Dead alternator - Type 4 bay, cant find a new one.
Page: 1, 2, 3  Next
72Bus_in_OC
72Bus_in_OC is offline
PostPosted: Tue Nov 14, 2023 4:13 pm    Post subject: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Alternator just went out and Im having a hell of a time trying to find a new one. I know there are re-builds online but trying to go new here if possible.
My brother in law was telling me that there are conversion kits for Chevy alternators, has anyone here ever done that?
The only new alternator I was able to find was in Belgium and can be here in a couple of days, bad news its $320.
bsairhead
bsairhead is offline
PostPosted: Tue Nov 14, 2023 4:51 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
You can buy a remanufactured at your local FLAPS for about $70
W1K1
W1K1 is offline
PostPosted: Tue Nov 14, 2023 4:56 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
your local electric motor rewind shop should be able to rebuild it for you too.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
bsairhead
PostPosted: Tue Nov 14, 2023 5:00 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
This, Buy the cheap one from the auto parts store and take yours to the rebuilder for a spare.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Nov 14, 2023 5:02 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
is this 55 amp or 70 amp?
72Bus_in_OC
PostPosted: Tue Nov 14, 2023 5:58 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
55 Amp.
aeromech
aeromech is offline
PostPosted: Tue Nov 14, 2023 6:05 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
I have one. If you’re interested send me a pm
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Wed Nov 15, 2023 8:06 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
55 amp easy to find. Most likely Telford has looked over Gary's (Aeromech). That would be the one to get. That said, be sure the backing plate clears the stud and washer, and make your own gasket.
72Bus_in_OC
PostPosted: Wed Nov 15, 2023 9:25 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Good news everyone! I found a brand new one in Perris (Autozone) which is about 40 miles from me. Driving over to pick up now.
SGKent is offline
PostPosted: Wed Nov 15, 2023 10:14 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
do not install it until you understand the stud and washer problem that exists or you will burn some things up.
Wildthings
Wildthings is offline
PostPosted: Wed Nov 15, 2023 10:53 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
If it's new, it is likely a Bosch for a different application that will kind of fit. As mentioned make sure the two studs on the diode plate have been shortened and that the one washer is either a small diameter one or has been clipped. There may be gaps in the housing that need to be sealed off as well.
Davy_B.
Davy_B. is offline
PostPosted: Wed Nov 15, 2023 11:42 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Don't forget when you install the new one that it must get power from the wire that comes from the dashboard light... this is to magnetize! Don't ask me! I thought it was already defective... Shocked Laughing
72Bus_in_OC
PostPosted: Wed Nov 15, 2023 12:05 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Thanks for the info all!
459032
459032 is offline
PostPosted: Wed Nov 15, 2023 3:13 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Just have yours rebuilt.
1978 VW Beetle convertible w/ FI
1978 VW Bus w/ FI
bsairhead
PostPosted: Wed Nov 15, 2023 4:23 pm    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
75 Westy FI noob
75 Westy FI noob is offline
PostPosted: Thu Jun 12, 2025 7:30 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
I jump started the ol Lorax Lorry when it had a flat battery.
Now i have a dark instrument panel and running voltage of 13.2 independent of the rpms.
Is the dark panel causing the Alt not to energize?
Studying the diagram, I suspect the D+ might be cold and failing to supply the Blue wire. But based on Davy B's comment.. maybe the Blue wire is supposed to be powered by the instrument panel?
Wildthings
PostPosted: Thu Jun 12, 2025 8:11 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
With the engine not running but the key on, you should have some voltage on the blue wire at the alternator and regulator and the light on the dash should be on. Once you start the engine the voltage on the D+ wire should be whatever the charging voltage is.
75 Westy FI noob
PostPosted: Thu Jun 12, 2025 8:17 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
I'm now zeroing in on the Black (15) from the ignition ..
I thought the Blue was powered by the Red from the Alt... but now I see that there's a jumper from the Black to the Alt Light .. to the Blue.
So, assuming the Black is cold.. and the Alt Light is cold.. would that prevent the Alternator from energizing / building Amps ?
Odd to me that the Alt light is off when the key is ON, but the Alt light is on when the engine is running. more staring at diagram is in order.
SGKent is offline
PostPosted: Thu Jun 12, 2025 9:57 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
did you verify if S9 has voltage on at least one side of the fuse. Count from the left.
wagen19
wagen19 is offline
PostPosted: Thu Jun 12, 2025 11:47 am    Post subject: Re: Dead alternator - Type 4 bay, cant find a new one. Reply with quote
Dashboard light: hangs on terminal 15 + and on D+ (blue wire connected with regulator black wire)
Engine off but ignition on: > light on, because D+ brings ground, Voltage + from terminal 15
Engine on, alternator charging: > light off, because double + plus, from terminal 15 and D+
The Alternator needs minimum positive voltage from terminal 15 through the bulb of dashboard light to blue wire and D+ for starting polarising and charging then.
Page: 1, 2, 3  Next
