sfizio Samba Member
Joined: November 30, 2014 Posts: 75 Location: Norwalk Connecticut
Posted: Fri Oct 06, 2023 3:31 am Post subject: Steering wheel - turn signal gap |
Any ideas on why I have a large gap between my turn signal and steering wheel? The set screw holding the turn signal is at the edge of steering column so it cannot slide forward further. The wheel is seated as far back as it will go.
_________________ Like me, looks good from 10 feet away. |
Spudleydoright Samba Member
Posted: Tue Oct 10, 2023 10:55 am Post subject: Re: Steering wheel - turn signal gap |
deleted my comment.... double post got me! |
chuckkeeler Samba Member
Posted: Fri Mar 22, 2024 7:17 pm Post subject: Re: Steering wheel - turn signal gap |
Hi. I have the same thing on my project. Did you find the solution?
Mybe a collar of some sort. Thanks.
Never mind. Saw your duplicate post. Thanks |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sat Mar 23, 2024 9:35 am Post subject: Re: Steering wheel - turn signal gap |
Is this a new problem?
What did you change?
Do you have the/any previous parts to measure? That is how you narrow-down and isolate your problem, you trace it back to the root cause from when the problem first arose. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
Albiebac Samba Member
Joined: June 26, 2009 Posts: 19 Location: San Diego, CA
Posted: Sat Mar 23, 2024 9:44 am Post subject: Re: Steering wheel - turn signal gap |
On my 1964 (without locking ignition switch), it's a simple adjustment. Loosen steering column clamp (two nuts) and slide up.
I imagine yours would be similar with loosening the locking ignition switch to free the steering column and pull up.
The wear mark on the steering column where the wire harness goes to the dash would suggest it's been like this for a long time. Is the steering wheel a replacement? That would be another explanation. |
RUNKLE Samba Member
Posted: Sat Mar 23, 2024 11:03 am Post subject: Re: Steering wheel - turn signal gap |
Answered in duplicate thread.
wdfifteen wrote: |
Loosen the clamp holding the steering column to the body and pull the steering column out toward the steering wheel. |
Link to duplicate thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=785393&highlight=
chuckkeeler wrote: |
…Never mind. Saw your duplicate post. Thanks |
It is imperative, if not just plain polite to post a link to your findings, as to keep others from spinning their wheels on the subject.
. _________________ Type 1
Type 3
1968 Squareback |
Posted: Sat Mar 23, 2024 12:14 pm Post subject: Re: Steering wheel - turn signal gap |
Yeah, pretty weak, OP @sfizio shoulda terminated this thread, got his response and moved on. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
sfizio Samba Member
Posted: Sat Mar 23, 2024 2:39 pm Post subject: Re: Steering wheel - turn signal gap |
For some reason, this is a duplicate post. Search out the original. I got excellent advice which solved the problem. It’s worth reading if you have the same issue. _________________ Like me, looks good from 10 feet away. |
