Westfalia trim piece available?
Fairview
Fairview is offline
PostPosted: Sat Jan 20, 2024 7:47 am    Post subject: Westfalia trim piece available? Reply with quote
Need some parts help: is the wide white plastic header trim available somewhere? This one has wrinkled quite a bit. Thanks
Forgot to say this is for a 1976 Westfalia
Slip356
Slip356 is offline
PostPosted: Sat Jan 20, 2024 9:08 am    Post subject: Re: Westfalia trim piece available? Reply with quote
Bet if you took it off & heated it with a heat gun or equal, pressed it flat with a couple 2X 4S with weight it would be re useable.
dodger tom Premium Member
dodger tom is offline
PostPosted: Sat Jan 20, 2024 9:35 am    Post subject: Re: Westfalia trim piece available? Reply with quote
https://nlavw.com/home/449-westfalia-white-plastic-ceiling-covertrim.html
KentABQ Premium Member
KentABQ is offline
PostPosted: Sat Jan 20, 2024 10:50 am    Post subject: Re: Westfalia trim piece available? Reply with quote
My favorite year and in my favorite color!
I'm very jealous Very Happy
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
Fairview
Fairview is offline
PostPosted: Sat Jan 20, 2024 12:44 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Great idea, will try that first. Thank you
Fairview
Fairview is offline
PostPosted: Sat Jan 20, 2024 12:45 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Thanks for this, nice source!
Fairview
Fairview is offline
PostPosted: Sat Jan 20, 2024 12:47 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Thanks Kent. Just curious, why is it your favorite year?
Manfred58sc
Manfred58sc is offline
PostPosted: Sat Jan 20, 2024 10:02 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Really sweet Bus, heat gun and a wet cloth to "quench" once it gets good and warm helps retain desired shape.
Fat chick owner/operator
KentABQ is offline
PostPosted: Sun Jan 21, 2024 3:31 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
It has the swivel front seat, 2.0 l engine, and the cabinets are all along one side which leaves room between the bed and the passenger seat.
In my Riviera, if the bed is pulled out, there is about one square foot to stand between the sink cabinet and the cooler cabinet.
It makes it very tight for two adults and one 70 lb dog.
Some people prefer the full width bed that mine has, but I think I'd like the 3/4 width with room to stand and get dressed.
-Kent-
---WildIdea
Pango Pango
Pango Pango is offline
PostPosted: Wed Jan 24, 2024 3:50 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Bus Depot too.
https://www.busdepot.com/231070850
Fairview
Fairview is offline
PostPosted: Thu Jan 25, 2024 3:19 am    Post subject: Re: Westfalia trim piece available? Reply with quote
Thanks to all, your help is much appreciated.
otiswesty
otiswesty is offline
PostPosted: Fri Jan 26, 2024 9:54 am    Post subject: Re: Westfalia trim piece available? Reply with quote
Mine was also badly warped. Unable to find a replacement, I took mine off and the bare green metal looked nice as well. Recently I did use the NLA VW piece and it is hgh quaity. It is off white in color and a bit stiffer plastic than the original, but is a very accurate replacement piece.
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Fri Jan 26, 2024 3:18 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
Just how off-white is it? Do you have photos of it installed?
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
obieoberstar
obieoberstar is offline
PostPosted: Fri Jan 26, 2024 9:19 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
I purchased this from NLA a few years back. Yes it is a bit stiffer. I could not get rear edge wrapped over the sheet metal. Trimmed it to fit and used some Gorilla tape to hold it in place. Looks great still.
bugfil
bugfil is offline
PostPosted: Sun May 11, 2025 11:43 pm    Post subject: Re: Westfalia trim piece available? Reply with quote
I just purchased one of these trim pieces for my 78' Westy and I am not sure how to install it. It seems very brittle and definitely won't bend without breaking to fit over the metal support it's designed to cover. Has anyone been successful installing one of these ceiling trim pieces yet?
Thanks, Phil
raymino
raymino is offline
PostPosted: Tue May 13, 2025 8:15 am    Post subject: Re: Westfalia Atrim piece available? Reply with quote
Mine is not only wrinkled but cracked. I got a replacement and it seems to me that the upper bunk (headbanger and closet too) needs to come out to do a proper install.
'79 Westy Headflow Masters 2.0L FI
'87 GTI 16V Sold!
'06 Jetta 2.5 Package 2
'71 Super Marine Blue
busdaddy
busdaddy is offline
PostPosted: Tue May 13, 2025 8:22 am    Post subject: Re: Westfalia trim piece available? Reply with quote
I'm not sure about the closet and headbanger, but it would help to loosen the bed board so it can be wedged up 1/4".
Heat is your friend here, warming it up not only makes it bendy, it also expands it so getting that lip over the edge isn't as much of a pucker session. A wide thin putty knife helps too, use it as a ramp to slide the plastic up over the lip, start the rear lip first of course.
Слава Україні!
bugfil
bugfil is offline
PostPosted: Fri May 16, 2025 9:45 am    Post subject: Re: Westfalia trim piece available? Reply with quote
Here is my update on the install process on the Westy headbanger plastic trim piece. In a quick sentence-it doesn't seem possible to install it without cutting it
or ruining it with heat and bending. I did manage to get it installed but the upper, narrower forward lip is warped and cracked after too much heat and flexing to get it into place. This is noticeable but you would have to look closely as it is partially hidden by the upper bunk fabric where it snaps onto the headbanger. It's also questionable how long the plastic will last in it's weakened condition.
I'm definitely disappointed with my efforts as it's quite a bit of work to get the bunk platform out of the way.
The first thing I did was call the Bus Depot where I purchased the trim and asked if they had any idea how it installs. I spoke to Anthony who did his best to help but no one there knew how to install the piece. He said he would call the supplier, which I believe is NLA VW Parts in the UK, to see what they would recommend for installation. I'm waiting to hear back on that.
Meanwhile, I pulled the bus out and raised the top and started disassembly to have access to the bar. The side trim and has to be pulled loose and the narrow upper side panels need to be removed or pulled away. then you can access the Phillips screws that hold the bed base down along the sides. You do not have to remove any of the cabinets.
Once I had space to work I carefully held the trim piece up the the bar and gently slid it onto the lip of the header bar. It cracked slightly immediately.
At that point I hadn't used any heat but I was very careful and it still split.
Next I laid it on the work bench and carefully heated it with a heat gun, It turned to the consistency of a lasagna noodle almost instantly. Wow, I did not expect this as the plastic is very rigid! I next used a hair dryer to try to heat the part, it didn't get hot enough to do the job.
I thought busdaddy's idea of using heat(carefully) and thin putty knives to gently bend the flange out and upward to clear the lip of the headbanger bar and then gently bend back over the lip of the bar to it's original shape would
work and it did but as you can see in the photos I had to bend so much that the plastic cracked, warped and broke along much of the flange. It's obviously not meant to bend anywhere near that far. It needed to move somewhere around 1/4" to clear the front lip after the rear wider flange is installed on the rear lip. It's very difficult to work with the softened plastic without damaging it.
I will consider redoing the trim in the future if there really is a way to install the part correctly that I haven't figured out yet. Of course I'd have to buy another trim piece then. There is a wide flange and a narrow flange on the part. I installed the wide flange to the back(which is where the screws go that hold the front of the bunk down.and heated and bent the main body of the part slightly and focused on bending the narrow plastic flange to clear the lip of the headbanger bar.
Well, I would say it was a Fail!
This camper came from the original owner and I've worked to keep it as original as possible. I though this part would be the finishing touch to the mostly original interior. The original vinyl headlining material was replaced with a more modern auto headlining fabric in the mid 90's.
I would welcome feedback if you have been successful installing the part properly without cutting it or heating it into a mess.
bugfil
bugfil is offline
PostPosted: Sun May 18, 2025 8:07 am    Post subject: Re: Westfalia trim piece available? Reply with quote
I had a chance to look at an original trim piece in a mostly unmolested 76' Westy yesterday. The wide flange is installed on the front side of the headbanger
the opposite of how I installed mine. I'm not sure if that matters or not, it wouldn't change the fit anyway. Here are a few photos.
