adaysnight Samba Member
Joined: October 13, 2021 Posts: 88 Location: Los Angeles
Posted: Thu Feb 29, 2024 10:07 pm Post subject: Re: Throwout bearing??? |
my bowden tube bracket is definitely part of the differential side cover, so it's '61 or newer. but my 1st gear is not synchronized, i need to come to a complete stop to put it into 1st, unlike with other gears which i can shift into while rolling. or perhaps i don't understand what synchronized means... thank you. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Fri Mar 01, 2024 2:46 pm Post subject: Re: Throwout bearing??? |
If the trans case is one piece (not 2 halves bolted together), looks so in your pictures, it is synchronized in all gears. If you have to come to complete stop to get first (you should anyway, no need for 1st gear unless leaving a dead stop IMOA), your 1st gear or syncros are worn or clutch not correctly adjusted _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed Mar 06, 2024 2:10 pm Post subject: Re: Throwout bearing??? |
well i adjusted the clutch cable again, loosened it a bit, i think i may have had it too tight. took it for a test drive and all is fine but still need to stop to go into 1st.
but parking it in the garage, where it's quiet, when i press the clutch pedal, just past the free play, i hear a low rumbling sound as i push it to the floor. the sound stops when i release the pedal. this sound wasn't there before this adjustment. did i make it too loose? thank you
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9977 Location: Huntington Beach, CA
Posted: Wed Mar 06, 2024 11:35 pm Post subject: Re: Throwout bearing??? |
Sounds like a bearing going bad. If the TO bearing is good, then I would automatically go to the mainshaft bearings. Maybe you can get the car on a lift so that you can listen to it with a stethoscope. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Fri Mar 08, 2024 5:35 pm Post subject: Re: Throwout bearing??? |
thank you for your insights. i adjusted the clutch cable yet again and reduced the play down to about half an inch, maybe a bit less, and the noise went away. test drove it and shifting is fine, just that the clutch engagement point is now at about half to three quarter way up on the pedal release. before it was at less than half. otherwise, no difference. |
