DUNTOVFAN Samba Member
Joined: November 03, 2023 Posts: 61 Location: Fremont
Posted: Tue Dec 19, 2023 7:18 pm Post subject: Looking for this wheel |
Is the finish on this Fuch wheel a natural finish,meaning brushed satin? It's advertised as polished but looks more like the natural finish from the manufacturer.
Puppy67 Samba Member
Joined: October 04, 2022 Posts: 221 Location: Bristol, UK
Posted: Wed Dec 20, 2023 2:46 am Post subject: Re: Looking for this wheel |
It looks to me like diamond cut. The wheel is painted, then the paint (and a small amount of the metal) is cut off on a lathe to leave the "polished" area. The finish is close to polished, but not quite when examined closely as you will see the fine tool finish. A lot of modern alloys have this finish, often with a clearcoat over the top. Due to the way the "polished" surface is cut on a lathe, it can only cut the outer surfaces, not into the wells or pockets.
True detailed Fuchs wheels are polished, then anodised, then painted (originally by dipping, but mostly by masking and painting now), so the paint comes around more on the "petals" but a diamond cutter cannot reach these areas.
Posted: Wed Dec 20, 2023 5:12 am Post subject: Re: Looking for this wheel |
Puppy67 wrote: |
This is the exact finish I'm looking for in a 4.4/15 and 5.5/15 or a 6/15. Are these easily found in these sizes and finishes? Thank you for the info,greatly appreciated. |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1303 Location: North Carolina
Posted: Wed Dec 20, 2023 9:22 am Post subject: Re: Looking for this wheel |
Are you looking for these wheels in the Porsche bolt pattern(5 x 130mm) or in the early beetle bolt pattern(5 x 205mm) like the wheel you displayed?
The early beetle bolt pattern versions produced where aftermarket. I had a set on my bug in the late 70s sized 15”x 5.5”
Looks like the diamond cut finish to me.
EMPI has them in both bolt patterns:
https://v1.empius.com/vwcatalogsite/vwcatalog/2018/318.html
Last edited by DerrickfromNC1 on Wed Dec 20, 2023 9:36 am; edited 1 time in total |
Posted: Wed Feb 07, 2024 5:58 am Post subject: Re: Looking for this wheel |
Well I got the Fuchs and they are indeed polished but they look too good to send them back. The pictures I'm seeing are a bit deceptive with the satin finish. |
