36hp No Spark/Start
PatterBon
Samba Engine Connoisseur
PatterBon is offline
PostPosted: Mon Feb 19, 2024 1:11 pm    Post subject: 36hp No Spark/Start Reply with quote
Hey guys,
So I'm at a loss. My 1959 36er was running in last year and then suddenly stopped charging. It would fire up fine but the red light wouldn't extinguish.
So I'm now here trying to get it going again and it refuses to start. The condenser, points, cap and rotor were all new as of April of last year and she ran like a Swiss watch.
Today I've taken apart all the ignition components, cleaned them up, and reinstalled in the same order they came out in.
With the ignition ON, if I flick the points open, there is a spark. So I know spark is at least getting to the distributor. But it won't even attempt to fire. The cap is clean, the wires are clean, the parts are all about a year old and it ran fine before. I'm getting fuel to the carb and the fuses look fine. 6v at the coil with the ignition ON. I've even tried swapping coils to no avail. Hopefully you guys have seen this before and can point me in the right direction!
PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer
esde
esde is offline
PostPosted: Mon Feb 19, 2024 1:31 pm    Post subject: Re: 36hp No Spark/Start Reply with quote
Check/ clean the plugs, and then check for spark at the plugs.
modok wrote:
PatterBon
PostPosted: Mon Feb 19, 2024 2:05 pm    Post subject: Re: 36hp No Spark/Start Reply with quote
Got her running again, there was corrosion in the distributor and condensation. Went all through it again and it fired up!
2020 Ford F-150
1959 Karmann Ghia
rdwood
rdwood is offline
PostPosted: Fri Feb 23, 2024 10:12 am    Post subject: Re: 36hp No Spark/Start Reply with quote
Thanks for letting us know the cause of the problem.
'57 Beetle- Horizon Blue
'71 Ghia Convertible - Tornado Red
'74 Super Beetle - Tropical Green
