dopeboat Samba Member
Posted: Wed Oct 18, 2023 4:33 pm Post subject: New Starter Grinding |
Hi all, I bought a 1977 beetle from a guy whose kid had it as his first car. Needless to say, there has been some interesting work done on the car. The kid put a new starter in, which worked intermittently. The starter would immediately disengage about 2/3 of the time. The remaining third the car cranked like a dream. Well that wasn't good enough for me, so naturally I started messing with it. Pulled the old starter, which ended up not being the right one for the car. It was an Autozone special, and didn't have the little dimple in the casing surrounding the upper bolt to prevent it from spinning, so as you can imagine, it was quite a bear to remove. I got a reman starter from NAPA, which came with the new bushing. I pulled the old bushing (12mm tap) and installed the new one. Installed the starter and this is what I get. Grinding, groaning. Turns the engine over very slowly. Pulled the starter again and it doesn't look like the bushing is happy, but it's installed flush, and I pre-fit it on the shaft before installing. Sliding the starter into place it doesn't seem to have any issue gliding straight into the bushing. Bench tested the starter, it spins up just fine. My system is 12v, and I've confirmed the starter is the correct 12v one. Feel like I must just be doing something wrong and I'm puzzled as to how it could be grinding.
Joined: August 31, 2013 Posts: 13292 Location: North Carolina
Posted: Wed Oct 18, 2023 6:50 pm Post subject: Re: New Starter Grinding |
That flywheel looks a bit suspect. It looks like an aftermarket lightened unit that may be out of round or not installed correctly.
Check the end play of the crank & maybe have someone turn the engine by hand as you film the flywheel with the starter removed. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Cusser Samba Member
Joined: October 02, 2006 Posts: 33070 Location: Hot Arizona
Posted: Wed Oct 18, 2023 6:53 pm Post subject: Re: New Starter Grinding |
Not a good idea to "bench test" a non-supported VW starter, would be OK to bench test a self supported autostick starter this way.
I might suggest using a self supported autostick starter. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Oct 18, 2023 7:45 pm Post subject: Re: New Starter Grinding |
Cusser wrote: |
I might suggest using a self supported autostick starter. |
Do the autostick starters fit the bell-housing of the manual transmission cars?
I know doing the bench test with the unsupported starter isn't ideal, but I needed to know what I'm working with. If the starter had clearly exhibited the same characteristics on the bench then it obviously isolates the entire issue, plus it's not unheard of or I feel like even uncommon to get a bad reman starter. |
Posted: Wed Oct 18, 2023 7:46 pm Post subject: Re: New Starter Grinding |
TDCTDI wrote: |
Check the end play of the crank & maybe have someone turn the engine by hand as you film the flywheel with the starter removed. |
What makes it look suspect to you? Not challenging the assertion, just genuinely curious. Obviously a potential issue with the flywheel makes this into a MUCH more involved project... |
Cusser Samba Member
Posted: Thu Oct 19, 2023 7:39 am Post subject: Re: New Starter Grinding |
dopeboat wrote: |
Cusser wrote: |
Do the autostick starters fit the bell-housing of the manual transmission cars? |
Yes, the autostick starters simply bolt in, and have a little more power/torque. And you can simply leave the existing bushing in place, or remove it: your choice.
The starters in both my VWs are the type that need a starter bushing (both "rebuilt-by-Bosch" in the 1980s); but if I need to replace one, I would consider the autostick starter. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2037 Location: Wichita, KS
Posted: Thu Oct 19, 2023 8:23 am Post subject: Re: New Starter Grinding |
From your video in the opening post, sounds & seems to me like the starter motor's drive gear clutch might be slipping - ?? I mean, it sounds like the starter motor is rotating somewhat at speed (under labor), but the engine is obviously barely turning over. Not hearing a bunch of loud grinding, like if gear teeth were broken or missing. So only thing I can think of that might be slipping would be that gear clutch.
On older stock starters, you can replace that drive gear and clutch as an integrated assembly - e.g. like this one in the classifieds:
https://www.thesamba.com/vw/classifieds/detail.php?id=2588420
There are different types for different starter styles, however, so not sure what type your Napa replacement might take. May be easier just to replace the whole starter... _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
