volksbugusa Samba Member
Joined: May 19, 2003 Posts: 382 Location: BUNNELL , FLORIDA. 32110.
Posted: Sun Sep 24, 2023 5:19 pm Post subject: suggested jets for weber 34 ict's |
installed redline weber 34 ict dual. jets are stock..but the engine is running terrible;..it is a new 1776 with a bosch German 009 dissy. I need to do something...the idle screw is way over 21/2 turns..timing is set at 30* btdc at 3000 rpms..valve adjustment is good.. I need some suggesting on jetting.... I am sure there are others that have experienced the same issue...what did you do...Thanks...
[email protected] _________________ Matthew E D'Azzo
volksbugusa
https://www.facebook.com/groups/506947294919060 |
Jason37 Samba Member
triumph67 Samba Member
Joined: October 07, 2011 Posts: 142 Location: Lexington,ohio
Posted: Mon Sep 25, 2023 9:27 am Post subject: Re: suggested jets for weber 34 ict's |
Read the article from Wayoutwesty.com, make sure you have a balancing tube 1/2 inch diameter hard hone, don’t use a soft one. Make sure your float levels are good and you have the right fuel psi, 2.1-2.5psi. Wayoutwesty has the right formula on jetting. If you’re using the stock jets that Redline came with you will need to change them. Also make sure you are using F6 emulsion tubes. Time the engine to 10* at idle and 30* at 3000rpm. I have a 1776 also and it runs great and pulls through any speeds. Best of luck to you |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7750 Location: Videbaek Denmark
Posted: Mon Sep 25, 2023 1:21 pm Post subject: Re: suggested jets for weber 34 ict's |
As I mentioned in that otrher thread. When using these carbs, a 009 type dizzy and a regular coil, 30 degree advance is not enough. Most need 32. some even more to do a proper burn. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Mon Sep 25, 2023 1:38 pm Post subject: Re: suggested jets for weber 34 ict's |
Alstrup...thank you for your comments. this is a brand new motor. when i installed the set of carbs for the first time the bug started but ran a little rough.i wish i would have left it alone and have taken baby steps.instead i took the approach to reset both set screws...i have been struggling ever since.
1776 stock motor
009 bosch german dizzy with electronic ignition
stock fuel pump set a 1.5 psi. but will need to check again once i get it running.
flamethrower coil
i have not pulled the carbs yet..so i am not sure what jets are residing within..i am willing to change over the jets. Thats the other problem. who sells them at the each level..trying to buy these 160 mains, 180 airs, 55 idles, f6 emulsions, 150 float jets*. thanks Matt _________________ Matthew E D'Azzo
volksbugusa
Posted: Mon Sep 25, 2023 2:13 pm Post subject: Re: suggested jets for weber 34 ict's |
found euro carb going to order....
77201 Weber DGAV/DGAS/ICT/IDA3C Air Corrector - 180 air corrector
74409 Weber ICT/DGAV/DGAS/ICH Idle Jet - 55 idle jet £3.10
73801 Weber DGAS/DCD/DFAV/DGV/ICT/IDA3C Main jet - 160 main jet £2.69
61440 Weber DGAV/DGV/DFEV/ICT/IDA3c Emulsion tube - F6 emulsion tube
79507V Weber DMTL ICT IDF Viton needle valve - 150 Needle valve
shipped to florida. complete. 165.00. thats crazy..need. to find a cheaper solution _________________ Matthew E D'Azzo
volksbugusa
Posted: Mon Sep 25, 2023 7:28 pm Post subject: Re: suggested jets for weber 34 ict's |
You can get the jets from jbugs |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2176 Location: Behind the wheel
Posted: Sat Sep 30, 2023 7:32 am Post subject: Re: suggested jets for weber 34 ict's |
I’ve never been a fan of ICT’s _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
