Tow’dman Samba Member
Joined: February 17, 2024 Posts: 1 Location: Appleton WI
Posted: Sat Feb 17, 2024 5:54 pm Post subject: Longer tie rods for 6” beam. |
I just installed a 6 inch wider front beam on my buggy I’m using the stock steering box that is mounted more to the driver side. My question is where do I find extended Tie rods? I have looked extensively and I cannot find them. I have a searched the forms can’t find any info. Moore has extended tie rods that I found but they’re both the same length for I believe a super beetle. I would assume that I would need them 3 inches longer on each side? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Feb 17, 2024 7:03 pm Post subject: Re: Longer tie rods for 6” beam. |
Fabricate them? _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Sat Feb 17, 2024 7:04 pm Post subject: Re: Longer tie rods for 6” beam. |
OOPS!....Double post.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
DeathBySnuSnu Samba Member
Posted: Sat Feb 17, 2024 7:12 pm Post subject: Re: Longer tie rods for 6” beam. |
I have never had that set up and it has been a very long time. All I have seen the past few decades have been center steer racks.
Somebody used to make lift spindles and wide beams...... Tweed.... Tweeds. Something like that. Call the places that sell wide beams Moore parts, Dan's Buggies, Claudes buggies...... ect _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
cbeck Samba Member
Posted: Sun Feb 18, 2024 6:52 am Post subject: Re: Longer tie rods for 6” beam. |
Bet you will need a center steer box/rack. The long tie rod will likely hit the frame at full droop. Make your own tie rods out of tubing and properly sized weld in threaded bungs. Center steer should give equal length tie rods. Make 3 and carry the spare.
Edit. If using a vw pan the long rod will not clear the frame head without serious notching
At full droop, mine just clear the bottom frame rail.
_________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Sat Feb 24, 2024 10:02 am Post subject: Re: Longer tie rods for 6” beam. |
Pretty much no one uses a stock box with a widened beam. Best sugestion is the R&P mentinoned above. _________________ Michael
Pit Boy 6163 Spec Trophy Truck |
