Epoxy primer over original seam sealer?
MajorPIle
MajorPIle is offline
PostPosted: Sun Dec 17, 2023 10:01 pm    Post subject: Epoxy primer over original seam sealer? Reply with quote
I'm restoring a 73 bug and I'm not having it dipped or sandblasted, and I'm not planning on stripping it down to bare metal.
I'm just sanding where needed, and using a wire wheel to get rid of rust (and a rust converter for any pits with rust).
I'm working on the inside of the trunk so there are a lot of small areas and it's not easy to get tools in there to strip everything down, including the original seam sealer.
I bought Eastwood epoxy primer in their spray can, and I plan to paint the inside of the trunk with this.
Will I have any issues if I leave the original seam sealer in (which appears to be fine) and spray epoxy primer over it?
viiking
viiking is offline
PostPosted: Sun Dec 17, 2023 11:30 pm    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
Yes.
There is no guarantee that there is no rust under the seam sealer.
Here's a photo of my original 68 with the seam sealer removed. It was totally rusted underneath and showed no signs of external damage at all.
Of course yours may be ok, but you won't know if you don't look.
2type2
2type2 is offline
PostPosted: Mon Dec 18, 2023 8:38 am    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
Everbody,relax and investigate.How about a little test surgery first!? Find an area(s) that looks suspiciously like it would/could/has seen moisture.Get after it with your putty knife and look underneath the seam sealer to determine current condition. If you feel lucky,that is if things look acceptable, just reseal that area and proceed. If not, well you have work to do.
On bare metal, phosphoric acid is your best friend(Ospho). Whether your car has these seam issues is dependant on its past environment. The frailties which remain after refurbishing are greatly affected by future exposures:(garage or curbside parking?) So it's an individual assessment. Remember that seam sealer flexes, so painting over sealer will not assure a waterproof seal when the paint cracks.
"A life of peace and happiness depends on your own gratefulness"
MajorPIle
PostPosted: Mon Dec 18, 2023 9:20 pm    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
viiking wrote:
Yes.
Thanks, and good point. I found some rust underneath the undercoating of my front fender that I would not have found if I hadn't stripped the undercoating away. But that was right next to the heater channel which we all know is a pretty common area for rust.
Let's say I'm fairly confident there isn't rust in this particular area, I'm wondering what the implications are for spraying an epoxy primer over the sealer. Will the epoxy primer stick? Will it crack over time? etc.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Mon Dec 18, 2023 9:40 pm    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
Being confident doesn't mean anything, being SURE means you have checked and know it's not there. I have learned one thing about rust that has been universally true.. you never know how much is or isn't there until you uncover it. Most of the time it's not a good surprise.
Based on your desired outcome I have mixed thoughts spraying epoxy over old seam sealer. If you wanted to guarantee a rust free car for several decades, the only real option would be fully remove the seam sealer prior to any additional epoxy or seam sealer. It may be okay to spray over. It is certainly a gamble though.
Robert in Memphis
Engine rebuild thread
Busstom
Busstom is offline
PostPosted: Sun Dec 31, 2023 12:36 am    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
Pile,
If you bought Eastwood's epoxy primer in a rattle can, then you must have (or should have) reviewed the extensive Q & A's associated with their product lineups. In my experience in researching their products, most all of their primers are supposed to adhere to THEIR seam sealer products, but they can't assure you that their primer will stick to OTHER seam sealers.
So in your situation, if you're set on spraying the epoxy over some of the existing seam sealer, my suggestion is to clean it (the existing seam sealer) as best you can (like with Simple Green or a cleaner of your choice), then scuff it good with some coarse Scotch-Brite, then clean (wipe) it thoroughly with acetone. This should give you the best fresh substrate on the old seam sealer to have a chance at success. Besides, you're not building a show car, so who cares if the primer/topcoat cracks or chips at the seam sealer? The only way to almost guarantee success is to start from scratch.
With respect to what MAY lurk beneath the old seam sealer is a completely different question, I have no argument or input on that point. So just go for it and do it, it's your car. By the way, I see your "rust assessment" thread and it looks like you're on the path to doing things right. Maybe start a build thread and consolidate all your issues and progress in one place.
Thumbs Up
cory464 wrote:
viiking
viiking is offline
PostPosted: Sun Dec 31, 2023 1:51 am    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
I think paint will stick to the old seam sealer better than any new seam sealer. New seam sealer still off gases for a fair while resulting in shrinking which may crack paint. But two pack epoxy is pretty tough.
I replaced my seam sealer on the sections like I pictured above with new sealer. I painted the seam sealer with polyurethane paint and it did not crack. So
I guess epoxy should be ok too.
Millionmph
Millionmph is offline
PostPosted: Wed Jun 12, 2024 9:20 am    Post subject: Re: Epoxy primer over original seam sealer? Reply with quote
Strip old sealer, clean, epoxy then reseal... worries over...
