EricBo142 Samba Member
Posted: Sat Feb 03, 2024 10:44 pm Post subject: Towing |
Do we just use the standard empi beetle tow rig for these things? I have a Ram 1500 stock height for a.towing vehicle
. Thankd |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9788 Location: Oregon
Posted: Sun Feb 04, 2024 6:36 am Post subject: Re: Towing |
Lovely car.
A standard tow bar is all you need to tow your buggy.
Buy a receiver that is low enough to keep the tow bar fairly level to the front end of your car.
EDIT: Don't forget the safety chain. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Feb 04, 2024 9:17 am Post subject: Re: Towing |
I have towed mine with standard EMPI style to bar, longest trip was 300 miles behind 2005 Chevy Silverado.... Only issue with these is you can't back up (well you can IF you get lucky)... So stay out of blind driveways and parking lots that only have one way in or out...
IF you have locking steering column be sure it stays unlocked, and that trans stays in neutral.. _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
NJ John Samba Member
Joined: September 21, 2007 Posts: 2237 Location: HdG, MD & NJ
Posted: Sun Feb 04, 2024 11:37 am Post subject: Re: Towing |
That buggy should follow well. Big tires and not slammed. The lower your ball the better. It’s the lifting action of a tall hitch that makes towing sometimes sketchy. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Bikerndiver Samba Member
Joined: December 05, 2023 Posts: 95 Location: Mid-Atlantic
Posted: Sun Feb 04, 2024 6:21 pm Post subject: Re: Towing |
That is a beautiful buggy!!!! _________________ 1966 Manx clone (possibly a Joe Poty Enterprises) named SANDY. '70 to '73 1300 cc w/1600 DP heads, twin carbs and headers |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1173 Location: San Angelo, Texas
Posted: Mon Feb 05, 2024 9:55 am Post subject: Re: Towing |
Nice car. Make sure, and double check that the car is in neutral. A long time ago, I worked at a VW dealership and a roll back wrecker brought in a Baha bug from 60 miles south of where we we were located. The Baha was being towed down Interstate 10, in gear, maybe 1st gear behind a motorhome. It had exploded the engine (going 70mph in 1st gear) The wrecker driver said it had started range fires on some ranches by hot pieces of the motor flying into the bar ditch. The engine was about half still attached and had nearly sawed itself off the transmission, leaving a huge groove cut into the bell housing before other folks driving down the interstate got him to pull over. To late. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Thu Feb 08, 2024 11:24 am Post subject: Re: Towing |
NJ John wrote: |
That buggy should follow well. Big tires and not slammed. The lower your ball the better. It’s the lifting action of a tall hitch that makes towing sometimes sketchy. |
Thanks everyone. I waw.thinking having a welder maybe extend that empi bar some hoping the longer length would help. It doesn't lower the ball obviously but maybe not as sharp of a angle car to ball will do the trick |
Posted: Thu Feb 08, 2024 11:26 am Post subject: Re: Towing |
rugblaster wrote: |
Nice car. Make sure, and double check that the car is in neutral. A long time ago, I worked at a VW dealership and a roll back wrecker brought in a Baha bug from 60 miles south of where we we were located. The Baha was being towed down Interstate 10, in gear, maybe 1st gear behind a motorhome. It had exploded the engine (going 70mph in 1st gear) The wrecker driver said it had started range fires on some ranches by hot pieces of the motor flying into the bar ditch. The engine was about half still attached and had nearly sawed itself off the transmission, leaving a huge groove cut into the bell housing before other folks driving down the interstate got him to pull over. To late. |
Now that's a shit show to avoid lol |
Posted: Sat Feb 10, 2024 12:50 am Post subject: Re: Towing |
NJ John wrote: |
Good ideas I did not even think of a lower ball I see them daily but it never entered my mind |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Thu Mar 07, 2024 4:41 pm Post subject: Re: Towing |
Adjustible height receiver is about $20 at HF. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Thu Mar 07, 2024 7:51 pm Post subject: Re: Towing |
Wolfgangdieter wrote: |
Adjustible height receiver is about $20 at HF. |
Have not checked prices lately have you.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Thu Mar 07, 2024 8:06 pm Post subject: Re: Towing |
Now just under $30 at WalMart, $33 at Amazon and $45 at HF less 20-30% off coupon - so corrected at $30. Argh, that $8 hamburger is now $18! _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
