Front Axle Support
KChallener
KChallener is offline
PostPosted: Sun Oct 15, 2023 4:56 pm    Post subject: Front Axle Support Reply with quote
I need help installing my front axle supports. I have new plates, and used supports. My question is about mounting. There are two holes forward that line up with the axle supports. In the parts manual it looks like the bolts go down from the head support, through the front support plate, and through the front supports with two bolts on each side. There are two back slotted holes that look like they should bolt up into the body, like the pan. I appear to be missing those bolt holes??? What side bolts? I will have to cut out part of the rebuilt body (foot well) and weld the nuts on the back side? Suggestions? Pictures?
Thanks,
Ken
1976 Bay, 1974 Thing, 1979 Vert Bug, 1973 Super, 1968 Beetle, 1967 split Brazilian Kombi
