1971 Super Beetle - Total Newbie Restoration
EvanAskins
EvanAskins is offline
PostPosted: Wed Feb 21, 2024 8:08 am    Post subject: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Hey ya'll!
About a year ago, I purchased a '71 Super Beetle as an engagment gift to my now wife.
I was never a fan of classic VW, but my wife was so in love with them that I knew it'd make a great gift. (She even has a tatoo of one.)
But once I got it home, I realised that I was in for a wild ride...I'm not new to working on cars, as I've replaced water pumps, alternators, brakes, etc on newer cars, but I definetely have never done the work that I'm about to do.
As I've been working on it, (it sat for about a year before we bought a house and moved it to the garage) I quickly fell in love with how simple everything is.
That being said, there is a lot of body work that needs to be done, and I have never even touched a welder before. I have a lot to learn, but I am super excited to one day take my wife to some of the local VW meets in the Tampa Bay area.
I'm very excited for the work ahead! Expect quite a few newbie questions from me in the near future.
Zundfolge1432
Zundfolge1432 is offline
PostPosted: Wed Feb 21, 2024 9:46 am    Post subject: Re: New Member / VW Newbie Reply with quote
I hate rust and usually it’s not localized. I would immediately look the entire car over for rust and determine if it makes sense to try and repair. Anything can be fixed but you gotta balance the time, potentially hundreds of hours with cost parts supplies and labor. It doesn’t have to make economic sense as there are many cars running around that owners have gone overboard restoring to the point they have spent 25k for a car that is worth 8 to 10k on a good day. Who knows when but super beetles might be worth serious coin some day if you stay around a few years.
EvanAskins
PostPosted: Wed Feb 21, 2024 10:30 am    Post subject: Re: New Member / VW Newbie Reply with quote
The floor pans definitely need to be replaced, and the heater channels need to go. The A and B pillars look good, and the chasis doesn't look bad either. From what I've seen, heater channels and floor pans are a super common replacment, so in my mind it doesn't make much sense to buy a donor car that will most likely have the same issue...not too sure though!
oprn
oprn is offline
PostPosted: Wed Feb 21, 2024 11:19 am    Post subject: Re: New Member / VW Newbie Reply with quote
Welcome! That is the same year and color my SB was! If that is the worst rust on that car then it is pretty cherry for it's age. Absolutely it is worth fixing up!
Keep us posted please.
EvanAskins
PostPosted: Wed Feb 21, 2024 1:22 pm    Post subject: Re: New Member / VW Newbie Reply with quote
I'm not too sure about the formalities, but should I just start a new thread in the Super Beetle section and continiously post updates to that thread?
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Wed Feb 21, 2024 6:46 pm    Post subject: Re: New Member / VW Newbie Reply with quote
Evan, You can continue to post in this forum, if you wish.
But posting in the 68 and up forum will garner better and more knowledgeable answers, when you have a question about your car. Plus, folks there will likely see more of your car than in the General / Chat forum.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Abscate Premium Member
Abscate is offline
PostPosted: Thu Feb 22, 2024 4:28 am    Post subject: Re: New Member / VW Newbie Reply with quote
Ask a mod to bump your thread over to super Beetlr world
And a spouse who likes any VW as an engagement gift is awesome …
.ssS!
PostPosted: Thu Feb 22, 2024 8:24 am    Post subject: Re: New Member / VW Newbie Reply with quote
Moved!
omegared
omegared is offline
PostPosted: Thu Feb 22, 2024 9:26 am    Post subject: Re: New Member / VW Newbie Reply with quote
If you're looking for VW shows or swap meets in the Tampa Bay area there is a pretty decent one in Dade City called The Bug Jam. I'm not sure what time of year it is but I'm sure the internet does.
Volkswagens don't like trees, make all necessary efforts to keep your VW from meeting one.
1966 Bus
1976 Bus
1971 Standard Beetle
EvanAskins
PostPosted: Thu Feb 22, 2024 10:11 am    Post subject: Re: New Member / VW Newbie Reply with quote
So I got the engine out an onto a stand! The harbor freight stand only let me attached the top two mounts, so I wont be able to split the case until I get a hold of a VW adaptor.
That being said, I found out that this engine isn't the original! It's an AJ model that was originally FI. (A previous owner did a carb conversion.) My question is, whats with the extra port on the top of the intake manifold? I can't find anything like it, and I'm considering just buying a new dual port intake manifold...any suggestions?
omegared
omegared is offline
PostPosted: Thu Feb 22, 2024 11:33 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
"My question is, whats with the extra port on the top of the intake manifold?"
Had one of these manifolds on a '76 bus. If I remember correctly it is a vacuum line port that runs to the vacuum assist brakes. If not using vacuum assist brakes it can jus be plugged.
1966 Bus
1976 Bus
Zundfolge1432
PostPosted: Thu Feb 22, 2024 11:46 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Exhaust gas recirculation. It would have had a small pipe going to muffler. The tube on the left side was vacuum port for distributor. Autostik cars had a huge vacuum port in addition to that.
tpinthepack
tpinthepack is offline
PostPosted: Sat Feb 24, 2024 2:54 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Small world, I recognize the apartment building, my son used to live there off US 19 in Clearwater. There is plenty of VW enthusiasts in this area, good luck.
Tony
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
EvanAskins
PostPosted: Thu Mar 14, 2024 7:17 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Got the body off the pan. I'm starting to wonder how I'm going to store all these pieces I'm removing before the rebuild!
T1SuperNoob
T1SuperNoob is offline
PostPosted: Thu Mar 14, 2024 10:11 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Awesome! Man I wish the body on my restoration project was that good. I'm in for a world of hurt compared to that!
agramer1966
agramer1966 is offline
PostPosted: Thu Mar 14, 2024 12:59 pm    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
I wish i have restoration as "complicated" as yours.
Label everything into small bags and take a lot of pictures as you go along. Good luck Sir👍.
1966 VW1300
1973 VW1302
1979 924
1984 924
Bunch of old Jap motorbikes
Instagram & YT: #agrameroldoctane
EvanAskins
PostPosted: Tue Apr 23, 2024 7:28 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Getting the chassis completely torn apart. Removing all the "fixes" the last owner did has been helpful in showing me what NOT to do Laughing (They welded the floor pans in with about 5 giant welds that were largely not doing anything.)
...Does anyone have a good machine shop in the tampa bay area that will work on these engines? I've called 10+ shops and no one will touch my engine with a ten foot pole. I'm not expecting much work needs to be done, but it would be nice to have a shop in my pocket just in case.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Tue Apr 23, 2024 8:25 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
These folks will probably be able to help or point you to where you can get the needed work done:
https://www.facebook.com/olsensvw/
Tom
"Following distance is proportional to IQ."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
"But I also have to say, for the umpty-umpth time, that life isn't fair. It's just fairer than death, that's all." William Goldman
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
Chinaclipper
Chinaclipper is offline
PostPosted: Thu May 02, 2024 10:21 am    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Dude! Come on!!
If you've gotten THIS far, you can take care of the engine! What'ddya got to loose? You can do it!! you can learn something, have fun, save money! What a concept!!
Good luck!
China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight=
EvanAskins
PostPosted: Tue May 07, 2024 12:01 pm    Post subject: Re: 1971 Super Beetle - Total Newbie Restoration Reply with quote
Chinaclipper wrote:
Dude! Come on!!
Good luck!
Lol, I appreciate the attitude! I was mainly asking because if I need machine work done, I def don't have the capability. I might be over thinking it, hopefully the engine just needs a basic rebuild and nothing rebored, turned, or machined.
