 2:13 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Alstrup wrote: |
As I use to say for you US based guys, Set the CR up for premium fuel at sea level and use the octane needed at the altitude you are driving in. |
thank you. Yes I was speaking to somebody else here recently about that issue with the 7590. One thing I don't want is to lose low-end efficiency, hence why I was leaning towards the 142. It gets a lot of good press here lately. I'll have to check around and see if there are any other recommendations. I 100% plan on staying with the factory fuel injection |
Posted: Tue Sep 05, 2023 2:39 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
Then the 7550 is the way to go.
The 142 is "just" a 412E/914 2,0 cam.
The ´77 bus is L jet, right?
That can easily be modified to work significantly better, - and handle the extra power. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Tue Sep 05, 2023 2:41 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Alstrup wrote: |
That can easily be modified to work significantly better, - and handle the extra power. |
okay thanks I understand now. Yes stock L Jetronic injection. I'll have to look it up because I'm pretty sure I read that the 7550 is no longer produced. Maybe web can grind it themselves. I'll have to look up the specs |
Wreck Samba Member
Posted: Tue Sep 05, 2023 2:53 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
A little trivial and not relevant in this case . AA used the VW head to cast their square port heads , it is a shame they didn't copy the AMC casting . The AMC square port head has more material to work with on the long side of the exhaust port .
Even though mine are opened up , I can still use the stock gasket . just have to carefully open it up with a die grinder , then put the 3 seperated parts together with a little maniseal . |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23586 Location: Oklahoma City
Posted: Tue Sep 05, 2023 6:02 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
Just a few corrections here....just cleaning up and not poking at anyone!
The. cam Alstrup was speaking about is the "9550". Yes....it's been discontinued.
It was a variation of the web #73 with a couple of degrees difference in overlap or timing. I can post the specs later when I get home.
Both the #73 and the 9550 cams are based around the valve timing (within a few degrees) as the original 1.7L 411 cam which continued perhaps into the very first few 412 with 1.7L....Both with D-jet injection. That is listed as the "V" series factory cam. The later 412 and 914 cams were "Z" series.
I will post specs for each that I have. The critical difference between the factory V and Z series was considerably different valve timing for intake and exhaust opening and closing points.
Both cams worked "well" with factory D-jet injection but the early V series I think tuned a little better. It also was the cam used on the carbed 411 in 1968 -1971.
The later Z grind works a little better with the first L-jet used in 1974 412 and 914. That's just my personal opinion. I am not 100% sure off the top of my head which cam the 1.8 used.
The current replacement cam for the 9550 is the 9590 available from the Type 4 store.
It is essentially the same cam as 9550 with about 2.5° extra exhaust duration or overlap. Cannot remember which one. I will see if I have the specs on all of them.
Ray |
Posted: Tue Sep 05, 2023 6:13 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Thanks Ray. It hit me earlier thinking about the web 73 being very close to the 9550. The straight 73 is the one I was originally going to use in my L-Jet 2 liter. Some had recommended the 9590 but then others have said the it has too much exhaust duration, and will kill torque. I don't want this as I don't like running higher RPM than needed. I feel I'm honing in on what I want, and appreciate everyone input here as always. |
Wreck Samba Member
Posted: Tue Sep 05, 2023 6:25 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| MuzzcoVW wrote: |
Don't be to concerned about higher revs , get an extra oil cooler with a thermostat sandwich plate to handle oil temps , the extra rpm will help cool the heads . A bit of exhaust scavenging will also help . |
Posted: Tue Sep 05, 2023 7:17 pm Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Alstrup wrote: |
Man, when did that happen? A couple years ago the 914 2.0 was the only one they had. I just looked, and they do have bus castings. Wild.
Ever try them out? Never heard any feedback or mention of them. Reviews? Curious how they compare to the AMC castings. _________________ 1800 Type 4 Berrien 295
Posted: Wed Sep 06, 2023 3:27 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| I know I've seen them listed the last couple years, not sure when they started. I haven't been able to find much about real world longevity results... because they are fairly new to the market |
Posted: Wed Sep 06, 2023 8:18 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| MuzzcoVW wrote: |
I had a more detailed post I was going to put up....and still will....showing the valve opening event/timing for the 73, the 142, the 9550 and the 9590....but I got home too late.
The answer's I don't have that hopefully Alstrup can help with .....is....what were the FACTORY lift and duration for early 411 cams 1968 through 1970 which is the "V" grind.....and what was lift and duration for the later "Z" grind that went into 412 and later 914?
I have the valve timing events for all of these cams and will post them shortly....but....though my first car was a 411 and I have worked on hundreds of 411/412, bay bus and 914.....but it was all stock or near stock.
All of my early cam work was just swapping to new cams or having cams reground. By the time I got into the phase where I was getting unto upgrades....there were no KNOWN to be exact 411/412/914 cams around to measure.
I like that you and other people give detailed thought to cam changes with type 4 based engines. It's been said many times before by people who know much more than me.....its as much about all of the details of the engine....and the gearing.....tire size and how you plan to drive it.
And.....most of these cams being discussed....if what we are seeing in spec sheets is true.....MOSTLY relate back to the original early grind factory cam in the VW 411's and early 914....with the main changes being some added lift and duration and a couple of degrees of timing change. And.....this does NOT mean that there have not been significant or suhle changes in lobe profile.
This "keying" off of one main original factory cam was mainly done to keep these cams "friendly" to factory stock injection for type 4 cars (not buses)....and that was mainly D-jet. And the main two function D-jet requires is the correct valve event timing and a smooth enough vacuum signature to work with its manifold pressure sensor.
Example of this lineage:
Early V-grind --- Web #73 with more lift and duration----R-9550 with slight exhaust valve timing change----R-9590 with more exhaust duration.
These are all closely based around the same original V grind valve event timing and lobe center.
The other issue....among many....is that a lot of people (there is a thread going on now in the Bay forum)....get pushed away from the web #73 and toward the # 142 (not saying that is wrong) and therefore, by connected reasoning... away from 9550 or 9590 ...but I think some of the stated reasoning is not correct.
It's being stated that the upper end max power rpm graph is too high for a bus. I am not sure that is true.
Yes, it's true that MAXIMUM HP and TQ with a web 73 based cam is higher than the cruising rpm you want in a bus.....but.....do you need to be at that max hp and tq peak when highway cruising at 65 to 75 mph....to still get excellent hp and tq?
Better said.....when on a long distance cruise on the highway....do you need MAXIMUM hp and tq at cruising speed? Or....would 80-85% do just fine?
Again, this also depends on your gearing and what rpm the gears will force you to be at....for high speed cruise.
More to come. Ray |
Posted: Wed Sep 06, 2023 8:22 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| MuzzcoVW wrote: |
Must have started right after the last time I talked with them. Any one know if they are a carbon copy or the original VW heads, or have they been beefed up? Seems like AMC heads are thicker around the chamber than stock. Would be nice if AA did the same. _________________ 1800 Type 4 Berrien 295
Posted: Wed Sep 06, 2023 8:31 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Looking forward to it Ray, thanks. As for the setup I plan to run, stock gears for a 1977 bus and I MAY run 215-75r15 tires. Not sure on that yet, but I always felt these rigs were under tired ( if thats a thing) for their size. I have them on my Vanagon now and love the look and handling. So if I do that my RPM will be close to a couple hundred lower. I don't drive aggressively but do occasionally take the highways. Here in New England I'm not dealing with the Rockies haha. Thanks again and looking forward to more. Craig |
Posted: Wed Sep 06, 2023 8:35 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Vanapplebomb wrote: |
| MuzzcoVW wrote: |
Must have started right after the last time I talked with them. Any one know if they are a carbon copy or the original VW heads, or have they been beefed up? Seems like AMC heads are thicker around the chamber than stock. Would be nice if AA did the same. |
Good question! I'm planning to use the AA as I've heard talk that the AMC castings have gotten a little long in the tooth. Also myself and several I know are running the cheap AA 500 type 1 heads with great results so that flavors my opinion some. I just hope the valve seats are up to par... |
Posted: Wed Sep 06, 2023 9:42 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
Yeah, AMC have gotten a little nasty with casting flash. They didn’t used to be so bad, but it has definitely gotten worse. Takes a lot of work to clean up the flashing in the air cooling passages. _________________ 1800 Type 4 Berrien 295
Posted: Thu Sep 21, 2023 5:46 am Post subject: Re: AA Type 4 Heads and exhaust port question. |
| Alstrup wrote: |
Just getting back to this, and wanted to make a comment on the timing setup. I had a somewhat unstable idle on my type 1 L-Jet 1600 build when using a CB2280 cam. On advice.. maybe from you? I adjusted the distributor to give me 11 to 12 degrees BTDC at idle, while hitting 30 at max advance. Prior to that i was at 7 and 30. Raising the timing at idle made a HUGE difference in stability and cleanliness of the idle. I believe Jake had mentioned somewhere here that when using a cam like the 7590 to set idle to 14 degrees and max at 28. Depending on the cam I ultimately decide on, I will likely try this on the bus also. |
