Chinaclipper Samba Member
Joined: October 03, 2019 Posts: 639 Location: Somewhere in the great Midwest
Posted: Sun Nov 12, 2023 4:01 pm Post subject: Unhooking/ Deconnecting the shielded Spade connectors |
OK I am frustrated and stupid. I can't figure out how to disconnect the plastic shielded spade connectors in my 1971 SB.
I am re-doing my harness and need to make a few changes, but I need to disconnect these spade terminal. HOW DO I DO IT???
Is there a special tool? I tried just pulling and THAT didn't seem to work....
Please help, yes, I did check the forum.. Thanks CC _________________ China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight= |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76976 Location: Sneaking up behind you
Posted: Sun Nov 12, 2023 4:03 pm Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
They pull apart... try harder. _________________ Glenn
Member #1009
#BlueSquare |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4525 Location: Oklahoma City, OK
Posted: Mon Nov 13, 2023 10:48 am Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
Are you sure they are the twin end spade? VW used a single spade end with clip in male terminal, the fixed in does not pull out easily until little retainer is pushed back into terminal. |
Posted: Mon Nov 13, 2023 7:08 pm Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
busman78 wrote: |
OK.. What little clip and how?? _________________ China Clippers Official 1971 Super Beetle Project!
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9974 Location: Huntington Beach, CA
Posted: Tue Nov 14, 2023 5:09 pm Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
Chinaclipper wrote: |
busman78 wrote: |
OK.. What little clip and how?? |
Use this type of tool. The flat thick one works well, about 1/8 inch wide. push it in centered on the bottom side, barrel is not crimped on this side, then push the terminal in, and then back out. Should slide out if you got it!
The red one has it on it.
The tab you are trying to flatten is like these ones, but on the flat terminal.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Nov 15, 2023 10:58 am Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
VW_Jimbo wrote: |
busman78 wrote: |
Thanks Jimbo! Will do.
viiking Samba Member
Joined: May 10, 2013 Posts: 2670 Location: Sydney Australia
Posted: Wed Nov 15, 2023 2:59 pm Post subject: Re: Unhooking/ Deconnecting the shielded Spade connectors |
I’ve used a tiny jeweller’s screwdriver (the ones you use to tighten the tiny screw on sunglasses) to push that tab if you don’t have the correct tool in a pinch. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
